Hi everyone!
As is well known, finite element assembly can be represented in the following form
The matrices R^(m) are the standard Boolean matrices which provide the
local-to-global correspondence of the numbering of the degrees of freedom.
If I want to perform some matrix operations before assembly.
For example,inverse of a matrix:
Can dolfinx do it?
The reason for doing this is that I need B as a preconditioner for my solver.
Form this paper:[Element-by-Element Schur Complement Approximations for General Nonsymmetric Matrices of Two-by-Two Block Form]
