I am now using Netwon to solve a nonlinear equation and I would like to try different solvers
Jac = derivative(F, U, dU)
problem = NonlinearVariationalProblem(F, U, bcs, Jac)
prm = solver.parameters
prm['newton_solver']['linear_solver'] = 'cg' #'gmres' 'mumps', 'gmres', 'bicgstab'
prm['newton_solver']['preconditioner'] = 'amg' # 'hypre_euclid'
prm['newton_solver']['maximum_iterations'] = 50 #50
prm['newton_solver']['krylov_solver']['maximum_iterations'] = 100
prm['newton_solver']['relaxation_parameter'] = 0.9 #0.9
prm['newton_solver']['absolute_tolerance'] = 1E-6
prm['newton_solver']['relative_tolerance'] = 1E-8 #tol_tstep * tol_fac #0.01
prm['newton_solver']['report'] = True
prm['newton_solver']['error_on_nonconvergence'] = True
prm['newton_solver']['krylov_solver']['report'] = True
prm['newton_solver']['krylov_solver']['monitor_convergence'] = True
prm['newton_solver']['krylov_solver']['nonzero_initial_guess'] = True
prm['newton_solver']['krylov_solver']['error_on_nonconvergence'] = True
However, the linear solver does not converge, which shows:
Newton iteration 0: r (abs) = 5.819e+02 (tol = 1.000e-06) r (rel) = 1.000e+00 (tol = 1.000e-08)
Solving linear system of size 781072 x 781072 (PETSc Krylov solver).
PETSc Krylov solver starting to solve 781072 x 781072 system.
RuntimeError:
*** Reason: Solution failed to converge in 0 iterations (PETSc reason DIVERGED_NANORINF, residual norm ||r|| = 0.000000e+00).
*** Where: This error was encountered inside PETScKrylovSolver.cpp.
*** Process: 0
*** DOLFIN version: 2019.1.0
*** Git changeset:
My question is: why the output does not include the convergence process of linear solvers? I would like to see the error of every linear iteration and the number of iterations, etc… I have thought that prm['newton_solver']['krylov_solver']['monitor_convergence'] = True should do this job, but it seems not.
Thanks,
Leon
