I created a mesh for a circle domain using Gmsh (GUI version), and save it as .msh file.
Then I’d like to read the
.msh file using dolfinx.io.gmshio.read_from_msh() and save it as .xdmf file. The reading code is as following:
path = "../data/mesh/"
domain = dolfinx.io.gmshio.read_from_msh(path + "circle.msh", MPI.COMM_WORLD)[0]
dolfinx.io.XDMFFile(MPI.COMM_WORLD, path + "circle.xdmf", "w").write_mesh(domain)
Howerver, some errors output:
Info : Reading '../data/mesh/circle.msh'...
Info : 4 entities
Info : 8133 nodes
Info : 8227 elements
Info : Done reading '../data/mesh/circle.msh'
MPI_ERR_RANK: invalid rank
MPI_ABORT was invoked on rank 0 in communicator MPI COMMUNICATOR 8 DUP FROM 4
with errorcode 6.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
Process finished with exit code 6
