I would like to convert a msh file generated with gmsh python API into two xdmf files (one for the full mesh and one for the facets). I use FEniCS (not FEniCSx). My script is organized as follow:
I generate a msh file using gmsh python API. The mesh generation follows test problem 1. At the end I have a msh file called
mesh.msh. -
Then I try to create a mesh & facet objects using tutorial 2. Inside the
Create_meshfunction, the mesh object I would like to return is calledmeshand is aMeshinstance, the facet object is calledfacetand is aMeshFunctionSizetinstance.
The whole script is written just below:
This script takes only care about the gmsh mesh creation
#------------ Mesh Creation ---------------#
import time
import sys
import math
# cylinder radius
r = 0.05
# length of the fluid domain
L = 2.2
# hight
h = 0.41
# coordinates of the center of the cylinder
c_x, c_y = [0.2], [0.2]
# dimension of the mesh
gdim = 2
# Calculating the time that mesh generation will take
tic = time.perf_counter()
gmsh.model.add("Schaffer_cylinder")
# target mesh size for any point
lc = 0.2
# lc = 0.75
# extra fine
# factors = {"cylinders": 0.025, "cylinders_far": 0.6, "wake_start": 0.05, "wake_end": 0.5}
# very_fine (with l=1 --> 8791)
# factors = {"cylinders": 0.045, "cylinders_far": 1, "wake_start": 0.05, "wake_end": 0.25}
# fine (with lc = 0.35 = 52246)
# factors = {"cylinders": 0.045, "cylinders_far": 0.75, "wake_start": 0.055, "wake_end": 0.15}
# # mirror comparison
# factors = {"cylinders": 0.045, "cylinders_far": 1, "wake_start": 0.055, "wake_end": 0.35}
# test settings
factors = {"cylinders": 0.02, "cylinders_far": 0.2, "wake_start": 0.02, "wake_end": 0.2}
# standard
# factors = {"cylinders": 0.07, "cylinders_far": 1, "wake_start": 0.08, "wake_end": 0.4}
# coarse
# factors = {"cylinders": 0.1, "cylinders_far": 1, "wake_start": 0.12, "wake_end": 0.4}
# very coarse
# factors = {"cylinders": 0.14, "cylinders_far": 1, "wake_start": 0.19, "wake_end": 0.4}
#---------- Geometry creation -------------#
# Rectangle
rectangle = gmsh.model.occ.addRectangle(0, 0, 0, L, h, tag=1)
# Cylinder
obstacle = gmsh.model.occ.addDisk(c_x[0], c_y[0], 0, r, r)
# Fluid domain
fluid = gmsh.model.occ.cut([(gdim, rectangle)], [(gdim, obstacle)])
gmsh.model.occ.synchronize()
#--------- Tags & Physical Groups ---------#
fluid_marker = 1
assert (len(volumes) == 1)
gmsh.model.addPhysicalGroup(volumes[0][0], [volumes[0][1]], tag=fluid_marker)
gmsh.model.setPhysicalName(volumes[0][0], fluid_marker, "Fluid")
inlet_marker, outlet_marker, wall_marker, obstacle_marker = 2, 3, 4, 5
inflow, outflow, walls, obstacle = [], [], [], []
for boundary in boundaries:
if np.allclose(center_of_mass, [0, h / 2, 0]):
inflow.append(boundary[1])
elif np.allclose(center_of_mass, [L, h / 2, 0]):
outflow.append(boundary[1])
elif np.allclose(center_of_mass, [L / 2, h, 0]) or np.allclose(center_of_mass, [L / 2, 0, 0]):
walls.append(boundary[1])
obstacle.append(boundary[1])
gmsh.model.addPhysicalGroup(1, walls, tag=wall_marker)
gmsh.model.setPhysicalName(1,wall_marker, "walls")
gmsh.model.addPhysicalGroup(1, inflow, tag=inlet_marker)
gmsh.model.setPhysicalName(1, inlet_marker, "inlet")
gmsh.model.addPhysicalGroup(1, outflow, tag=outlet_marker)
gmsh.model.setPhysicalName(1, outlet_marker, "outlet")
gmsh.model.addPhysicalGroup(1, obstacle, tag=obstacle_marker)
gmsh.model.setPhysicalName(1, obstacle_marker, "cylinder")
#---------------- Fields ------------------#
res_min = r / 5
distance_field = gmsh.model.mesh.field.add("Distance")
gmsh.model.mesh.field.setNumbers(distance_field, "EdgesList", obstacle)
threshold_field = gmsh.model.mesh.field.add("Threshold")
gmsh.model.mesh.field.setNumber(threshold_field, "IField", distance_field)
gmsh.model.mesh.field.setNumber(threshold_field, "LcMin", res_min)
gmsh.model.mesh.field.setNumber(threshold_field, "LcMax", 0.15 * h)
gmsh.model.mesh.field.setNumber(threshold_field, "DistMin", r)
gmsh.model.mesh.field.setNumber(threshold_field, "DistMax", 2 * h)
min_field = gmsh.model.mesh.field.add("Min")
gmsh.model.mesh.field.setNumbers(min_field, "FieldsList", [threshold_field])
gmsh.model.mesh.field.setAsBackgroundMesh(min_field)
#------------ Mesh Generation -------------#
gmsh.option.setNumber("Mesh.Algorithm", 8)
gmsh.option.setNumber("Mesh.RecombinationAlgorithm", 2)
gmsh.option.setNumber("Mesh.RecombineAll", 1)
gmsh.option.setNumber("Mesh.SubdivisionAlgorithm", 1)
gmsh.model.mesh.setOrder(2)
gmsh.write("mesh.msh")
# gmsh.model.mesh.generate(gdim)
if '-nopopup' not in sys.argv:
gmsh.fltk.run()
#---------- Creating xdmf Files -----------#
# ------- and mesh & facet objects --------#
def create_Mesh():
Method that creates the Mesh object from a msh file. It also creates facet_tags.
Returns
the mesh object
mesh = Mesh()
# The mesh generated with gmsh's python API
mesh_file = "mesh.msh"
# xdmf file that will contain the mesh
# xdmf_file = os.path.splitext(mesh_file)[0] + ".xdmf"
xdmf_file = "full_mesh.xdmf"
# xdmf file that will contain the 1D elements mesh (facets)
# facet_file = os.path.splitext(mesh_file)[0] + "_facet.xdmf"
facet_file = "facet_mesh.xdmf"
# read mesh from msh file
msh = meshio.read(mesh_file)
# create the 1D element mesh
# line_mesh = create_mesh(msh, "line", prune_z=True)
line_mesh = create_mesh(msh, "line3", prune_z=True)
meshio.write(facet_file, line_mesh)
# TODO set
# create the xdmf mesh
# triangle_mesh = create_mesh(msh, "triangle", prune_z=True)
# meshio.write(xdmf_file, triangle_mesh)
quad_mesh = create_mesh(msh, "quad9", prune_z=True)
meshio.write(xdmf_file, quad_mesh)
# writing xdmf file into Mesh object
with XDMFFile(xdmf_file) as infile:
infile.read(mesh)
# retrieving the facets
mvc1 = MeshValueCollection("size_t", mesh, 1)
with XDMFFile(facet_file) as infile:
infile.read(mvc1, "name_to_read")
facet = cpp.mesh.MeshFunctionSizet(mesh, mvc1)
# reading mesh from file
# self.parameters["mesh"] = mesh
# self.parameters["facet_tags"] = facet
return mesh, facet
def create_mesh(mesh, cell_type, data_name="name_to_read", prune_z=False):
Function that create a meshio.Mesh object from msh mesh using meshio.
Parameters
mesh meshio.Mesh
the mesh object on which the mesh will be written
cell_type : str
see meshio doc
data_name : str
see meshio doc
prune_z: bool
see meshio doc
Returns
meshio.Mesh
the mesh created from the msh mesh file.
# retrieving the cell type (line or triangles or quads)
# getting the cell data knowing physical groups of the msh file and the cell type
# retrieving the points corresponding to the cells (the z coordinate is pruned in the 2D case!)
# creating the meshio.Mesh object from the previously defined parameters
out_mesh = meshio.Mesh(points=points, cells={cell_type: cells}, cell_data={
data_name: [cell_data]})
return out_mesh
full_mesh, facet_mesh = create_Mesh()
The mesh (following test problem 1) is made of second order quadrilateral elements. In meshio, I checked, and the cells type are "line3" or "quad9". So I modified the tutorial 2, and changed "line" to "line3" and "quad" to "quad9".
The problem occurs when the class XDMFFile read the xdmf file created with meshio. The error specifies:
*** Error: Unable to recognise cell type.
*** Reason: Unknown value "quadrilateral_9".
Also note that if I comment the line gmsh.model.mesh.setOrder(2) and change back "line3" to "line" and "quad9" to "quad", then I get this error:
*** Error: Unable to order quadrilateral cell.
*** Reason: Cell is not orderable.
*** Where: This error was encountered inside QuadrilateralCell.cpp.
*** Process: 0
The tutorial 2 is useful to me, but I must admit that I do not really know how it works. As a consequence, my modification do not work. Could someone help me adapting the tutorial 2 so that I get the mesh and facets (with line3 & quad9)? Because with a standard 2D triangle mesh, everything works fine.
Thanks and regards.
