I don’t know what happened, but my mshr installation doesn’t work anymore. I reinstalled mshr from source but the error remains.
>>> from mshr import *
File "<stdin>", line 1, in <module>
File "/usr/lib/python3/dist-packages/mshr/__init__.py", line 24, in <module>
from .cpp import Circle
ImportError: libdolfin.so.2017.2: cannot open shared object file: No such file or directory
I’m not sure why it references libdolfin.so.2017.2, because if I check my dolfin version by dolfin-version, I get 2018.1.0
Did you install mshr from source in the /usr directory? I see you have the file /usr/lib/python3/dist-packages/mshr/__init__.py. That’s usually where package managers install its packages, so it is not a good idea to use this directory for packages built from source. Did you install the rest of the FEniCS packages also from source?
