Hello everyone,
I am trying to do mechanical analysis of a plate with a hole, as shown in figure.
A parametric study for the y-displacement at the midpoint of top surface as a function of the length of the geometry is carried out. The bottom face is fixed, while the top is subjected to traction boundary condition (Tr = 1). The sides have a periodic boundary condition. Height of the block is D ( = 1) and width is W( = 1). D is the parameter to be varied for the study.
When I do the parametric study using a for loop in FEniCSx the first iteration gives correct result and the iterations thereafter give wrong results. When I do the same parametric study manually i.e. run the simulation for different parameter values sequentially, I get different values for y-displacement. For example,
D = 1.00, B[1] (manually) = 1.10308, B[1] (for-loop) = 1.10308
D = 1.10, B[1] (manually) = 1.16850, B[1] (for-loop) = 0.98714
Probably, there is some issue with my implementation of the multi-point constraint function within the for-loop. I am using FEniCSx 0.9 on Ubuntu. Can someone please help me with the issue. A MWE is attached below
import os
import pyvista
import tqdm.autonotebook
from basix.ufl import element
from dolfinx import plot, default_scalar_type, mesh, geometry
from dolfinx.cpp.mesh import to_type, cell_entity_type
from dolfinx.fem import (Constant, functionspace, Expression, assemble_scalar, dirichletbc, form, locate_dofs_topological, locate_dofs_geometrical, set_bc, petsc, Function)
from dolfinx.fem.petsc import (apply_lifting, assemble_matrix, assemble_vector, create_vector, create_matrix, set_bc, LinearProblem)
from dolfinx.graph import adjacencylist
from dolfinx.geometry import bb_tree, compute_collisions_points, compute_colliding_cells
from dolfinx.io import (VTXWriter, distribute_entity_data, gmshio)
from dolfinx.mesh import (create_mesh, meshtags_from_entities, locate_entities_boundary)
from ufl import (FacetNormal, Identity, Measure, TestFunction, lhs, TrialFunction, as_vector, div, dot, ds, dx, inner, grad, nabla_grad, rhs, sym, system)
from dolfinx import io
import dolfinx_mpc
from dolfinx_mpc import LinearProblem, MultiPointConstraint
from dolfinx_mpc.utils import create_point_to_point_constraint
from dolfinx.common import Timer, TimingType, list_timings
os.system('clear')
print(f"DOLFINx version: {dolfinx.__version__}")
no_iter = 2
B_D = np.zeros((no_iter, 2))
for iter in range(no_iter):
W = 1.00
D = 1.00 +iter*0.1
r = 0.20
gdim = 2
mesh_comm = MPI.COMM_WORLD
model_rank = 0
rectangle = gmsh.model.occ.addRectangle(0, 0, 0, W, D)
circle = gmsh.model.occ.addDisk(W/2, D/3, 0, r, r)
bool1 = gmsh.model.occ.cut([(gdim, rectangle)],[(gdim, circle)])[0]
gmsh.model.occ.synchronize()
gmsh.model.addPhysicalGroup(gdim, [bool1[0][1]], 1*(iter+1))
gmsh.option.setNumber("Mesh.CharacteristicLengthMin", 0.05)
gmsh.option.setNumber("Mesh.CharacteristicLengthMax", 0.05)
gmsh.option.setNumber("Mesh.Algorithm", 11)
gmsh.option.setNumber("Mesh.RecombinationAlgorithm", 1)
gmsh.option.setNumber("Mesh.RecombineAll", 0)
gmsh.option.setNumber("Mesh.SubdivisionAlgorithm", 2)
domain, cell_markers, facet_markers = gmshio.model_to_mesh(gmsh.model, mesh_comm, model_rank, gdim=gdim)
V = functionspace(domain, ("Lagrange", 1, (gdim,)))
u_sol = Function(V, name="Displacement")
E = 1.0
nu = 0.3
mu = E / (2 * (1 + nu))
lmbda = E*nu / ((1+nu)*(1-2*nu))
boundaries = [(1, lambda x: np.isclose(x[1], 0)),
(2, lambda x: np.isclose(x[1], D))]
facets = dolfinx.mesh.locate_entities(domain, fdim, locator)
facet_indices.append(facets)
facet_tag = dolfinx.mesh.meshtags(domain, fdim, facet_indices[sorted_facets], facet_markers[sorted_facets])
def on_bottom(x):
return np.isclose(x[1], 0)
bottom_dofs = locate_dofs_geometrical(V, on_bottom)
bc_bottom = dirichletbc(np.zeros((2,)), bottom_dofs, V)
bcs = [bc_bottom]
def on_side(x):
return np.isclose(x[0], 1)
def eps(u):
return ufl.sym(ufl.grad(u))
def sigma(u):
return lmbda * ufl.nabla_div(u) * ufl.Identity(len(u)) + 2*mu*eps(u)
##Periodic boundary condition =============================
def periodic_relation(x):
out_x = np.zeros(x.shape)
out_x[0] = 1 - x[0]
out_x[1] = x[1]
out_x[2] = x[2]
return out_x
with Timer("~Elasticity: Initialize MPC"):
mpc = MultiPointConstraint(V)
mpc.create_periodic_constraint_geometrical(V, on_side, periodic_relation, bcs)
mpc.finalize()
##Variational problem =====================================
ds = ufl.Measure("ds", domain = domain, subdomain_data = facet_tag)
u = ufl.TrialFunction(V)
Tr = Constant(domain, default_scalar_type((0, 1.00)))
a = ufl.inner(sigma(u), eps(v)) * ufl.dx
L = ufl.dot(Tr, v) * ds(2)
problem = LinearProblem(a, L, mpc, bcs= bcs, petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
uh = problem.solve()
point = np.zeros((3,1))
point[0] = W/2
point[1] = D
tree = geometry.bb_tree(domain, domain.topology.dim)
cells = []
points_on_proc = []
cell_candidates = geometry.compute_collisions_points(tree, point.T)
colliding_cells = geometry.compute_colliding_cells(domain, cell_candidates, point.T)
for i, pt in enumerate(point.T):
points_on_proc.append(pt)
points_on_proc = np.array(points_on_proc, dtype=np.float64)
B = uh.eval(points_on_proc, cells)
B_D[iter] = [D, B[1]]
print(B_D)
