I have a system with two weak PDEs of the form:
F(u,v,q1)=0
and
G(u,v,q2)=0
I want to solve F for u with a temporary v, then vice versa for G.
I’m struggling with how to implement this.
The only way I can get things to run at the moment is to have u,v as Functions(V) and q1,q2 as q1,q2=TestFunctions(V).
But then it’s unclear what the solutions to NonVariationalProblem(F,x) are, is x an estimate for u or v? I thought it made the most sense to have a
u=TrialFunction(V)
v=TrialFunction(V)
tmpu=Function(V)
tmpv=Function(V)
but this gives me
File "/usr/local/lib/python3.6/dist-packages/ufl/algorithms/check_arities.py", line 41, in nonlinear_operator
raise ArityMismatch("Applying nonlinear operator {0} to expression depending on form argument {1}.".format(o._ufl_class_.__name__, t))
My real question is, if the NonVariationalProblem contains two function terms then what does the solution represent?
MWE:
import random
def Initial(perm,x,out):
size=out.vector().size()
r1=np.random.rand(size)
r2=np.random.rand(size)
out.vector().set_local(x+perm*(r1-r2))
return out
def lapla(u):
return inner(grad(u),grad(u))
def Simulations():
# nx,ny are number of elements on x and y axis
# xm, ym are maximum x and y values
# x0,y0 are minimum x and y values
# hx, hy are meshwidth on the x and y axis.
x0=0
y0=0
xm=10
ym=10
nx=10
ny=10
StSt=[0,1]
perm=0.1
# FeNiCs variables--------------------------------------------------
# Initialise the space ---------------------------------------------
mesh=RectangleMesh(Point(x0,y0),Point(xm,ym),nx,ny)
#P1 = FiniteElement('P', triangle, 1)
#element = MixedElement([P1, P1])
V = FunctionSpace(mesh, 'Lagrange',1)
# Function(V) indicates a scalar variable over the domain.
# TestFunction(V) is a scalar test function over the domain for the weak problem.
u0 = TrialFunction(V)
v0 = TrialFunction(V)
tmpu0 = Function(V)
tmpv0 = Function(V)
u1 = Function(V)
v1 = Function(V)
q1 = TestFunction(V)
q2 = TestFunction(V)
#Initialise time step 0
tmpu0 = Initial(perm,StSt[0],tmpu0)
tmpv0 = Initial(perm,StSt[1],tmpv0)
# Define variational problem ---------------------------------------
F=(lapla(u0)+u0**2-u0*tmpv0)*q1*dx
G=(lapla(v0)+(tmpu0+v0)*(1-v0)-v0)*q2*dx
# Solvers
problem_u=NonlinearVariationalProblem(F,u1)
solver_u=NonlinearVariationalSolver(problem_v)
tmpu0.assign(u1)
problem_v=NonlinearVariationalProblem(G,v1)
solver_v=NonlinearVariationalSolver(problem_v)
tmpv0.assign(v1)
return
def main(simon=1):
if simon: Simulations()
return
if __name__=='__main__':
main()
exit()
