The articles that you proposed ain’t freely accessible, can write down the formula you’re referencing to?
For the boundary condition you want to impose Neumann bc?
Ok thanks,
I have some questions before answering. The equation (5.10) is your PDE? The \Delta is a Laplacian or \nabla ?
It’s important to have a clear formulation of your PDE. For example you can rewrite (5.10) with \nabla\psi instead of \partial_{x_1}\psi and \partial_{x_2}\psi.
Finally are you sure that the Neumann bc and the dirichlet bc are compatible?
if I understand well, \Delta is the Laplacian (in another place of the paper (5.10) is called ‘‘Nonlinear Biharmonic Problem’’).
Yes, problem (5.10) with boundary conditions (6.7) and (6.8) is the problem I want to implement (I realize just now that it is slightly different from the problem in (6.9) ).
I am not an expert in PDE and for this reason, I decided to post this topic.
I believe that conditions (6.7) and (6.8) are not compatible as they are written. Since this should be equivalent to the lid-driven cavity problem I believe that (6.7) should be imposed just on three sides of the square and (6.8) should be imposed on one side of the square. I am not sure of this and I would appreciate knowing your opinion.
You may also want to check the Biharmonic demo since the weak form 5.16, if you want to implement as it is, requires you to have your approximation in H^2(\Omega), which again would require at least C^1-continuous spaces. These are difficult to construct compared to C^0 functions. Even though FIAT as the celebrated Argyris triangle, as far as I know, it is not supported in ffc.
Dear bhaveshshrimali,
thank you for your answer!
Yes have already given a look to the tutorial on biharmonic equations and I did not notice this issue…
On the documentation, they say ‘‘partially supported’’ for the Argyris triangle (see here ).
Do you think that this could fix the issue?
Best
Stefano
Yes, I think only FIAT supports the Argyris triangle, ffc doesn’t; so you cannot do any meaningful calculations using it. I have tested this in dolfin-2018.1.0; and I don’t think dolfin-2019.1.0 would either. You can check by typing FunctionSpace(mesh, "Argyris", 5).
Firedrake has full support for Argyris as I understand but even though it does, imposing Dirichlet boundary conditions might not be straightforward for C^1 continuous elements. You can check the paper, they have examples and code as supplements. If you are looking to use Argyris, you can also check a lightweight library scikit-fem. It also has an example on using Argyris.
I haven’t used tiGAR, but it does seem to support C^1 splines on quads/hex @kamensky might be the best person to help you with it.
Hi, thanks for posting your question and having this discussion here. I have been trying to solve the Navier-Stokes Stream function-vorticity formulation. But have very little luck in it and haven’t found any good notes on variation form and how to do time stepping. Would you mind to share your code with or if you would be willing to point me to any notes for it. Thanks!
