Hi All,
I am trying to define a external force T=10 (along x-direction) on a surface of a rectangular geometry (60 * 10 * 5) on a surface with id=15 with actual area (5 * 10 = 50). I have specifically created these id’s in Gmsh and are labelled correctly. The surface id=16 is given a DirichletBC and works perfectly.
- But the ds(15) gives me 100. Can anyone help me with this?
- There is no error while running the program but the solution is also not converging for this.
I am attaching my files and code for reference.
https://drive.google.com/drive/folders/1UwOmKv_oxyOpJIStliJrya-b2NB5tgGu?usp=sharing
mesh = Mesh("Rectangle-v1.xml")
fd = MeshFunction('size_t', mesh, "Rectangle-v1_facet_region.xml")
ds = Measure("ds", domain=mesh, subdomain_data=fd)
ds_15 = ds(15)
E0 = 30e3
nu = 0.30
mu = E0/(2*(1 + nu))
lmbda = E0*nu/((1 + nu)*(1 - 2*nu))
return 0.5*(grad(u) + grad(u).T)
def sigma(u):
return 2.0*mu*epsilon(u) + lmbda*tr(epsilon(u))*Identity(len(u))
bc_left = DirichletBC(V, Constant((0, 0, 0)), fd, 16)
bcs = [bc_left]
f = Constant((0, 0, 0))
T = Constant((10, 0, 0))
L = dot(f, v)*dx + dot(T, v)*ds_15
F = a - L
J=derivative(F, u)
# Solve the problem
solve(F == 0, u, J=J)
u_x, u_y, u_z = u.split(deepcopy=True)
file_u_x = File("Test1/u_x_plt.pvd")
file_u_x << u_x
file_u_y = File("Test1/u_y_plt.pvd")
file_u_y << u_y
file_u_z = File("Test1/u_z_plt.pvd")
file_u_z << u_z
