I am trying to implement a simple cantilever type problem, where the left edge is fixed and a known traction is applied at the middle portion of the right edge. I have done this problem multiple time in FEniCS.
For FEniCSx, I have followed this tutorial example. However, it seems that L = ufl.dot(T, du) * ds(1) is not able to recognize the boundary marked as 1, and the solution is zero everywhere. I am not sure what I am missing here.
Thanking you for your help and sorry for such trivial question.
## Standard library imports
import timeit
## FEniCSx related imports
from ufl import ds, dx, grad, inner, nabla_grad
### ------ Problem domain description (with the example of cantilever problem)-------------
## Geometry description
x0 = 0.0; y0 = 0.0
x1 = 2.0; y1 = 1.0
nx = 100; ny = 50
h = 0.10 # half length on right edge with load
trac0 = -1.0 # applied traction
## Material parameters
E = 1.0
nu = 0.3
lambda_ = E*nu/(1+nu)/(1-2*nu)
mu = E/(2*(1+nu))
### ------ Function for the calculation of stress -----
def epsilon(v):
return ufl.sym(ufl.grad(v))
def sigma(v):
"""Return an expression for the stress \sigma given a displacement field v """
return lambda_ * ufl.nabla_div(v) * ufl.Identity(len(v)) + 2*mu*epsilon(v)
### ------- Mesh generation and boundary condition facets -----------------
msh = mesh.create_rectangle(comm=MPI.COMM_WORLD,
points=((x0, y0), (x1, y1)), n = (nx, ny),
cell_type=mesh.CellType.quadrilateral,)
### ------- Function spaces and functions for density and displacement fields -------------
## Function space for displacement
V_disp = fem.VectorFunctionSpace(msh, ("Lagrange", 1))
## Function space for density field
V_density = fem.FunctionSpace(msh, ("DG", 0))
## Test and trial function for displacement solution
u, du = ufl.TestFunction(V_disp), ufl.TrialFunction(V_disp)
u_sol = fem.Function(V_disp)
### --------- Setup variational problem -----------------
## Apply dirichlet boundary condition
dofs_dirchlet_zero = fem.locate_dofs_geometrical(V_disp, marker = lambda x: np.isclose(x[0], x0))
bc = fem.dirichletbc(value= np.array([0,0], dtype=ScalarType), dofs= dofs_dirchlet_zero, V= V_disp)
## Neumann bc
T = fem.Constant(msh, ScalarType((0, trac0))) # traction bc
dofs_neumann = fem.locate_dofs_geometrical(V_disp, marker = lambda x: np.logical_and(np.isclose(x[0], x1),
np.logical_and( x[1]<= y1/2 + h, x[1] >= y1/2 - h)))
#print(dofs_neumann)
meshtags_neumann = mesh.meshtags(mesh = msh, dim = (msh.topology.dim - 1), entities = dofs_neumann, values= 1)
ds = ufl.Measure("ds", subdomain_data = meshtags_neumann) #
print(meshtags_neumann.indices)
print(meshtags_neumann.values)
## Variational problem
a = ufl.inner(sigma(u), epsilon(du)) * dx
problem = fem.petsc.LinearProblem(a, L, bcs=[bc], petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
u_sol = problem.solve()
with io.XDMFFile(msh.comm, "data/check_elasticity_sol.xdmf", "w") as file:
file.write_mesh(msh)
file.write_function(u_sol)
