New ArityMismatch Problem
Hi everyone,
in my last issue there was great help with one equation of the system which I am trying to solve (Problem with nonlinear variational problem). The full system which i try to solve is:
\begin{align} \int u\psi -\int u^n\psi +\Delta t\left(\int\nabla p\psi +\int \sigma\cdot\nabla\psi + \mu\int\nabla u\cdot \nabla\psi\right)&=0\\ \sigma &=C-1\\ \int \left(C-C^n+\frac{1}{\lambda}(C-1)\right)v -\Delta t\begin{pmatrix} \frac{1}{\lambda}\int\partial_1u v_1\\ \frac{1}{\lambda}\int\partial_2u v_2\\ 2\int (\partial_1 uC_1+\partial_2 u C_2)v_3 \end{pmatrix}&= 0 \end{align}
Where \sigma and C are 3 dimensional vectors and u is scalar. I tried to solve this task by using this piece of code (only the things relevant for the variational form):
domain=mshr.Cylinder(Point(0,0,0),Point(2,0,0),1.,1.)
mesh = mshr.generate_mesh(domain, nCells)
StressTensorElement1 = FiniteElement('P', tetrahedron, 1)
StressTensorElement2 = FiniteElement('P', tetrahedron, 1)
StressTensorElement3 = FiniteElement('P', tetrahedron, 1)
VelocityElements = FiniteElement('P', tetrahedron, 1)
element = MixedElement(StressTensorElement1, StressTensorElement2, StressTensorElement3, VelocityElements)
# stuff with boundary conditions was here but not relevant saved in "bc"
dt = Constant(0.1)
mu = Constant(0.1)
gradP = Constant(5)
Lambda = Constant(2.)
C1, C2, C3, u = TrialFunctions(V)
CV1, CV2, CV3, v = TestFunctions(V)
u_n = interpolate(Constant((0,0,1,0)), V) # previous timestep and initial condition at start
un1, un2, un3, un4 = split(u_n)
def getSigma(self, C1, C2, C3, Lambda):
        """get sigma from C"""
        return 0.5/Lambda*as_vector([C1-1, C2-1, C3-1])
F = u * v * dx - un4 * v * dx + dt*(gradP * v * dx\
      + dot(getSigma(uk1, uk2, uk3,  Lambda), grad(v)) * dx)\
      + Constant(mu) * dot(grad(u), grad(v)) * dx \
      + (C1 - un1 + 1 / Lambda * (C1 - 1)) * CV1 * dx\
      + (C2 - un2 + 1 / Lambda * (C2 - 1)) * CV2 * dx \
      + (C3 - un3 + 1 / Lambda * (C3 - 1)) * CV3 * dx \
      - dt *(1/Lambda*u.dx(0) * CV1 * dx \
      + 1 / Lambda * u.dx(1) * CV2 * dx + 2 * (u.dx(0) * C1 + u.dx(1) * C2) * CV3 * dx)
U = Function(V)
solve(F == 0, U, bc)
I omitted the timeloop here. The error I get is
adding expression with non-matching form arguments
But this problem is definitly nonlinear and if i call it the linear way it will of course still not work.
Thank you for your time to read this!
Try changing the following
#C1, C2, C3, u = TrialFunctions(V)
U = Function(V)
C1, C2, C3, u = split(U)
and then removing the line
U = Function(V)
immediately before the nonlinear solve. TrialFunctions are only used to define left-hand-side forms for linear problems. For nonlinear problems, the unknown should be a Function.
that solved it thanks!
