Hi, I’m trying to implement this tutorial on Hertzian contact using penalty approach by @bleyerj in 2D on an unit square domain but unfortunately ran into the error stated above in title. I tried using Custom NewtonSolver made by @nate in this post Set krylov linear solver paramters in newton solver instead of inbuilt NonlinearVariationalProblem but ran into the same error again.
Here is MWE :-
square = Rectangle(Point(0, 0), Point(1., 1.))
domain = square
mesh = generate_mesh(domain, 10)
class Top(SubDomain):
return near(x[1], 1., 1e-8) and on_boundary
def symmetry_x(x, on_boundary):
return near(x[0], 0., 1e-8) and on_boundary
def symmetry_y(x, on_boundary):
def bottom(x, on_boundary):
return near(x[1], 0., 1e-8) and on_boundary
facets = MeshFunction("size_t", mesh, 2)
facets.set_all(0)
Top().mark(facets, 1)
ds = Measure('ds', subdomain_data=facets)
R = 0.5
d = 0.02
obstacle = Expression("-d+(pow(x[0],2))/2/R", d=d, R=R, degree=2)
V = VectorFunctionSpace(mesh, "CG", 1)
V2 = FunctionSpace(mesh, "CG", 1)
V0 = FunctionSpace(mesh, "DG", 0)
u = Function(V, name="Displacement")
du = TrialFunction(V)
u_ = TestFunction(V)
gap = Function(V2, name="Gap")
p = Function(V0, name="Contact pressure")
bc =[DirichletBC(V, Constant((0., 0.)), bottom),
DirichletBC(V.sub(0), Constant(0.), symmetry_x),
DirichletBC(V.sub(1), Constant(0.), symmetry_y)]
E = Constant(10.)
nu = Constant(0.3)
mu = E/2/(1+nu)
lmbda = E*nu/(1+nu)/(1-2*nu)
def eps(v):
return sym(grad(v))
def sigma(v):
return lmbda*tr(eps(v))*Identity(2) + 2.0*mu*eps(v)
def ppos(x):
return (x+abs(x))/2.
pen = Constant(1e4)
form = inner(sigma(u), eps(u_))*dx + pen*dot(u_[1], ppos(u[1]-obstacle))*ds(1)
J = derivative(form, u, du)
class Problem(NonlinearProblem):
def __init__(self, J, F, bcs):
self.bilinear_form = J
self.linear_form = F
self.bcs = bcs
def F(self, b, x):
assemble(self.linear_form, tensor=b)
for bc in self.bcs:
bc.apply(b, x)
def J(self, A, x):
assemble(self.bilinear_form, tensor=A)
for bc in self.bcs:
bc.apply(A)
class CustomSolver(NewtonSolver):
def __init__(self):
NewtonSolver.__init__(self, mesh.mpi_comm(),
PETScKrylovSolver(), PETScFactory.instance())
def solver_setup(self, A, P, problem, iteration):
self.linear_solver().set_operator(A)
PETScOptions.set("ksp_type", "gmres")
PETScOptions.set("ksp_monitor")
PETScOptions.set("pc_type", "ilu")
self.linear_solver().set_from_options()
problem = Problem(J, form, bc)
custom_solver = CustomSolver()
custom_solver.solve(problem, u.vector())
Any help would be highly appreciated.
Thanks.
