Newton iteration against time-stepping for steady solution of the incompressible Navier-Stokes equations
Hi!
I’m interested in using FEniCSx to compute the steady solution of incompressible Navier-Stokes equations. I’ve found several examples (in the tutorials or in this forum) but they are all based on time-stepping.
But I’m coming from the world of FreeFem++ where we usually rather use a Newton iteration (as explained in section 2.1 of this article and shown in the code here).
So here comes my question: is there such an example available for FEniCSx that I missed in my research? If not then why focusing only on time-stepping? It seems to me that the Newton iteration method is pretty nice to compute a steady solution.
I tried several implementations but I’m not happy with the results (I tried both to implement by hand the Newton iteration or to use directly dolfinx.fem.petsc.NonlinearProblem and both by computing by hand the Jacobian or using ufl.derivative).
Cheers
See for instance tutorial_navier_stokes
The example as is requires an additional library, but if you don’t want to install that it is possible to replace the only two places in which it is used. I won’t do that for you, but it should be easy to do considering that you have already seen plenty of other examples.
Thanks a lot Francesco, that is exactly what I was looking for!
I put the modified code for people who does not have multiphenics and viskex (and thanks for making me discover viskex, this looks pretty cool, I’ll install it):
Adapted from https://multiphenics.github.io/tutorials/02_navier_stokes/tutorial_navier_stokes.html
import typing
from petsc4py.PETSc import ScalarType, InsertMode, ScatterMode, KSP, Vec, SNES, Mat
import dolfinx.fem.petsc as fem_petsc
import basix.ufl
pre_step_length = 4.
after_step_length = 14.
pre_step_height = 3.
after_step_height = 5.
mesh_size = 1. / 5.
nu = 0.01
def create_mesh():
    gmsh.model.add("mesh")
    p0 = gmsh.model.geo.addPoint(0.0, after_step_height - pre_step_height, 0.0, mesh_size)
    p1 = gmsh.model.geo.addPoint(pre_step_length, after_step_height - pre_step_height, 0.0, mesh_size)
    p2 = gmsh.model.geo.addPoint(pre_step_length, 0.0, 0.0, mesh_size)
    p3 = gmsh.model.geo.addPoint(pre_step_length + after_step_length, 0.0, 0.0, mesh_size)
    p4 = gmsh.model.geo.addPoint(pre_step_length + after_step_length, after_step_height, 0.0, mesh_size)
    p5 = gmsh.model.geo.addPoint(0.0, after_step_height, 0.0, mesh_size)
    l0 = gmsh.model.geo.addLine(p0, p1)
    l1 = gmsh.model.geo.addLine(p1, p2)
    l2 = gmsh.model.geo.addLine(p2, p3)
    l3 = gmsh.model.geo.addLine(p3, p4)
    l4 = gmsh.model.geo.addLine(p4, p5)
    l5 = gmsh.model.geo.addLine(p5, p0)
    line_loop = gmsh.model.geo.addCurveLoop([l0, l1, l2, l3, l4, l5])
    domain = gmsh.model.geo.addPlaneSurface([line_loop])
    gmsh.model.geo.synchronize()
    gmsh.model.addPhysicalGroup(1, [l5], 1)
    gmsh.model.addPhysicalGroup(1, [l0, l1, l2, l4], 2)
    gmsh.model.addPhysicalGroup(2, [domain], 0)
    gmsh.model.mesh.generate(2)
    mesh, subdomains, boundaries = dolfinx.io.gmshio.model_to_mesh(
        gmsh.model, comm=MPI.COMM_WORLD, rank=0, gdim=2)
    gmsh.finalize()
    return mesh, subdomains, boundaries
mesh, subdomains, boundaries = create_mesh()
# Create connectivities required by the rest of the code
boundaries_1 = boundaries.indices[boundaries.values == 1]
boundaries_2 = boundaries.indices[boundaries.values == 2]
def u_in_eval(x: np.typing.NDArray[np.float64]) -> np.typing.NDArray[  # type: ignore[no-any-unimported]
        ScalarType]:
    """Return the flat velocity profile at the inlet."""
    values = np.zeros((2, x.shape[1]))
    values[0, :] = 1.0
    return values
def u_wall_eval(x: np.typing.NDArray[np.float64]) -> np.typing.NDArray[  # type: ignore[no-any-unimported]
        ScalarType]:
    """Return the zero velocity at the wall."""
    return np.zeros((2, x.shape[1]))
V_element = basix.ufl.element("Lagrange", mesh.basix_cell(), 2, shape=(mesh.geometry.dim, ))
Q_element = basix.ufl.element("Lagrange", mesh.basix_cell(), 1)
def run_monolithic() -> dolfinx.fem.Function:
    """Run standard formulation using a mixed function space."""
    # Function spaces
    W_element = basix.ufl.mixed_element([V_element, Q_element])
    W = dolfinx.fem.functionspace(mesh, W_element)
    # Test and trial functions: monolithic
    vq = ufl.TestFunction(W)
    (v, q) = ufl.split(vq)
    dup = ufl.TrialFunction(W)
    up = dolfinx.fem.Function(W)
    (u, p) = ufl.split(up)
    # Variational forms
    F = (nu * ufl.inner(ufl.grad(u), ufl.grad(v)) * ufl.dx
         + ufl.inner(ufl.grad(u) * u, v) * ufl.dx
         - ufl.inner(p, ufl.div(v)) * ufl.dx
         + ufl.inner(ufl.div(u), q) * ufl.dx)
    J = ufl.derivative(F, up, dup)
    # Boundary conditions
    W0 = W.sub(0)
    V, _ = W0.collapse()
    u_in = dolfinx.fem.Function(V)
    u_in.interpolate(u_in_eval)
    u_wall = dolfinx.fem.Function(V)
    u_wall.interpolate(u_wall_eval)
    bdofs_V_1 = dolfinx.fem.locate_dofs_topological((W0, V), mesh.topology.dim - 1, boundaries_1)
    bdofs_V_2 = dolfinx.fem.locate_dofs_topological((W0, V), mesh.topology.dim - 1, boundaries_2)
    inlet_bc = dolfinx.fem.dirichletbc(u_in, bdofs_V_1, W0)
    wall_bc = dolfinx.fem.dirichletbc(u_wall, bdofs_V_2, W0)
    bc = [inlet_bc, wall_bc]
    # Class for interfacing with SNES
    class NavierStokesProblem:
        """Define a nonlinear problem, interfacing with SNES."""
        def __init__(  # type: ignore[no-any-unimported]
            self, F: ufl.Form, J: ufl.Form, solution: dolfinx.fem.Function,
            bcs: list[dolfinx.fem.DirichletBC], P: typing.Optional[ufl.Form] = None
        ) -> None:
            self._F = dolfinx.fem.form(F)
            self._J = dolfinx.fem.form(J)
            self._obj_vec = fem_petsc.create_vector(self._F)
            self._solution = solution
            self._bcs = bcs
            self._P = P
        def create_snes_solution(self) -> Vec:  # type: ignore[no-any-unimported]
            Create a petsc4py.PETSc.Vec to be passed to petsc4py.PETSc.SNES.solve.
            The returned vector will be initialized with the initial guess provided in `self._solution`.
            x = self._solution.vector.copy()
            with x.localForm() as _x, self._solution.vector.localForm() as _solution:
                _x[:] = _solution
            return x
        def update_solution(self, x: Vec) -> None:  # type: ignore[no-any-unimported]
            """Update `self._solution` with data in `x`."""
            x.ghostUpdate(addv=InsertMode.INSERT, mode=ScatterMode.FORWARD)
                _solution[:] = _x
        def obj(  # type: ignore[no-any-unimported]
            self, snes: SNES, x: Vec
        ) -> np.float64:
            """Compute the norm of the residual."""
            self.F(snes, x, self._obj_vec)
            return self._obj_vec.norm()  # type: ignore[no-any-return]
        def F(  # type: ignore[no-any-unimported]
            self, snes: SNES, x: Vec, F_vec: Vec
        ) -> None:
            """Assemble the residual."""
            self.update_solution(x)
            with F_vec.localForm() as F_vec_local:
                F_vec_local.set(0.0)
            dolfinx.fem.petsc.assemble_vector(F_vec, self._F)
            dolfinx.fem.apply_lifting(F_vec, [self._J], [self._bcs], x0=[x], scale=-1.0)
            F_vec.ghostUpdate(addv=InsertMode.ADD, mode=ScatterMode.REVERSE)
            dolfinx.fem.set_bc(F_vec, self._bcs, x, -1.0)
        def J(  # type: ignore[no-any-unimported]
            self, snes: SNES, x: Vec, J_mat: Mat,
            P_mat: Mat
        ) -> None:
            """Assemble the jacobian."""
            J_mat.zeroEntries()
            dolfinx.fem.petsc.assemble_matrix(  # type: ignore[misc]
                J_mat, self._J, self._bcs, diagonal=1.0)  # type: ignore[arg-type]
            J_mat.assemble()
            if self._P is not None:
                P_mat.zeroEntries()
                    P_mat, self._P, self._bcs, diagonal=1.0)  # type: ignore[arg-type]
                P_mat.assemble()
    # Create problem
    problem = NavierStokesProblem(F, J, up, bc)
    F_vec = dolfinx.fem.petsc.create_vector(problem._F)
    J_mat = dolfinx.fem.petsc.create_matrix(problem._J)
    # Solve
    snes = SNES().create(mesh.comm)
    snes.setTolerances(max_it=20)
    snes.getKSP().setType("preonly")
    snes.getKSP().getPC().setType("lu")
    snes.getKSP().getPC().setFactorSolverType("mumps")
    snes.setObjective(problem.obj)
    snes.setFunction(problem.F, F_vec)
    snes.setJacobian(problem.J, J=J_mat, P=None)
    snes.setMonitor(lambda _, it, residual: print(it, residual))
    up_copy = problem.create_snes_solution()
    snes.solve(None, up_copy)
    problem.update_solution(up_copy)  # TODO can this be safely removed?
    up_copy.destroy()
    snes.destroy()
    return up
up_m = run_monolithic()
(u_m, p_m) = (up_m.sub(0).collapse(), up_m.sub(1).collapse())
from dolfinx import fem, io
Wplot = fem.FunctionSpace(mesh, ufl.VectorElement("CG", mesh.ufl_cell(), 1 + 1, mesh.geometry.dim))
uv = fem.Function(Wplot)
uv.name = "uv"
uv.interpolate(u_m)
uv.x.scatter_forward()
with io.VTXWriter(mesh.comm, "solution_u.bp", [uv], engine="BP4") as vtx:
    vtx.write(0.0)
