Newton solver not converging for simple heat problem
Hi – I have a time-dependent heat equation that I am trying to solve, but Newton solver was not converging, so I tried solving a simpler problem (f=1 and Gaussian initial condition), but it is still not converging, which makes me think I have set something up wrong. The domain is just a cube (which I think I have set up right?), and I have homogeneous Dirichlet b.c. Even if I am extremely liberal with the relative tolerance, it still doesn’t converge. Below is a minimal working example. Any help is greatly appreciated!
from dolfinx import fem, mesh, io, plot, nls, log
# Define initial condition
def initial_condition(x):
    return np.exp(-(x[0]**2+x[1]**2+x[2]**2))
# Parameter for reaction-diffusion
D = 800 # µm^2/s
def rxn_dif(d,rho):
    # Define temporal parameters
    t = 0 # Start time
    T = 10.0 # Final time
    num_steps = 500
    # MESH
    nx, ny, nz = 50, 50, 50
    domain = mesh.create_box(MPI.COMM_WORLD, [np.array([-10,-10,-10]), np.array([10, 10, 10])],
                                   [nx, ny, nz], mesh.CellType.tetrahedron)
    V = fem.FunctionSpace(domain, ("CG", 2))
    # INITIAL CONDITION
    u_n = fem.Function(V)
    u_n.name = "u_n"
    u_n.interpolate(initial_condition)
    # BOUNDARY CONDITIONS
    boundary_facets = mesh.locate_entities_boundary(
        domain, fdim, lambda x: np.full(x.shape[1], True, dtype=bool))
    bc = fem.dirichletbc(PETSc.ScalarType(0), fem.locate_dofs_topological(V, fdim, boundary_facets), V)
    # Define solution variable and interpolate initial solution
    uh = fem.Function(V)
    uh.name = "uh"
    uh.interpolate(initial_condition)
    # VARIATIONAL FORM
    f = 1.0
    F = uh * v * ufl.dx + dt*ufl.dot(ufl.grad(uh), ufl.grad(v)) * ufl.dx - (u_n + dt * f) * v * ufl.dx
    problem = fem.petsc.NonlinearProblem(F, uh, bcs=[bc])
    # SOLVE
    solver = nls.petsc.NewtonSolver(MPI.COMM_WORLD, problem)
    solver.rtol = 1e-4
    solver.report = True
    for i in range(num_steps):
        print(t)
        # Solve linear problem
        n, converged = solver.solve(uh)
        assert(converged)
        uh.x.scatter_forward()
        u_n.x.array[:] = uh.x.array
    return uh
print(rxn_dif(5,1))
Your code seems to work fine for me. Could you add
    solver.rtol = 1e-4
    # -- Add this
    pfx = solver.krylov_solver.getOptionsPrefix()
    opt = PETSc.Options()
    opt[f"{pfx}ksp_view"] = None
    solver.krylov_solver.setFromOptions()
And let us know what solver is being used.
Hi, thanks for the response. It is using the Krylov solver, if I add the code that you indicated. Output is:
2023-01-23 09:58:03.767 ( 4.955s) [main ] petsc.cpp:677 INFO| PETSc Krylov solver starting to solve system.
It does not advance beyond the first timestep.
Very strange. So you don’t even see the output from the PETSc KSP view? E.g. I see the default ksp_type as preonly and pc_type as lu.
No, unfortunately I only see the print(t) output (0.02) and then the output I mentioned in the last comment. I have gotten the heat equation code from the tutorial to work, so I think it is some issue with the nonlinear solver on my system.
