and added the fenicsproject environment to Jupyter Notebook following ’ How to add your Conda environment to your jupyter notebook in just 4 steps’ by Cooper R K. It all went well. However when I try to run a simple code
mesh = UnitSquareMesh(32,32)
I get the error
ModuleNotFoundError Traceback (most recent call last)
Input In [6], in <cell line: 1>()
----> 1 from dolfin import *
2 from fenics import *
3 from tabulate import tabulate
ModuleNotFoundError: No module named 'dolfin'
I have python version 3.9 installed and the output of pip3 list is
(base) elizabethhawkins@Elizabeths-Air ~ % conda install -c anaconda fenics-dolfin
Collecting package metadata (current_repodata.json): done
Solving environment: failed with initial frozen solve. Retrying with flexible solve.
Collecting package metadata (repodata.json): done
PackagesNotFoundError: The following packages are not available from current channels:
- fenics-dolfin
Current channels:
- https://conda.anaconda.org/anaconda/osx-64
- https://conda.anaconda.org/anaconda/noarch
- https://repo.anaconda.com/pkgs/main/osx-64
- https://repo.anaconda.com/pkgs/main/noarch
- https://repo.anaconda.com/pkgs/r/osx-64
- https://repo.anaconda.com/pkgs/r/noarch
To search for alternate channels that may provide the conda package you're
looking for, navigate to
https://anaconda.org
and use the search bar at the top of the page.
Then I installed python version 3.9 onto the fenics environment
(fenicsproject) elizabethhawkins@Elizabeths-Air ~ % conda uninstall python
Solving environment: done
## Package Plan ##
environment location: /Users/elizabethhawkins/opt/anaconda3/envs/fenicsproject
removed specs:
- python
The following packages will be REMOVED:
boost-cpp-1.78.0-h8b082ac_1
bzip2-1.0.8-h0d85af4_4
c-ares-1.18.1-h0d85af4_0
cmake-3.25.2-h4032537_0
eigen-3.4.0-h940c156_0
expat-2.5.0-hf0c8a7f_0
fenics-dijitso-2019.1.0-py311h6eed73b_35
fenics-dolfin-2019.1.0-py311h46d4075_35
fenics-ffc-2019.1.0-py311h6eed73b_35
fenics-fiat-2019.1.0-py311h6eed73b_35
fenics-libdolfin-2019.1.0-h2bb9e8c_35
fenics-ufl-2019.1.0-py311h6eed73b_35
fftw-3.3.10-mpi_openmpi_h7f3849b_6
gmp-6.2.1-h2e338ed_0
gmpy2-2.1.2-py311hc5b4402_1
hdf5-1.12.2-mpi_openmpi_hf8ec552_1
hypre-2.25.0-mpi_openmpi_ha398ffd_0
icu-70.1-h96cf925_0
krb5-1.20.1-h049b76e_0
libaec-1.0.6-hf0c8a7f_1
libblas-3.9.0-16_osx64_openblas
libcblas-3.9.0-16_osx64_openblas
libcurl-7.87.0-h6df9250_0
libcxx-14.0.6-hccf4f1f_0
libedit-3.1.20191231-h0678c8f_2
libev-4.33-haf1e3a3_1
libffi-3.4.2-h0d85af4_5
libgfortran-5.0.0-11_3_0_h97931a8_27
libgfortran5-11.3.0-h082f757_27
libiconv-1.17-hac89ed1_0
liblapack-3.9.0-16_osx64_openblas
libnghttp2-1.51.0-he2ab024_0
libopenblas-0.3.21-openmp_h429af6e_3
libsqlite-3.40.0-ha978bb4_0
libssh2-1.10.0-h47af595_3
libuv-1.44.2-hac89ed1_0
libzlib-1.2.13-hfd90126_4
llvm-openmp-15.0.7-h61d9ccf_0
metis-5.1.0-h2e338ed_1006
mpc-1.3.1-h81bd1dd_0
mpfr-4.1.0-h0f52abe_1
mpi-1.0-openmpi
mpi4py-3.1.4-py311h0cff672_0
mpmath-1.2.1-pyhd8ed1ab_0
mumps-include-5.2.1-h694c41f_11
mumps-mpi-5.2.1-had0ebf5_11
ncurses-6.3-h96cf925_1
numpy-1.24.2-py311ha9d2c9f_0
openmpi-4.1.4-h4fe9131_102
parmetis-4.0.3-h7eda126_1005
petsc-3.17.4-real_h7f1bf32_101
petsc4py-3.17.4-real_h17f71e9_101
pip-23.0-pyhd8ed1ab_0
pkg-config-0.29.2-ha3d46e9_1008
pkgconfig-1.5.5-pyhd8ed1ab_4
ptscotch-6.0.9-h6295d7f_2
pybind11-2.10.3-py311hd2070f0_0
pybind11-global-2.10.3-py311hd2070f0_0
python-3.11.0-he7542f4_1_cpython
python_abi-3.11-3_cp311
readline-8.1.2-h3899abd_0
rhash-1.4.3-hac89ed1_0
scalapack-2.2.0-h208a4c8_1
scotch-6.0.9-h3da7401_2
setuptools-67.1.0-pyhd8ed1ab_0
six-1.16.0-pyh6c4a22f_0
slepc-3.17.2-real_h6fa9d90_100
slepc4py-3.17.2-real_hb0b1125_101
suitesparse-5.10.1-h7aff33d_1
superlu-5.2.2-h1f0f902_0
superlu_dist-7.2.0-hcde7739_0
sympy-1.11.1-py311h6eed73b_2
tbb-2021.7.0-hb8565cd_1
tk-8.6.12-h5dbffcc_0
tzdata-2022g-h191b570_0
wheel-0.38.4-pyhd8ed1ab_0
xz-5.2.6-h775f41a_0
yaml-0.2.5-h0d85af4_2
zstd-1.5.2-hbc0c0cd_6
The following packages will be UPDATED:
ca-certificates conda-forge::ca-certificates-2022.12.~ --> pkgs/main::ca-certificates-2023.01.10-hecd8cb5_0
The following packages will be SUPERSEDED by a higher-priority channel:
openssl conda-forge::openssl-3.0.8-hfd90126_0 --> pkgs/main::openssl-1.1.1s-hca72f7f_0
Proceed ([y]/n)? y
Downloading and Extracting Packages
Preparing transaction: done
Verifying transaction: done
Executing transaction: done
(fenicsproject) elizabethhawkins@Elizabeths-Air ~ % conda install python=3.9
## Package Plan ##
added / updated specs:
- python=3.9
The following NEW packages will be INSTALLED:
certifi pkgs/main/osx-64::certifi-2022.12.7-py39hecd8cb5_0
libcxx pkgs/main/osx-64::libcxx-14.0.6-h9765a3e_0
libffi pkgs/main/osx-64::libffi-3.4.2-hecd8cb5_6
ncurses pkgs/main/osx-64::ncurses-6.4-hcec6c5f_0
pip pkgs/main/osx-64::pip-22.3.1-py39hecd8cb5_0
python pkgs/main/osx-64::python-3.9.16-h218abb5_0
readline pkgs/main/osx-64::readline-8.2-hca72f7f_0
setuptools pkgs/main/osx-64::setuptools-65.6.3-py39hecd8cb5_0
sqlite pkgs/main/osx-64::sqlite-3.40.1-h880c91c_0
tk pkgs/main/osx-64::tk-8.6.12-h5d9f67b_0
tzdata pkgs/main/noarch::tzdata-2022g-h04d1e81_0
wheel pkgs/main/noarch::wheel-0.37.1-pyhd3eb1b0_0
xz pkgs/main/osx-64::xz-5.2.10-h6c40b1e_1
zlib pkgs/main/osx-64::zlib-1.2.13-h4dc903c_0
Proceed ([y]/n)? y
installed ipykernel and included the environment in jupyter notebook
(fenicsproject) elizabethhawkins@Elizabeths-Air ~ % conda install -c anaconda ipykernel
## Package Plan ##
- ipykernel
appnope anaconda/osx-64::appnope-0.1.2-py39hecd8cb5_1001
asttokens anaconda/noarch::asttokens-2.0.5-pyhd3eb1b0_0
backcall anaconda/noarch::backcall-0.2.0-pyhd3eb1b0_0
debugpy anaconda/osx-64::debugpy-1.5.1-py39he9d5cce_0
decorator anaconda/noarch::decorator-5.1.1-pyhd3eb1b0_0
entrypoints anaconda/osx-64::entrypoints-0.4-py39hecd8cb5_0
executing anaconda/noarch::executing-0.8.3-pyhd3eb1b0_0
ipykernel anaconda/osx-64::ipykernel-6.9.1-py39hecd8cb5_0
ipython anaconda/osx-64::ipython-8.3.0-py39hecd8cb5_0
jedi anaconda/osx-64::jedi-0.18.1-py39hecd8cb5_1
jupyter_client anaconda/osx-64::jupyter_client-7.2.2-py39hecd8cb5_0
jupyter_core anaconda/osx-64::jupyter_core-4.10.0-py39hecd8cb5_0
libsodium anaconda/osx-64::libsodium-1.0.18-h1de35cc_0
matplotlib-inline anaconda/noarch::matplotlib-inline-0.1.2-pyhd3eb1b0_2
nest-asyncio anaconda/osx-64::nest-asyncio-1.5.5-py39hecd8cb5_0
parso anaconda/noarch::parso-0.8.3-pyhd3eb1b0_0
pexpect anaconda/noarch::pexpect-4.8.0-pyhd3eb1b0_3
pickleshare anaconda/noarch::pickleshare-0.7.5-pyhd3eb1b0_1003
prompt-toolkit anaconda/noarch::prompt-toolkit-3.0.20-pyhd3eb1b0_0
ptyprocess anaconda/noarch::ptyprocess-0.7.0-pyhd3eb1b0_2
pure_eval anaconda/noarch::pure_eval-0.2.2-pyhd3eb1b0_0
pygments anaconda/noarch::pygments-2.11.2-pyhd3eb1b0_0
python-dateutil anaconda/noarch::python-dateutil-2.8.2-pyhd3eb1b0_0
pyzmq anaconda/osx-64::pyzmq-22.3.0-py39he9d5cce_2
six anaconda/noarch::six-1.16.0-pyhd3eb1b0_1
stack_data anaconda/noarch::stack_data-0.2.0-pyhd3eb1b0_0
tornado anaconda/osx-64::tornado-6.1-py39h9ed2024_0
traitlets anaconda/noarch::traitlets-5.1.1-pyhd3eb1b0_0
wcwidth anaconda/noarch::wcwidth-0.2.5-pyhd3eb1b0_0
zeromq anaconda/osx-64::zeromq-4.3.4-h23ab428_0
ca-certificates pkgs/main::ca-certificates-2023.01.10~ --> anaconda::ca-certificates-2022.4.26-hecd8cb5_0
certifi pkgs/main::certifi-2022.12.7-py39hecd~ --> anaconda::certifi-2022.6.15-py39hecd8cb5_0
Proceed ([y]/n)? y
(fenicsproject) elizabethhawkins@Elizabeths-Air ~ % python -m ipykernel install --user --name=fenics2
Installed kernelspec fenics2 in /Users/elizabethhawkins/Library/Jupyter/kernels/fenics2
Then I ran
from dolfin import*
and got the same error
Input In [2], in <cell line: 1>()
----> 1 from dolfin import*
Please read the output before posting. By changing the Python version, you remove the fenics installation. You need to install the Python version of choice prior to installing fenics.
