Nonlinear 1d PDE
Dear all,
I want to solve the 1d nonlinear differential equation \frac {d^2 u} {dz^2} =-\theta(z)u+\frac {1} {u^3} +\frac {Q} {2u}, where \theta(z) is the step function and Q is set to 10. The code written with dolfinx is shown below:
from petsc4py.PETSc import ScalarType, Options
from dolfinx import mesh, fem, io, nls
from ufl import TestFunction, inner, grad, dx
domain = mesh.create_interval(MPI.COMM_WORLD, 20, [0, 1])
u = fem.Function(V)
theta = fem.Function(V)
cells_0 = mesh.locate_entities(domain, domain.topology.dim, lambda x: x[0]<=0.5)
cells_1 = mesh.locate_entities(domain, domain.topology.dim, lambda x: x[0]>=0.5)
theta.x.array[cells_0] = np.full_like(cells_0, 1, dtype=ScalarType)
theta.x.array[cells_1] = np.full_like(cells_1, 0, dtype=ScalarType)
F = inner(u**3*grad(u), grad(v))*dx - inner(theta*u**4, v)*dx + inner(fem.Constant(domain, ScalarType(1)), v)*dx + inner(10*u**2, v)*dx
problem = fem.petsc.NonlinearProblem(F, u)
solver = nls.petsc.NewtonSolver(MPI.COMM_WORLD, problem)
solver.rtol = 1e-4
solver.report = True
n, converged = solver.solve(u)
assert(converged)
However, an error is reported:
RuntimeError: Newton solver did not converge because maximum number of iterations reached.
I’m really appreciated if anyone can help me.
