NonlinearVariationalProblem not working
Hello Everyone,
I am trying to extend the Phasefield modeling from brittle fracture to cohesive fracture. Therefore, my advection-diffusion equation needs to solve using nonlinear variational formulation. I am extending the code to cohesive fracture. Can anyone show me how to implement it using nonlinear problem. At this point there’s no change in constitutive equation. Here is the code:
# Preliminaries and mesh
import mshr
dom1 = mshr.Rectangle(Point(-0.50, -0.5), Point(0.5, 0.50))
dom2 = mshr.Rectangle(Point(-0.5, 0.0-1e-05), Point(0.0, 0.0+0.0+1e-05))
dom = dom1 - dom2
mesh = mshr.generate_mesh(dom, 40)
# Define Space
W = VectorFunctionSpace(mesh, 'CG', 1)
WW = FunctionSpace(mesh, 'DG', 0)
p, q = Function(V), TestFunction(V)
u, v = TrialFunction(W), TestFunction(W)
# Introduce manually the material parameters
Gc =  2.7
l = 0.015
lmbda = 121.1538e3
mu = 80.7692e3
# Constituive functions
    return sym(grad(u))
def sigma(u):
    return 2.0*mu*epsilon(u)+lmbda*tr(epsilon(u))*Identity(len(u))
def psi(u):
    return 0.5*(lmbda+mu)*(0.5*(tr(epsilon(u))+abs(tr(epsilon(u)))))**2+\
           mu*inner(dev(epsilon(u)),dev(epsilon(u)))
def H(uold,unew,Hold):
    return conditional(lt(psi(uold),psi(unew)),psi(unew),Hold)
# Boundary conditions
top = CompiledSubDomain("near(x[1], 0.5) && on_boundary")
bot = CompiledSubDomain("near(x[1], -0.5) && on_boundary")
def Crack(x):
    return abs(x[1]) < 1e-03 and x[0] <= 0.0
load = Expression("t", t = 0.0, degree=1)
bcbot= DirichletBC(W, Constant((0.0,0.0)), bot)
bctop = DirichletBC(W.sub(1), load, top)
bc_u = [bcbot, bctop]
bc_phi = [DirichletBC(V, Constant(1.0), Crack)]
boundaries.set_all(0)
top.mark(boundaries,1)
# Variational form
unew, uold = Function(W), Function(W)
pnew, pold, Hold = Function(V), Function(V), Function(V)
E_du = ((1.0-pold)**2)*inner(grad(v),sigma(u))*dx
E_phi = (Gc*l*inner(grad(p),grad(q))+((Gc/l)+2.0*H(uold,unew,Hold))\
            *inner(p,q)-2.0*H(uold,unew,Hold)*q)*dx
J = derivative(E_phi, pnew)
p_disp = LinearVariationalProblem(lhs(E_du), rhs(E_du), unew, bc_u)
p_phi = NonlinearVariationalProblem(E_phi, pnew, bc_phi, J=J)
solver_disp = LinearVariationalSolver(p_disp)
solver_phi = NonlinearVariationalSolver(p_phi)
# Initialization of the iterative procedure and output requests
t = 0
u_r = 0.007
deltaT  = 0.1
tol = 1e-3
conc_f = File ("./ResultsDir/phi.pvd")
fname = open('ForcevsDisp.txt', 'w')
# Staggered scheme
while t<=0.90:
    t += deltaT
    if t >=0.7:
        deltaT = 0.01
    load.t=t*u_r
    iter = 0
    err = 1
    while err > tol:
        iter += 1
        solver_disp.solve()
        solver_phi.solve()
        err_u = errornorm(unew,uold,norm_type = 'l2',mesh = None)
        err_phi = errornorm(pnew,pold,norm_type = 'l2',mesh = None)
        err = max(err_u,err_phi)
        uold.assign(unew)
        pold.assign(pnew)
        Hold.assign(project(psi(unew), WW))
        if err < tol:
            print ('Iterations:', iter, ', Total time', t)
            if round(t*1e4) % 10 == 0:
                conc_f << pnew
                Traction = dot(sigma(unew),n)
                fy = Traction[1]*ds(1)
                fname.write(str(t*u_r) + "\t")
                fname.write(str(assemble(fy)) + "\n")
fname.close()
print ('Simulation completed')
Hello Hasan,
did you manage developing the code?
