Nonzero pressure Navier Stokes
Hi Dolfinx community!
I’m working on a stabilized Navier-Stokes solver using DOLFINx 0.9.0 using equal order interpolation with SUPG and PSPG stabilization. The weak formulation follows the formulation in Donea & Huerta, Finite Element Methods for Flow Problems (2003), Section 6.6.1.
\begin{aligned} F(u, p; v, q) &= \rho \int_{\Omega} \mathbf{v} \cdot \left[(\mathbf{u} \cdot \nabla)\mathbf{u}\right] \, d\Omega + \mu \int_{\Omega} \nabla \mathbf{v} : \nabla \mathbf{u} \, d\Omega \\ &\quad - \int_{\Omega} p \, \nabla \cdot \mathbf{v} \, d\Omega + \int_{\Omega} q \, \nabla \cdot \mathbf{u} \, d\Omega - \rho \int_{\Omega} \mathbf{v} \cdot \mathbf{b} \, d\Omega \\[1em] &\quad + \int_{\Omega} \tau_{\text{SUPG}} \, (\nabla \mathbf{v} \, \mathbf{u}) \cdot \mathbf{R}_m \, d\Omega + \int_{\Omega} \tau_{\text{PSPG}} \, \nabla q \cdot \mathbf{R}_m \, d\Omega \end{aligned}
\mathbf{R}_m = \rho \frac{\partial \mathbf{u}}{\partial t} + \rho (\mathbf{u} \cdot \nabla)\mathbf{u} - \mu \nabla^2 \mathbf{u} + \nabla p - \rho \mathbf{b}
\tau = \left[ (2 \theta / \Delta t)^2 + (2 |\mathbf{u}| / h)^2 + (4 \nu / h^2)^2 \right]^{-1/2}
The solver behaves as expected for the velocity field, the soltuion converges quickly to the parabolic profile expected for Poiseuille flow in a 2D channel. However, the pressure field exhibits stong oscillations, especially near the beginning of the simulation (see images below). The solution eventually converges toward the physically correct steady-state, but this is not suitable for unsteady problems where the outlet pressure is prescribed as a transient boundary condition (e.g., modeling physiological outflow or time-dependent traction).
t = 50 steps
t=150 steps
t = 300 steps
When the outlet pressure is non-zero, the solver fails to converge in general. In the below image I show the fields when p_{out} = 1, which should simply shift the pressure field above by 1. Instead, we see backflow into the domain.
p out = 1
I’m confident in the weak form, we have a similar script in Dolfin 2019 that behaves as expected, but I’m not willing to rule the weak form out as a possibility. I do think the issue lies within how I’m setting up the PETSc matrix system.
MWE
import basix
import dolfinx as dfx
from dolfinx.io import gmshio
import ufl as ufl
# Define boundary markers and bc function
def left(x): return np.isclose(x[0], 0.0)
def right(x): return np.isclose(x[0], 10.0)
def top(x): return np.isclose(x[1], 1.0)
def bottom(x): return np.isclose(x[1], 0.0)
def no_slip_bc(x): return np.stack((np.zeros(x.shape[1]), np.zeros(x.shape[1])))
def inlet_bc(x):
    # Parabolic
    y = x[1]
    u_max = 1.5
    profile = np.where(np.abs(y - 0.5) <= 0.5, u_max * (1 - ((y - 0.5) / 0.5) ** 2), 0.0)
    return np.stack((profile, np.zeros(x.shape[1])))
def outlet_pressure_bc(x): return np.zeros(x.shape[1])
# Define mesh
mesh = dfx.mesh.create_rectangle(MPI.COMM_WORLD, [np.array([0.0, 0.0]), np.array([10.0, 1.0])], [100, 20], dfx.mesh.CellType.triangle)
# Define mixed function space
PE = basix.ufl.element('CG', mesh.basix_cell(), degree=1)
QE = basix.ufl.element('CG', mesh.basix_cell(), degree=1, shape=(mesh.topology.dim,))
ME = basix.ufl.mixed_element([QE, PE])
W = dfx.fem.functionspace(mesh, ME)
u_sub, u_submap = W.sub(0).collapse()
p_sub, p_submap = W.sub(1).collapse()
# Define boundary conditions
fdim = mesh.topology.dim - 1
ID_left = dfx.mesh.locate_entities_boundary(mesh, fdim, left)
ID_right = dfx.mesh.locate_entities_boundary(mesh, fdim, right)
ID_top = dfx.mesh.locate_entities_boundary(mesh, fdim, top)
ID_bottom = dfx.mesh.locate_entities_boundary(mesh, fdim, bottom)
dofs_left = dfx.fem.locate_dofs_topological((W.sub(0), u_sub), fdim, ID_left)
dofs_top = dfx.fem.locate_dofs_topological((W.sub(0), u_sub), fdim, ID_top)
dofs_bottom = dfx.fem.locate_dofs_topological((W.sub(0), u_sub), fdim, ID_bottom)
dofs_right = dfx.fem.locate_dofs_topological((W.sub(0), u_sub), fdim, ID_right)
dofs_P = dfx.fem.locate_dofs_topological((W.sub(1), p_sub), fdim, ID_right)
wall = dfx.fem.Function(u_sub)
wall.interpolate(no_slip_bc)
inlet = dfx.fem.Function(u_sub)
inlet.interpolate(inlet_bc)
pressure_out = dfx.fem.Function(p_sub)
pressure_out.interpolate(outlet_pressure_bc)
bc_left = dfx.fem.dirichletbc(inlet, dofs_left, W.sub(0))
bc_top = dfx.fem.dirichletbc(wall, dofs_top, W.sub(0))
bc_bottom = dfx.fem.dirichletbc(wall, dofs_bottom, W.sub(0))
bc_P = dfx.fem.dirichletbc(pressure_out, dofs_P, W.sub(1))
bc = [bc_left, bc_top, bc_bottom, bc_P]
dt = 0.05
(v,q) = ufl.TestFunctions(W)
mu = dfx.fem.Constant(mesh, dfx.default_scalar_type(0.001))
rho = dfx.fem.Constant(mesh, dfx.default_scalar_type(1.0))
idt = dfx.fem.Constant(mesh, dfx.default_scalar_type(1.0/dt))
theta = dfx.fem.Constant(mesh, dfx.default_scalar_type(0.5))
b = dfx.fem.Constant(mesh, PETSc.ScalarType((0.0,0.0)))
W1 = dfx.fem.Function(W)
(u,p) = ufl.split(W1)
T1_1 = rho * ufl.inner(v, ufl.dot(ufl.grad(u), u)) * ufl.dx
T2_1 = mu * ufl.inner(ufl.grad(v), ufl.grad(u)) * ufl.dx
T3_1 = p * ufl.div(v) * ufl.dx
T4_1 = q * ufl.div(u) * ufl.dx
T5_1 = rho * ufl.dot(v,b) * ufl.dx
L_1  = T1_1 + T2_1 - T3_1 + T4_1 - T5_1
W0 = dfx.fem.Function(W)
(u0,p0) = ufl.split(W0)
T1_0 = rho * ufl.inner(v, ufl.dot(ufl.grad(u0), u0)) * ufl.dx
T2_0 = mu * ufl.inner(ufl.grad(v), ufl.grad(u0)) * ufl.dx
T3_0 = p * ufl.div(v) * ufl.dx
T4_0 = q * ufl.div(u0) * ufl.dx
T5_0 = rho * ufl.dot(v,b) * ufl.dx
L_0 = T1_0 + T2_0 - T3_0 + T4_0 - T5_0
F = idt * rho * ufl.inner((u-u0),v) * ufl.dx + (1.0-theta) * L_0 + theta * L_1
# SUPG/PSPG stabilization
u_norm = ufl.sqrt(ufl.inner(u0, u0))
h = ufl.CellDiameter(mesh)
tau = ( (2.0*theta*idt)**2 + (2.0*u_norm/h)**2 + (4.0*mu/h**2)**2 )**(-0.5)
residual =  idt*rho*(u - u0) + \
            theta*(rho*ufl.grad(u)*u - mu*ufl.div(ufl.grad(u)) + ufl.grad(p) - rho*b) +\
            (1.0-theta)*(rho*ufl.grad(u0)*u0 - mu*ufl.div(ufl.grad(u0)) + ufl.grad(p) - rho*b)
F_SUPG = tau * ufl.inner(ufl.grad(v)*u, residual) * ufl.dx
F_PSPG = tau * ufl.inner(ufl.grad(q), residual) * ufl.dx
F = F + F_SUPG + F_PSPG
# Define solver
problem = NonlinearProblem(F, W1, bcs=bc)
solver.rtol = 1e-7
solver.report = True
ksp = solver.krylov_solver
opts = PETSc.Options()
opts[f"{option_prefix}ksp_type"] = "gmres"
opts[f"{option_prefix}pc_type"] = "hypre"
ksp.setFromOptions()
t = 0
tn = 0
dfx.log.set_log_level(dfx.log.LogLevel.INFO)
vFile = dfx.io.VTKFile(MPI.COMM_WORLD, 'output/u.pvd', "w")
pFile = dfx.io.VTKFile(MPI.COMM_WORLD, 'output/p.pvd', "w")
while t < 20.0:
    n, converged = solver.solve(W1)
    print(f"Number of iterations: {n:d}")
    uf = W1.split()[0].collapse()
    pf = W1.split()[1].collapse()
    uf.name = 'vel'
    pf.name = 'pres'
    vFile.write_function(uf, tn)
    pFile.write_function(pf, tn)
    W0.x.array[:] = W1.x.array
    form = ufl.div(uf) * ufl.dx
    div = dfx.fem.assemble_scalar(dfx.fem.form(form))
    print(f"Max div: {np.abs(div)}")
    tn += 1
vFile.close()
pFile.close()
Several things to consider here.
  1. Starting from zero fluid flow, with a non-ramped inlet condition will cause an initial pressure wave going from the inlet into the domain. Consider either starting with a ramped inlet condition, or an initial condition that is non-zero (for instance generated with a Stokes solver).
  2. Using strong pressure conditions is not something I would advice, see for instance: https://asmedigitalcollection.asme.org/appliedmechanicsreviews/article-abstract/59/3/107/465438/On-Boundary-Conditions-for-Incompressible-Navier
  3. Have you tried with a direct solver, rather than gmres and hypre?
If you have a similar setup in legacy FEniCS, could you provide that code as well?
Hi Dokken, thanks for these suggestions. I wanted to take a few days to make sure I had fully looked into all of them before posting an update. They have helped, but I’m still having some issues:
  1. Ramping the solution does significantly reduce the number of time steps to reach a fully developed solution.
    viscosities = np.logspace(1, -3, num=10)
    for mu_val in viscosities:
        mu.value = mu_val
    This does help reduce the impact of the initial pressure wave you mentioned, but there are still oscillations in pressure field.
  2. I switched to traction boundary conditions and that does seem to help, though we still see some issues during the first time step (see below were the inlet pressure starts lower than the outlet). We will be going this route from here forward.
    Form:
    \int_\Gamma (p_{out} \hat{\bf{n}} \cdot \underline{\bf{v}})~d\Gamma
    These images included ramping the solution from 1.
Suggestions 1 and 2 have reduced the number of steps to stabilize from ~250 steps to ~10 for p_{out}=1.0. It takes longer for large values of p_{out}=1.0, but that makes sense given the initial pressure field.
  1. I tried a direct solver with positive results. Unfortunately, the application mesh is prohibitively large, though I can investigate using LU on the p block when I move to a field splitting setup.
    a. On the legacy FEniCS note - that was a direct solve. When I switched to GMRES/HYPRE I saw the same behavior.
  2. This legacy FEniCS demo uses the Chorin projection method to solve for strong, non-zero pressure conditions. We have only seen this method (outside of this one) in the context of homogenous boundary conditions where \frac{\partial p}{\partial n} = 0 on \Gamma (but we also tend to stick to monolithic coupling). Do you think this method would be worth investigating? If it’s helpful: The larger context of my problem is to set outflow conditions on multiple outflow boundaries where the outlet pressure depends on the velocity solution at the outlet.
Thanks again for your expertise in this matter!
Then it seems your problem is purely solver related, right?
  • Have you played with tolerances and iteration count numbers?
  • A truly well-posed problem is particular important when using iterative methods. Jorgen’s comment on the mathematically correct choice of boundary enforcement for the pressure factors in here.
  • And, of course, iterative methods are all about preconditioning. What have your tried there? This Repo explores some preconditioning strategies for Stokes-like PDEs: FEniCSx4Flow / Projects / Preconditioning · GitLab
Hi all,
It doesn’t seem to be solver related. We have found some evidence that this behavior does reflect pressure transience in a physical pipe flow (similar to a hydraulic hammer) from, as Dokken said, “Starting from zero fluid flow, with a non-ramped inlet condition will cause an initial pressure wave going from the inlet into the domain”. Unfortunately, we can’t seem to find effective ways of mitigating the initial transience.
  1. Solving a stokes-like problem (large \mu) does fully develop the velocity field. We then don’t have to wait for the velocity field to develop over the entire domain, which takes time \frac{L}{\overline{u}}.
  2. This disrupts the pressure field. The pressure drop is \frac{\mu_{Stokes}}{\mu_{problem}} larger than it should be. We’ve tried:
    a. Scaling the pressure field by \frac{\mu_{Stokes}}{\mu_{problem}}, setting the pressure vector, and then solving (see equation below). This seems to get to the expected solution faster than b, but with more oscillations. I naively tried this thinking that I could help the solver by solving for the pressure with a new viscosity. Probably wouldn’t recommend.
    b. Ramping the viscosity back down to \mu_{problem} from \mu_{Stokes} in some number of steps.
p_{new} = \frac{p - outlet~pressure}{\frac{\mu_{Stokes}}{\mu_{problem}}} + outlet~pressure
  1. Doing either of the methods in 2. does help the transience decay faster than just letting the advective front move through the domain, but it still takes several steps settle out. In my testing, I have to run the problem for time about 0.5 * \frac{L}{\overline{u}} in time.
For now, it seems the solution is:
  1. Start with a Stokes problem (large value of \mu) OR Scale the pressure field to the expected one.
  2. Wait for the field to develop before adding any additional transience (ex. pulsatile inflow condition)
Some other things that have helped:
  • Use the stress-div form of the Navier-Stokes equations
  • Use the “No-BC” outflow condition which sets both natural Neumann boundary conditions.
  • Add grad-div (LSIC) stabilization
Thanks for all the help!
