Normal vector in manifold
Hello everyone,
I have created a 2D curve mesh (1D topological dimension) like this:
I need to use and visualize the normal unit vector, I looked at some post but in these they use a 3D mesh, is there a way to compute the normal unit vector to use in a variational formulation,
Also, here is my code for the mesh generation
import os
import math
from dolfinx import default_real_type, log, plot, mesh
from dolfinx.fem import Function, functionspace, Expression
from dolfinx.io import XDMFFile, gmshio
from dolfinx.mesh import CellType, create_unit_square, GhostMode
from ufl import dx, grad, inner
# Save all logging to file
log.set_output_file("log.txt")
# Next, various model parameters are defined:
dt = 5.0e-05  # time step
# A unit square mesh with 96 cells edges in each direction is created,
# and on this mesh a
# {py:class}`FunctionSpaceBase <dolfinx.fem.FunctionSpaceBase>` `ME` is built
# using a pair of linear Lagrange elements.
try:
    import gmsh  # type: ignore
except ImportError:
    import sys
    print("This demo requires gmsh to be installed")
    sys.exit(0)
def gmsh_circle(model: gmsh.model, name: str) -> gmsh.model:
    """Create a Gmsh model of a circle.
    Args:
        model: Gmsh model to add the mesh to.
        name: Name (identifier) of the mesh to add.
    Returns:
        Gmsh model with a circle mesh added.
    model.add(name)
    model.setCurrent(name)
    gmsh.option.setNumber("Mesh.CharacteristicLengthFactor", 0.2)
    circle = model.occ.addCircle(0, 0, 0, 1, tag=1)
    # Synchronize OpenCascade representation with gmsh model
    model.occ.synchronize()
    # Add physical marker for cells. It is important to call this
    # function after OpenCascade synchronization
    model.add_physical_group(dim=1, tags=[circle])
    # Generate the mesh
    model.mesh.generate(dim=1)
    return model
def create_mesh(comm: MPI.Comm, model: gmsh.model, name: str, filename: str, mode: str):
    """Create a DOLFINx from a Gmsh model and output to file.
    Args:
        comm: MPI communicator top create the mesh on.
        model: Gmsh model.
        filename: XDMF filename.
        mode: XDMF file mode. "w" (write) or "a" (append).
    msh, ct, ft = gmshio.model_to_mesh(model, comm, rank=0,gdim=2)
    msh.name = name
    ct.name = f"{msh.name}_cells"
    ft.name = f"{msh.name}_facets"
    with XDMFFile(msh.comm, filename, mode) as file:
        msh.topology.create_connectivity(0, 1)
        file.write_mesh(msh)
        file.write_meshtags(ct, msh.geometry, geometry_xpath=f"/Xdmf/Domain/Grid[@Name='{msh.name}']/Geometry")
        file.write_meshtags(ft, msh.geometry, geometry_xpath=f"/Xdmf/Domain/Grid[@Name='{msh.name}']/Geometry")
gmsh.option.setNumber("General.Terminal", 0)
# Create model
model = gmsh.model()
model = gmsh_circle(model, "circle")
model.setCurrent("circle")
create_mesh(MPI.COMM_SELF, model, "circle", f"out_gmsh/mesh_rankCircle_{MPI.COMM_WORLD.rank}.xdmf", "w")
with XDMFFile(MPI.COMM_WORLD, "out_gmsh/mesh_rankCircle_0.xdmf", "r") as xdmf:
    mesh = xdmf.read_mesh(name="circle")
gmsh.finalize
thank you
Consider the following MWE (given your mesh has been read in)
n = ufl.CellNormal(mesh)
r = x/ufl.sqrt(ufl.dot(x, x))
sign = ufl.sign(ufl.dot(n, r))
n_oriented = sign*n
import dolfinx.fem
V = dolfinx.fem.functionspace(mesh, ("DG", 0, (mesh.geometry.dim,)))
u_expr = dolfinx.fem.Expression(n_oriented, V.element.interpolation_points())
u = dolfinx.fem.Function(V)
u.interpolate(u_expr)
with dolfinx.io.XDMFFile(mesh.comm, "normal.xdmf", "w") as xdmf:
    xdmf.write_mesh(mesh)
    xdmf.write_function(u)
Thus you can use sign*n in your variational formulation.
Thank you, Dokken. It seems to work. However, I am working with an evolving mesh over time and exporting the functions of the normal vec (normal_vec) tor and a newly defined mean curvature (H) function. It appears these are not updating over time.
Here is a MWE of what I am doing:
import os
import math
from dolfinx.fem.petsc import NonlinearProblem, LinearProblem
from ufl import dx, grad, inner, div
dt = 5.0e-04  # time step
try:
except ImportError:
    import sys
    sys.exit(0)
    Args:
    Returns:
    model.add(name)
    # Generate the mesh
    return model
    Args:
        model: Gmsh model.
    msh.name = name
# Create model
gmsh.finalize
P1 = element("Lagrange", mesh.basix_cell(), 1, gdim=2)
ME = functionspace(mesh, mixed_element([P1, P1],gdim=2))
n_oriented = sign*n
V1 = functionspace(mesh, ("DG", 0, (mesh.geometry.dim,)))
V2 = functionspace(mesh, ("Lagrange", 1))
normal_expr = Expression(n_oriented, V1.element.interpolation_points())
normal_vec = Function(V1)
H_expr = Expression(div(sign*n), V2.element.interpolation_points())
H = Function(V2)
t = 0.0
file1 = XDMFFile(MPI.COMM_WORLD, "Schnakenberg/outputu1.xdmf", "w")
file2 = XDMFFile(MPI.COMM_WORLD, "Schnakenberg/outputu2.xdmf", "w")
file3 = XDMFFile(MPI.COMM_WORLD, "Schnakenberg/normal.xdmf", "w")
file4 = XDMFFile(MPI.COMM_WORLD, "Schnakenberg/H.xdmf", "w")
#  Reduce run time if on test (CI) server
if "CI" in os.environ.keys() or "GITHUB_ACTIONS" in os.environ.keys():
    T = 3 * dt
    T = 10000 * dt
x_initial = mesh.geometry.x[:,0]
y_initial = mesh.geometry.x[:,1]
sigma = 0
rho = 0
sigma = 1e-5
rho = 0.8e-5
z = 0
inc = 0
impresion = 200
while (t < T):
    inc += 1
    normal_vec.interpolate(normal_expr)
    H.interpolate(H_expr)
    num=inc/impresion-1
    velx = 1 + sigma*math.sqrt(t)
    vely = 1 + rho*math.sqrt(t)
    mesh.geometry.x[:,0] = x_initial*velx
    mesh.geometry.x[:,1] = y_initial*vely
    if (int(num)==z) or (int(num-z)==0):
        #us, vs = ufl.split(u)
        # Save solution to file (VTK)
        name = "mesh_at_t"+str(t)
        mesh.name = name
        #file1.write_mesh(mesh)
        #file1.write_function(u1, t, mesh_xpath=f"/Xdmf/Domain/Grid[@Name='{mesh.name}']")
        file3.write_mesh(mesh)
        file3.write_function(normal_vec, t, mesh_xpath=f"/Xdmf/Domain/Grid[@Name='{mesh.name}']")
        file4.write_mesh(mesh)
        file4.write_function(H, t, mesh_xpath=f"/Xdmf/Domain/Grid[@Name='{mesh.name}']")
        z += 1
file1.close()
file2.close()
file3.close()
file4.close()
print(H.x.array)
I intend to use the normal_vec and H values for a variational formulation but wanted to confirm first if it’s working properly.
Thank you.
Note that when you use linear elements (straight elements), the divergence of the normal is 0 on every element (since the normal is constant on every line segment.
If you run your code for a while, you will see that the normal is updated, but H will always remain 0, as the elements are not curved.
If you use a second order mesh, H will be non-zero.
import os
import math
try:
except ImportError:
    import sys
    sys.exit(0)
    Args:
    Returns:
    model.add(name)
    # Generate the mesh
    model.mesh.setOrder(2)
    return model
    Args:
        model: Gmsh model.
    msh.name = name
# Create model
gmsh.finalize
n_oriented = sign*n
V1 = functionspace(mesh, ("Lagrange", 2, (mesh.geometry.dim,)))
V2 = functionspace(mesh, ("Lagrange", 2))
H = Function(V2)
t = 0.0
T = 10000 * dt
sigma = 0
rho = 0
sigma = 1e-5
rho = 0.8e-5
z = 0
inc = 0
impresion = 200
while (t < T):
    inc += 1
    num=inc/impresion-1
        mesh.name = name
        z += 1
file1.close()
file2.close()
file3.close()
file4.close()
print(H.x.array)
This worked perfectly, thank you Dokken.
