Hi all,
I am dealing with mixed-dimensional PDEs when I ran into an issue with computing facet tags. Trying to reproduce Dokken’s tutorial I do not see all the desired facets marked in the plot.
The MWE is
mesh = dolfinx.mesh.create_unit_square(MPI.COMM_WORLD, 40, 40)
def Omega1(x, tol=1e-14):
return x[0] <= 0.7 + tol
def Omega0(x, tol=1e-14):
return 0.7-tol <= x[0]
tdim = mesh.topology.dim
cell_map = mesh.topology.index_map(tdim)
num_cells_local = cell_map.size_local + cell_map.num_ghosts
marker = np.empty(num_cells_local, dtype=np.int32)
heat_marker = 1
stokes_marker = 3
marker[dolfinx.mesh.locate_entities(mesh, tdim, Omega0)] = heat_marker
marker[dolfinx.mesh.locate_entities(mesh, tdim, Omega1)] = stokes_marker
cell_tags = dolfinx.mesh.meshtags(mesh, mesh.topology.dim,
np.arange(num_cells_local, dtype=np.int32),
marker)
# + tags=["remove-input"]
assert len(np.unique(marker)) <= 2
# This section will contain alot of figures, to illustrate the different steps.
# Expand to see the code for creating a plotter of meshes and meshtags.
# + tags=["hide-input"]
import sys, os
import pyvista
if sys.platform == "linux" and (os.getenv("CI") or pyvista.OFF_SCREEN):
pyvista.start_xvfb(0.05)
def plot_mesh(mesh: dolfinx.mesh.Mesh, tags: dolfinx.mesh.MeshTags=None):
plotter = pyvista.Plotter()
mesh.topology.create_connectivity(tdim-1, tdim)
if tags is None:
ugrid = pyvista.UnstructuredGrid(*dolfinx.plot.vtk_mesh(mesh))
# Exclude indices marked zero
exclude_entities = tags.find(0)
marker = np.full_like(tags.values, True, dtype=np.bool_)
marker[exclude_entities] = False
ugrid = pyvista.UnstructuredGrid(*dolfinx.plot.vtk_mesh(mesh, tags.dim, tags.indices[marker]))
print(tags.indices[marker], tags.values[marker])
ugrid.cell_data["Marker"] = tags.values[marker]
plotter.add_mesh(ugrid, show_edges=True, line_width=3)
plotter.show_axes()
plotter.show()
plot_mesh(mesh, cell_tags)
# Next we define the boundaries for our sub-domains
facet_map = mesh.topology.index_map(tdim-1)
num_facets_local = facet_map.size_local + facet_map.num_ghosts
facet_values = np.zeros(num_facets_local, dtype=np.int32)
outer_marker = 4
facet_values[dolfinx.mesh.exterior_facet_indices(mesh.topology)] = 4
def inlet(x, tol=1e-14):
return np.isclose(x[0], 0.0) & ((x[1] >= 0.4-tol) & (x[1]<=0.6+tol))
inlet_marker = 1
facet_values[dolfinx.mesh.locate_entities_boundary(mesh, tdim-1, inlet)] = inlet_marker
def outlets(x, tol=1e-14):
return ((np.isclose(x[1], 0.0) & ((0.4 - tol <= x[0]) & (x[0]<=0.6 + tol))) |
(np.isclose(x[1], 1.0) & ((0.2 - tol <= x[0]) & (x[0] <= 0.35 + tol))))
outlet_marker = 2
facet_values[dolfinx.mesh.locate_entities_boundary(mesh, tdim-1, outlets)] = outlet_marker
interface_marker = 3
facet_values[dolfinx.mesh.locate_entities(mesh, tdim-1, lambda x: np.isclose(x[0], 0.7))] = interface_marker
facet_tags = dolfinx.mesh.meshtags(mesh, tdim-1, np.arange(num_facets_local, dtype=np.int32), facet_values)
plot_mesh(mesh, facet_tags)
and I see the follwing for the facet tags:
I guess there is a bug somewhere, but I am not sure. My env is
aiohappyeyeballs 2.6.1 pyhd8ed1ab_0 conda-forge
aiohttp 3.11.16 py310hc74094e_0 conda-forge
aiosignal 1.3.2 pyhd8ed1ab_0 conda-forge
anyio 4.9.0 pyh29332c3_0 conda-forge
aom 3.9.1 h7bae524_0 conda-forge
appnope 0.1.4 pyhd8ed1ab_1 conda-forge
argon2-cffi 23.1.0 pyhd8ed1ab_1 conda-forge
argon2-cffi-bindings 21.2.0 py310h493c2e1_5 conda-forge
arrow 1.3.0 pyhd8ed1ab_1 conda-forge
asttokens 3.0.0 pyhd8ed1ab_1 conda-forge
async-lru 2.0.5 pyh29332c3_0 conda-forge
async-timeout 5.0.1 pyhd8ed1ab_1 conda-forge
attrs 25.3.0 pyh71513ae_0 conda-forge
babel 2.17.0 pyhd8ed1ab_0 conda-forge
beautifulsoup4 4.13.4 pyha770c72_0 conda-forge
bleach 6.2.0 pyh29332c3_4 conda-forge
bleach-with-css 6.2.0 h82add2a_4 conda-forge
blosc 1.21.6 h7dd00d9_1 conda-forge
brotli 1.1.0 hd74edd7_2 conda-forge
brotli-bin 1.1.0 hd74edd7_2 conda-forge
brotli-python 1.1.0 py310hb4ad77e_2 conda-forge
bzip2 1.0.8 h99b78c6_7 conda-forge
c-ares 1.34.5 h5505292_0 conda-forge
ca-certificates 2025.1.31 hf0a4a13_0 conda-forge
cached-property 1.5.2 hd8ed1ab_1 conda-forge
cached_property 1.5.2 pyha770c72_1 conda-forge
cairo 1.18.4 h6a3b0d2_0 conda-forge
cctools_osx-arm64 1010.6 h4f2c9d0_1 conda-forge
certifi 2025.1.31 pyhd8ed1ab_0 conda-forge
cffi 1.17.1 py310h497396d_0 conda-forge
charset-normalizer 3.4.1 pyhd8ed1ab_0 conda-forge
clang 16.0.6 default_h87a6e52_14 conda-forge
clang-16 16.0.6 default_hc2ef00a_14 conda-forge
clang_impl_osx-arm64 16.0.6 hc421ffc_19 conda-forge
clang_osx-arm64 16.0.6 h54d7cd3_19 conda-forge
clangxx 16.0.6 default_h75e0ad0_14 conda-forge
clangxx_impl_osx-arm64 16.0.6 hcd7bac0_19 conda-forge
clangxx_osx-arm64 16.0.6 h54d7cd3_19 conda-forge
comm 0.2.2 pyhd8ed1ab_1 conda-forge
compiler-rt 16.0.6 h3808999_2 conda-forge
compiler-rt_osx-arm64 16.0.6 h3808999_2 conda-forge
contourpy 1.3.2 py310h7f4e7e6_0 conda-forge
cycler 0.12.1 pyhd8ed1ab_1 conda-forge
cyrus-sasl 2.1.27 h60b93bd_7 conda-forge
dav1d 1.2.1 hb547adb_0 conda-forge
dbus 1.13.6 h3818c69_3 conda-forge
debugpy 1.8.14 py310h853098b_0 conda-forge
decorator 5.2.1 pyhd8ed1ab_0 conda-forge
defusedxml 0.7.1 pyhd8ed1ab_0 conda-forge
double-conversion 3.3.1 h286801f_0 conda-forge
exceptiongroup 1.2.2 pyhd8ed1ab_1 conda-forge
executing 2.1.0 pyhd8ed1ab_1 conda-forge
expat 2.7.0 h286801f_0 conda-forge
fenics-basix 0.7.0 py310hc46d281_1 conda-forge
fenics-basix-pybind11-abi 0.4.16 hb11509e_1 conda-forge
fenics-dolfinx 0.7.3 py310h26b5a40_102 conda-forge
fenics-ffcx 0.7.0 pyh4af843d_0 conda-forge
fenics-libbasix 0.7.0 hb1687fd_1 conda-forge
fenics-libdolfinx 0.7.3 h3a14aee_102 conda-forge
fenics-ufcx 0.7.0 h4af843d_0 conda-forge
fenics-ufl 2023.2.0 pyhd8ed1ab_0 conda-forge
ffmpeg 7.1.1 gpl_h583251a_104 conda-forge
fftw 3.3.10 mpi_openmpi_haef8dc3_9 conda-forge
font-ttf-dejavu-sans-mono 2.37 hab24e00_0 conda-forge
font-ttf-inconsolata 3.000 h77eed37_0 conda-forge
font-ttf-source-code-pro 2.038 h77eed37_0 conda-forge
font-ttf-ubuntu 0.83 h77eed37_3 conda-forge
fontconfig 2.15.0 h1383a14_1 conda-forge
fonts-conda-ecosystem 1 0 conda-forge
fonts-conda-forge 1 0 conda-forge
fonttools 4.57.0 py310hc74094e_0 conda-forge
fqdn 1.5.1 pyhd8ed1ab_1 conda-forge
freetype 2.13.3 h1d14073_0 conda-forge
fribidi 1.0.10 h27ca646_0 conda-forge
frozenlist 1.5.0 py310hc74094e_1 conda-forge
gdk-pixbuf 2.42.12 h7ddc832_0 conda-forge
gl2ps 1.4.2 hc97c1ff_1 conda-forge
glew 2.1.0 h9f76cd9_2 conda-forge
gmp 6.3.0 h7bae524_2 conda-forge
graphite2 1.3.13 hebf3989_1003 conda-forge
h11 0.14.0 pyhd8ed1ab_1 conda-forge
h2 4.2.0 pyhd8ed1ab_0 conda-forge
harfbuzz 11.1.0 hab40de2_0 conda-forge
hdf4 4.2.15 h2ee6834_7 conda-forge
hdf5 1.14.3 mpi_openmpi_h7d685e0_4 conda-forge
hpack 4.1.0 pyhd8ed1ab_0 conda-forge
httpcore 1.0.7 pyh29332c3_1 conda-forge
httpx 0.28.1 pyhd8ed1ab_0 conda-forge
hyperframe 6.1.0 pyhd8ed1ab_0 conda-forge
hypre 2.28.0 mpi_openmpi_haba3941_0 conda-forge
icu 75.1 hfee45f7_0 conda-forge
idna 3.10 pyhd8ed1ab_1 conda-forge
importlib-metadata 8.6.1 pyha770c72_0 conda-forge
importlib_resources 6.5.2 pyhd8ed1ab_0 conda-forge
ipykernel 6.29.5 pyh57ce528_0 conda-forge
ipympl 0.9.7 pyhd8ed1ab_1 conda-forge
ipython 8.35.0 pyh907856f_0 conda-forge
ipywidgets 8.1.6 pyhd8ed1ab_0 conda-forge
isoduration 20.11.0 pyhd8ed1ab_1 conda-forge
jedi 0.19.2 pyhd8ed1ab_1 conda-forge
jinja2 3.1.6 pyhd8ed1ab_0 conda-forge
json5 0.12.0 pyhd8ed1ab_0 conda-forge
jsoncpp 1.9.6 h726d253_1 conda-forge
jsonpointer 3.0.0 py310hbe9552e_1 conda-forge
jsonschema 4.23.0 pyhd8ed1ab_1 conda-forge
jsonschema-specifications 2024.10.1 pyhd8ed1ab_1 conda-forge
jsonschema-with-format-nongpl 4.23.0 hd8ed1ab_1 conda-forge
jupyter 1.1.1 pyhd8ed1ab_1 conda-forge
jupyter-lsp 2.2.5 pyhd8ed1ab_1 conda-forge
jupyter_client 8.6.3 pyhd8ed1ab_1 conda-forge
jupyter_console 6.6.3 pyhd8ed1ab_1 conda-forge
jupyter_core 5.7.2 pyh31011fe_1 conda-forge
jupyter_events 0.12.0 pyh29332c3_0 conda-forge
jupyter_server 2.15.0 pyhd8ed1ab_0 conda-forge
jupyter_server_terminals 0.5.3 pyhd8ed1ab_1 conda-forge
jupyterlab 4.4.0 pyhd8ed1ab_0 conda-forge
jupyterlab_pygments 0.3.0 pyhd8ed1ab_2 conda-forge
jupyterlab_server 2.27.3 pyhd8ed1ab_1 conda-forge
jupyterlab_widgets 3.0.14 pyhd8ed1ab_0 conda-forge
kahip 3.16 py310h9fdae5a_2 conda-forge
kahip-python 3.16 py310he2182f4_2 conda-forge
kiwisolver 1.4.7 py310h7306fd8_0 conda-forge
krb5 1.21.3 h237132a_0 conda-forge
lame 3.100 h1a8c8d9_1003 conda-forge
lcms2 2.17 h7eeda09_0 conda-forge
ld64_osx-arm64 951.9 h0605c9f_1 conda-forge
lerc 4.0.0 h9a09cb3_0 conda-forge
libabseil 20240722.0 cxx17_h07bc746_4 conda-forge
libadios2 2.9.2 mpi_openmpi_h6324500_0 conda-forge
libaec 1.1.3 hebf3989_0 conda-forge
libass 0.17.3 h68e5b86_2 conda-forge
libblas 3.9.0 31_h10e41b3_openblas conda-forge
libboost 1.84.0 hc9fb7c5_7 conda-forge
libboost-devel 1.84.0 hf450f58_7 conda-forge
libboost-headers 1.84.0 hce30654_7 conda-forge
libbrotlicommon 1.1.0 hd74edd7_2 conda-forge
libbrotlidec 1.1.0 hd74edd7_2 conda-forge
libbrotlienc 1.1.0 hd74edd7_2 conda-forge
libcblas 3.9.0 31_hb3479ef_openblas conda-forge
libclang-cpp16 16.0.6 default_hc2ef00a_14 conda-forge
libclang-cpp18.1 18.1.8 default_hf90f093_9 conda-forge
libclang13 20.1.3 default_hee4fbb3_0 conda-forge
libcurl 8.13.0 h73640d1_0 conda-forge
libcxx 20.1.3 ha82da77_0 conda-forge
libcxx-devel 16.0.6 h86353a2_2 conda-forge
libdeflate 1.23 hec38601_0 conda-forge
libedit 3.1.20250104 pl5321hafb1f1b_0 conda-forge
libev 4.33 h93a5062_2 conda-forge
libexpat 2.7.0 h286801f_0 conda-forge
libffi 3.4.6 h1da3d7d_1 conda-forge
libgfortran 14.2.0 heb5dd2a_105 conda-forge
libgfortran5 14.2.0 h2c44a93_105 conda-forge
libglib 2.84.0 hdff4504_0 conda-forge
libhwloc 2.11.2 default_hbce5d74_1001 conda-forge
libiconv 1.18 hfe07756_1 conda-forge
libintl 0.23.1 h493aca8_0 conda-forge
libjpeg-turbo 3.0.0 hb547adb_1 conda-forge
liblapack 3.9.0 31_hc9a63f6_openblas conda-forge
libllvm16 16.0.6 hc4b4ae8_4 conda-forge
libllvm18 18.1.8 hc4b4ae8_3 conda-forge
libllvm20 20.1.3 h598bca7_0 conda-forge
liblzma 5.8.1 h39f12f2_0 conda-forge
liblzma-devel 5.8.1 h39f12f2_0 conda-forge
libnetcdf 4.9.2 nompi_h610d594_116 conda-forge
libnghttp2 1.64.0 h6d7220d_0 conda-forge
libntlm 1.8 h5505292_0 conda-forge
libogg 1.3.5 h99b78c6_0 conda-forge
libopenblas 0.3.29 openmp_hf332438_0 conda-forge
libopenvino 2025.0.0 h97facdf_0 conda-forge
libopenvino-arm-cpu-plugin 2025.0.0 h97facdf_0 conda-forge
libopenvino-auto-batch-plugin 2025.0.0 h7f72211_0 conda-forge
libopenvino-auto-plugin 2025.0.0 h7f72211_0 conda-forge
libopenvino-hetero-plugin 2025.0.0 hd3d436d_0 conda-forge
libopenvino-ir-frontend 2025.0.0 hd3d436d_0 conda-forge
libopenvino-onnx-frontend 2025.0.0 h76e6831_0 conda-forge
libopenvino-paddle-frontend 2025.0.0 h76e6831_0 conda-forge
libopenvino-pytorch-frontend 2025.0.0 h286801f_0 conda-forge
libopenvino-tensorflow-frontend 2025.0.0 he275e1d_0 conda-forge
libopenvino-tensorflow-lite-frontend 2025.0.0 h286801f_0 conda-forge
libopus 1.5.2 h48c0fde_0 conda-forge
libpng 1.6.47 h3783ad8_0 conda-forge
libpq 17.4 h6896619_1 conda-forge
libprotobuf 5.28.3 h3bd63a1_1 conda-forge
libptscotch 7.0.4 h5f5ebf5_2 conda-forge
librsvg 2.58.4 h266df6f_3 conda-forge
libscotch 7.0.4 h5fd1d4b_2 conda-forge
libsodium 1.0.20 h99b78c6_0 conda-forge
libsqlite 3.49.1 h3f77e49_2 conda-forge
libssh2 1.11.1 h9cc3647_0 conda-forge
libtheora 1.1.1 h99b78c6_1006 conda-forge
libtiff 4.7.0 h551f018_3 conda-forge
libusb 1.0.28 h5505292_0 conda-forge
libvorbis 1.3.7 h9f76cd9_0 conda-forge
libvpx 1.14.1 h7bae524_0 conda-forge
libwebp-base 1.5.0 h2471fea_0 conda-forge
libxcb 1.17.0 hdb1d25a_0 conda-forge
libxml2 2.13.7 h52572c6_1 conda-forge
libzip 1.11.2 h1336266_0 conda-forge
libzlib 1.3.1 h8359307_2 conda-forge
llvm-openmp 20.1.2 hdb05f8b_1 conda-forge
llvm-tools 16.0.6 hc4b4ae8_4 conda-forge
loguru 0.7.2 py310hbe9552e_2 conda-forge
lz4-c 1.10.0 h286801f_1 conda-forge
markupsafe 3.0.2 py310hc74094e_1 conda-forge
matplotlib-base 3.10.1 py310hadbac3a_0 conda-forge
matplotlib-inline 0.1.7 pyhd8ed1ab_1 conda-forge
metis 5.1.0 h15f6cfe_1007 conda-forge
mistune 3.1.3 pyh29332c3_0 conda-forge
more-itertools 10.6.0 pyhd8ed1ab_0 conda-forge
mpfr 4.2.1 hb693164_3 conda-forge
mpi 1.0 openmpi conda-forge
mpi4py 3.1.6 py310hd3bd7df_0 conda-forge
msgpack-python 1.1.0 py310h7306fd8_0 conda-forge
multidict 6.3.2 py310hdf261b0_0 conda-forge
mumps-include 5.6.2 hce30654_4 conda-forge
mumps-mpi 5.6.2 hc6b315c_4 conda-forge
munkres 1.1.4 pyh9f0ad1d_0 conda-forge
mysql-common 9.2.0 hd7719f6_0 conda-forge
mysql-libs 9.2.0 ha8be5b7_0 conda-forge
nbclient 0.10.2 pyhd8ed1ab_0 conda-forge
nbconvert-core 7.16.6 pyh29332c3_0 conda-forge
nbformat 5.10.4 pyhd8ed1ab_1 conda-forge
ncurses 6.5 h5e97a16_3 conda-forge
nest-asyncio 1.6.0 pyhd8ed1ab_1 conda-forge
nlohmann_json 3.12.0 ha1acc90_0 conda-forge
notebook 7.4.0 pyhd8ed1ab_0 conda-forge
notebook-shim 0.2.4 pyhd8ed1ab_1 conda-forge
numpy 1.26.4 py310hd45542a_0 conda-forge
openh264 2.6.0 hb5b2745_0 conda-forge
openjpeg 2.5.3 h8a3d83b_0 conda-forge
openldap 2.6.9 hbe55e7a_0 conda-forge
openmpi 4.1.6 h526c993_101 conda-forge
openssl 3.5.0 h81ee809_0 conda-forge
overrides 7.7.0 pyhd8ed1ab_1 conda-forge
packaging 24.2 pyhd8ed1ab_2 conda-forge
pandocfilters 1.5.0 pyhd8ed1ab_0 conda-forge
pango 1.56.3 h5fd7515_1 conda-forge
parmetis 4.0.3 h6eb5794_1005 conda-forge
parso 0.8.4 pyhd8ed1ab_1 conda-forge
pcre2 10.44 h297a79d_2 conda-forge
petsc 3.20.6 real_hdd9ae42_100 conda-forge
petsc4py 3.20.5 real_heb9844d_100 conda-forge
pexpect 4.9.0 pyhd8ed1ab_1 conda-forge
pickleshare 0.7.5 pyhd8ed1ab_1004 conda-forge
pillow 11.1.0 py310h61efb56_0 conda-forge
pip 25.0.1 pyh8b19718_0 conda-forge
pixman 0.44.2 h2f9eb0b_0 conda-forge
pkg-config 0.29.2 hde07d2e_1009 conda-forge
pkgutil-resolve-name 1.3.10 pyhd8ed1ab_2 conda-forge
platformdirs 4.3.7 pyh29332c3_0 conda-forge
pooch 1.8.2 pyhd8ed1ab_1 conda-forge
proj 9.5.1 h1318a7e_0 conda-forge
prometheus_client 0.21.1 pyhd8ed1ab_0 conda-forge
prompt-toolkit 3.0.51 pyha770c72_0 conda-forge
prompt_toolkit 3.0.51 hd8ed1ab_0 conda-forge
propcache 0.3.1 py310hc74094e_0 conda-forge
psutil 7.0.0 py310h078409c_0 conda-forge
pthread-stubs 0.4 hd74edd7_1002 conda-forge
ptscotch 7.0.4 hc1c4572_2 conda-forge
ptyprocess 0.7.0 pyhd8ed1ab_1 conda-forge
pugixml 1.14 h13dd4ca_0 conda-forge
pure_eval 0.2.3 pyhd8ed1ab_1 conda-forge
pybind11-abi 4 hd8ed1ab_3 conda-forge
pycparser 2.22 pyh29332c3_1 conda-forge
pygments 2.19.1 pyhd8ed1ab_0 conda-forge
pyobjc-core 11.0 py310h4e4eb3c_0 conda-forge
pyobjc-framework-cocoa 11.0 py310h4e4eb3c_0 conda-forge
pyparsing 3.2.3 pyhd8ed1ab_1 conda-forge
pysocks 1.7.1 pyha55dd90_7 conda-forge
python 3.10.17 h6cefb37_0_cpython conda-forge
python-dateutil 2.9.0.post0 pyhff2d567_1 conda-forge
python-fastjsonschema 2.21.1 pyhd8ed1ab_0 conda-forge
python-json-logger 2.0.7 pyhd8ed1ab_0 conda-forge
python_abi 3.10 6_cp310 conda-forge
pytz 2025.2 pyhd8ed1ab_0 conda-forge
pyvista 0.44.2 pyhd8ed1ab_1 conda-forge
pyyaml 6.0.2 py310hc74094e_2 conda-forge
pyzmq 26.4.0 py310h6d25ecc_0 conda-forge
qhull 2020.2 h420ef59_5 conda-forge
qt6-main 6.8.3 hca13b62_2 conda-forge
readline 8.2 h1d1bf99_2 conda-forge
referencing 0.36.2 pyh29332c3_0 conda-forge
requests 2.32.3 pyhd8ed1ab_1 conda-forge
rfc3339-validator 0.1.4 pyhd8ed1ab_1 conda-forge
rfc3986-validator 0.1.1 pyh9f0ad1d_0 conda-forge
rpds-py 0.24.0 py310h31b3829_0 conda-forge
scalapack 2.2.0 h515df86_1 conda-forge
scooby 0.10.0 pyhd8ed1ab_1 conda-forge
sdl2 2.32.54 h994913f_0 conda-forge
sdl3 3.2.10 he842692_0 conda-forge
send2trash 1.8.3 pyh31c8845_1 conda-forge
setuptools 78.1.0 pyhff2d567_0 conda-forge
sigtool 0.1.3 h44b9a77_0 conda-forge
six 1.17.0 pyhd8ed1ab_0 conda-forge
slepc 3.20.2 real_hc6ecad9_100 conda-forge
slepc4py 3.20.2 real_h60c1eb3_100 conda-forge
snappy 1.2.1 h98b9ce2_1 conda-forge
sniffio 1.3.1 pyhd8ed1ab_1 conda-forge
soupsieve 2.5 pyhd8ed1ab_1 conda-forge
sqlite 3.49.1 hd7222ec_2 conda-forge
stack_data 0.6.3 pyhd8ed1ab_1 conda-forge
suitesparse 5.10.1 h79486c6_3 conda-forge
superlu 7.0.0 h742a510_1 conda-forge
superlu_dist 8.2.1 h3dacc9e_1 conda-forge
svt-av1 3.0.2 h8ab69cd_0 conda-forge
tapi 1300.6.5 h03f4b80_0 conda-forge
tbb 2022.1.0 h9541205_0 conda-forge
terminado 0.18.1 pyh31c8845_0 conda-forge
tinycss2 1.4.0 pyhd8ed1ab_0 conda-forge
tk 8.6.13 h5083fa2_1 conda-forge
tomli 2.2.1 pyhd8ed1ab_1 conda-forge
tornado 6.4.2 py310h078409c_0 conda-forge
traitlets 5.14.3 pyhd8ed1ab_1 conda-forge
trame 3.8.2 pyhd8ed1ab_0 conda-forge
trame-client 3.7.1 pyhd8ed1ab_0 conda-forge
trame-server 3.4.0 pyhd8ed1ab_0 conda-forge
trame-vtk 2.8.15 pyhb419c8b_0 conda-forge
trame-vuetify 3.0.1 pyhd8ed1ab_0 conda-forge
types-python-dateutil 2.9.0.20241206 pyhd8ed1ab_0 conda-forge
typing-extensions 4.13.2 h0e9735f_0 conda-forge
typing_extensions 4.13.2 pyh29332c3_0 conda-forge
typing_utils 0.1.0 pyhd8ed1ab_1 conda-forge
tzdata 2025b h78e105d_0 conda-forge
unicodedata2 16.0.0 py310h078409c_0 conda-forge
uri-template 1.3.0 pyhd8ed1ab_1 conda-forge
urllib3 2.4.0 pyhd8ed1ab_0 conda-forge
utfcpp 4.0.6 h54c0426_0 conda-forge
vtk 9.3.1 qt_py310he4b582b_215 conda-forge
vtk-base 9.3.1 qt_py310h9cd0699_215 conda-forge
vtk-io-ffmpeg 9.3.1 qt_py310he4b582b_215 conda-forge
wcwidth 0.2.13 pyhd8ed1ab_1 conda-forge
webcolors 24.11.1 pyhd8ed1ab_0 conda-forge
webencodings 0.5.1 pyhd8ed1ab_3 conda-forge
websocket-client 1.8.0 pyhd8ed1ab_1 conda-forge
wheel 0.45.1 pyhd8ed1ab_1 conda-forge
widgetsnbextension 4.0.14 pyhd8ed1ab_0 conda-forge
wslink 2.3.3 pyhd8ed1ab_0 conda-forge
x264 1!164.3095 h57fd34a_2 conda-forge
x265 3.5 hbc6ce65_3 conda-forge
xorg-libxau 1.0.12 h5505292_0 conda-forge
xorg-libxdmcp 1.1.5 hd74edd7_0 conda-forge
xz 5.8.1 h9a6d368_0 conda-forge
xz-gpl-tools 5.8.1 h9a6d368_0 conda-forge
xz-tools 5.8.1 h39f12f2_0 conda-forge
yaml 0.2.5 h3422bc3_2 conda-forge
yarl 1.18.3 py310hc74094e_1 conda-forge
zeromq 4.3.5 hc1bb282_7 conda-forge
zfp 0.5.5 hcfdfaf5_8 conda-forge
zipp 3.21.0 pyhd8ed1ab_1 conda-forge
zstandard 0.23.0 py310h078409c_1 conda-forge
zstd 1.5.7 h6491c7d_2 conda-forge
Any help is highly appreciated!
Thanks,
Tom
