Not getting the desired coordinates of the submesh
I am creating a sub mesh by marking the subdomains. Following code I am using for this
mesh = UnitSquareMesh(2, 2)
class Left(SubDomain):
        return (x[0] < DOLFIN_EPS) and on_boundary
sub_domains = MeshFunction("size_t", mesh, mesh.topology().dim()-1)
left = Left()
sub_domains.set_all(0)
left.mark(sub_domains, 1)
sub_mesh = SubMesh(mesh, sub_domains, 1)
# coordinates of the sub mesh
sub_mesh.coordinates()
I am getting the following coordinates (0,0), (0,0.5), (0.5, 0.5) while in the original mesh, this subdomain has the mesh coordinates (0,0), (0,0.5),(0,1) .
Why is this happening? Is there any problem with my code?
SubMesh is not made for meshes of co-dimension 1 (i.e. facets).
You can check this by print(submesh.topology().dim()).
To create a submesh of facets, either use BoundaryMesh or MeshView.
Personally, I would advice you to move to DOLFINx, as the support for these kind of operations have been vastly improved (on main branch).
Thanks, Now it is woking fine. Can we solve an ordinary differential equation on this boundary mesh?
There are several example of this.
In legacy fenics you can use pointintegral solver. In dolfinx I would go a slightly different route, and use external software such as gotranx by @Henrik_Nicolay_Finsb (GitHub - finsberg/gotranx: Next generation ODE translator) and use it with external operator by @a-latyshev GitHub - a-latyshev/dolfinx-external-operator: Extension of DOLFINx implementing the concept of external operator
