Oasisx splitting scheme does not yield the 'right' result (?)
Dear all,
I am confused about the implementation of Adams Bashforth methods this Fenics tutorial on splitting schemes. See Section “Navier-Stokes equation”:
[…] and the convective term B_k^{n-\frac{1}{2}}=\mathbf{\bar{u}}\cdot \nabla \tilde u_k = (1.5 \mathbf{u}^{n-1}-0.5\mathbf{u}^{n-2})\cdot \nabla \tilde u_k is the implicit Adams-Bashforth discretization.
I implemented the splitting scheme in minimal_working_example.py (attached), which runs properly:
import math
# from dolfin import *
import ufl as ufl
#geometric parameters
L = 2.2
h = 0.41
r = 0.05
c_r = [0.2, 0.2]
# Create mesh
channel = Rectangle(Point(0, 0), Point(2.2, 0.41))
cylinder = Circle(Point(0.2, 0.2), 0.05)
domain = channel - cylinder
mesh = generate_mesh(domain, 64)
# Define function spaces
#the '2' in ''P', 2)' is the order of the polynomials used to describe these spaces: if they are low, then derivatives high enough of the functions projected on thee spaces will be set to zero !
O = VectorFunctionSpace(mesh, 'P', 2, dim=2)
O3d = VectorFunctionSpace(mesh, 'P', 2, dim=3)
Q = FunctionSpace(mesh, 'P', 1)
#I will use Q4 for functions which involve high order derivatives
Q4 = FunctionSpace(mesh, 'P', 4)
# Define boundaries and obstacle
inflow   = 'near(x[0], 0)'
outflow  = 'near(x[0], 2.2)'
walls    = 'near(x[1], 0) || near(x[1], 0.41)'
cylinder = 'on_boundary && x[0]>0.1 && x[0]<0.3 && x[1]>0.1 && x[1]<0.3'
#v[i] = v^i_{notes} (tangential velocity)
v = TrialFunction(O)
nu = TestFunction(O)
p = TrialFunction(Q)
q = TestFunction(Q)
#definition of scalar, vectorial and tensorial quantities
#latin indexes run on 2d curvilinear coordinates
i, j, k, l = ufl.indices(4)
#the normal vector on the inflow and outflow
def n_inout():
    u = as_tensor([conditional(lt(x[0], L/2), -1.0, 1.0), 0.0] )
    return as_tensor(u[k], (k))
T = 1.0
num_steps = 1024
dt = T / num_steps  # time step size
# the Reynolds number, Re = \rho U l / \mu, Re_here = R_{notes fenics}
# Re = 1E3
mu = 0.001
print("c_r = ", c_r)
print("L = ", L)
print("h = ", h)
print("r = ", r)
print("T = ", T)
print("N = ", num_steps)
print("mu = ", mu)
# Create XDMF files for visualization output
xdmffile_v = XDMFFile("v.xdmf")
xdmf_file_p = XDMFFile("p.xdmf")
# Create time series (for use in reaction_system.py)
timeseries_v = TimeSeries("v_series")
timeseries_p = TimeSeries("p_series")
# Define functions for solutions at previous and current time steps
#this is v_{n-1}
v_n_1 = Function(O)
#this is v_{n-2}
v_n_2 = Function(O)
v_sav = Function(O)
v_ = Function(O)
#this is p_{n-1}
p_n_1 = Function(Q)
#this is p_{n-2}
p_n_2 = Function(Q)
p_ = Function(Q)
inflow_profile = ('4.0*1.5*x[1]*(0.41 - x[1]) / pow(0.41, 2)', '0')
bcv_inflow = DirichletBC(O, Expression(inflow_profile, degree=2), inflow)
bcv_walls = DirichletBC(O, Constant((0, 0)), walls)
bcv_cylinder = DirichletBC(O, Constant((0, 0)), cylinder)
bcp_outflow = DirichletBC(Q, Constant(0), outflow)
bc_v = [bcv_walls, bcv_cylinder, bcv_inflow]
bc_p = [bcp_outflow]
V = 0.5 * (v_n_1 + v)
Deltat = Constant(dt)
mu = Constant(mu)
# Define variational problem for step 1
# step 1 for v
#CHOICE 1
# F1v = (dot((v - v_n_1) / Deltat, nu) \
#               + (( 3.0/2.0 * v_n_1[j] * ((v_n_1[i]).dx(j)) - 1.0/2.0 * v_n_2[j] * ((v_n_2[i]).dx(j)) ) * nu[i]) \
#             ) * dx \
#       + ( - ((nu[i]).dx(i)) * (p_n_1 + p_n_2) / 2.0 +  mu * ((V[i]).dx(j) + (V[j]).dx(i) ) * ((nu[i]).dx(j)) ) * dx \
#       + ( (p_n_1 + p_n_2) / 2.0 * nu[i] * ((n_inout())[i]) - mu *  ( 0 * (V[i]).dx(j) + (V[j]).dx(i) ) * nu[i] * ((n_inout())[j]) ) * ds
#CHOICE 2
              + (( 3.0/2.0 * v_n_1[j]  - 1.0/2.0 * v_n_2[j] ) * ((V[i]).dx(j))  * nu[i]) \
            ) * dx \
a1v = lhs(F1v)
L1v = rhs(F1v)
# step 2
F2 = ( \
        - (( 1.0/2.0*(p - p_n_2)  + mu * (v_[j]).dx(j) ).dx(i)) * (q.dx(i)) \
        - (1.0 / Deltat) * (v_[i]).dx(i) * q \
    ) * dx
    #THERE WOULD BE AN ADDITIONAL TERM ~  <q grad phi n>_{\partial \Omega} WHICH IS ZERO BECAUSE WE ASSUME THAT ON THE BOUNDARIES WHERE v IS SPECIFIED, WE HAVE d phi / d n  = 0
a2 = lhs(F2)
L2 = rhs(F2)
# step 3 for v
F3v = (dot(v - v_ , nu) + Deltat * dot(grad( 1.0/2.0*(p_ - p_n_2) + mu*div(v_) ), nu)) * dx
a3v = lhs(F3v)
L3v = rhs(F3v)
# Assemble matrices
A1v = assemble(a1v)
A2 = assemble(a2)
A3v = assemble(a3v)
# Apply boundary conditions to matrices
[bc.apply(A1v) for bc in bc_v]
[bc.apply(A2) for bc in bc_p]
print("Starting time iteration ...", flush=True)
# Time-stepping
t = 0
for n in range(num_steps):
    # Write the solution to file
    xdmffile_v.write(v_n_1, t)
    xdmf_file_p.write(p_n_1, t)
    # Save nodal values to file
    timeseries_v.store(v_n_1.vector(), t)
    timeseries_p.store(p_n_1.vector(), t)
    # Update current time
    # step 1 for v
    b1v = assemble(L1v)
    [bc.apply(b1v) for bc in bc_v]
    # this line solves for v^* and stores v^* in v_
    solve(A1v, v_.vector(), b1v, 'bicgstab', 'hypre_amg')
    # Step 2: surface_tension correction step
    b2 = assemble(L2)
    [bc.apply(b2) for bc in bc_p]
    # this step solves for p^{n+1} and stores the solution in p_
    solve(A2, p_.vector(), b2, 'bicgstab', 'hypre_amg')
    #compute v_n = v_{n-1}_{at the next step}
    b3v = assemble(L3v)
    solve(A3v, v_sav.vector(), b3v, 'cg', 'sor')
    v_n_2.assign(v_n_1)
    v_n_1.assign(v_sav)
    p_n_2.assign(p_n_1)
    p_n_1.assign(p_)
    print("\t%.2f %%" % (100.0 * (t / T)), flush=True)
print("... done.", flush=True)
If I implement the exact same scheme as indicated in the webpage (Choice 2), the functional for the first step reads
#CHOICE 2
              + (( 3.0/2.0 * v_n_1[j]  - 1.0/2.0 * v_n_2[j] ) * ((V[i]).dx(j))  * nu[i]) ) * dx + [...]
This does not yield the same result as this Fenics sample code, for the exact same geometry and simulation parameters, nor it reproduces the turbulend, oscillatory wake behind the cylinder, but a laminar wake. The result of Choice 2 at t = 1 is shown in the image choice 2.png attached
On the other hand, I implemented the explicit Adams-Bashforth method as shown here (Choice 2). This follows the prescription of setting y_{n+1} = y_n + \Delta t [3/2 f(y_n)-1/2 f(y_{n-1})] for an ODE as d y/dt = f(y).
#CHOICE 1
            ) * dx [...]
With choice 1, I do obtan the oscillatory, turbulent wake and the results of choice 1 agree quantitatively with those the Fenics sample code, and they are shown in choice 1.png
Why? I wonder whether the term B_k^{n-\frac{1}{2}}=\mathbf{\bar{u}}\cdot \nabla \tilde u_k = (1.5 \mathbf{u}^{n-1}-0.5\mathbf{u}^{n-2})\cdot \nabla \tilde u_k is correct.
Than you for your help ! :blush:
The mesh is way too coarse for the flow to be properly resolved.
One thing you should compare is the pressure difference and drag or lift.
Here is a code using your coarse mesh:
# Create mesh
with XDMFFile("mesh.xdmf") as xdmf:
    xdmf.write(mesh)
Using in with the code from the dolfinx tutorial (no modifications to the splitting scheme, only to reading in the mesh), yields
# # Test problem 2: Flow past a cylinder (DFG 2D-3 benchmark)
# Author: Jørgen S. Dokken
# In this section, we will turn our attention to a slightly more challenging problem: flow past a cylinder. The geometry and parameters are taken from the [DFG 2D-3 benchmark](https://www.featflow.de/en/benchmarks/cfdbenchmarking/flow/dfg_benchmark3_re100.html) in FeatFlow.
# To be able to solve this problem efficiently and ensure numerical stability, we will substitute our first order backward difference scheme with a Crank-Nicholson discretization in time, and a semi-implicit Adams-Bashforth approximation of the non-linear term.
# ```{admonition} Computationally demanding demo
# This demo is computationally demanding, with a run-time up to 15 minutes, as it is using parameters from the DFG 2D-3 benchmark, which consists of 12800 time steps. It is adviced to download this demo and  not run it in a browser. This runtime of the demo can be increased by using 2 or 3 mpi processes.
# The computational geometry we would like to use is
# ![Fluid channel with a circular obstacle](turek.png)
# The kinematic velocity is given by $\nu=0.001=\frac{\mu}{\rho}$ and the inflow velocity profile is specified as
#     u(x,y,t) = \left( \frac{4Uy(0.41-y)}{0.41^2}, 0 \right)
#     U=U(t) = 1.5\sin(\pi t/8)
# which has a maximum magnitude of $1.5$ at $y=0.41/2$. We do not use any scaling for this problem since all exact parameters are known.
# ## Mesh generation
# As in the [Deflection of a membrane](./../chapter1/membrane_code.ipynb) we use GMSH to generate the mesh. We fist create the rectangle and obstacle.
import os
import tqdm.autonotebook
from basix.ufl import element
from dolfinx.fem import (
    Constant,
    Function,
    functionspace,
    assemble_scalar,
    dirichletbc,
    form,
    locate_dofs_topological,
    set_bc,
from dolfinx.fem.petsc import (
    apply_lifting,
    assemble_matrix,
    assemble_vector,
    create_vector,
    create_matrix,
    set_bc,
from dolfinx.mesh import exterior_facet_indices, locate_entities_boundary, meshtags
from dolfinx.geometry import bb_tree, compute_collisions_points, compute_colliding_cells
from dolfinx.io import VTXWriter, XDMFFile
from ufl import (
    FacetNormal,
    Measure,
    TestFunction,
    TrialFunction,
    as_vector,
    div,
    dot,
    dx,
    inner,
    lhs,
    grad,
    nabla_grad,
    rhs,
with XDMFFile(MPI.COMM_WORLD, "mesh.xdmf", "r") as xdmf:
    mesh = xdmf.read_mesh(name="mesh")
gdim = mesh.geometry.dim
fdim = mesh.topology.dim - 1
mesh.topology.create_connectivity(fdim, fdim + 1)
num_facets = (
    mesh.topology.index_map(fdim).size_local + mesh.topology.index_map(fdim).num_ghosts
inlet_marker, outlet_marker, wall_marker, obstacle_marker = 2, 3, 4, 5
facets = np.arange(num_facets, dtype=np.int32)
values = np.zeros_like(facets)
values[exterior_facet_indices(mesh.topology)] = obstacle_marker
values[locate_entities_boundary(mesh, fdim, lambda x: np.isclose(x[0], 0))] = (
    inlet_marker
values[locate_entities_boundary(mesh, fdim, lambda x: np.isclose(x[0], 2.2))] = (
    outlet_marker
values[
        mesh, fdim, lambda x: np.isclose(x[1], 0) | np.isclose(x[1], 0.41)
] = wall_marker
ft = meshtags(mesh, fdim, facets, values)
t = 0
T = 8  # Final time
dt = 1 / 1600  # Time step size
num_steps = int(T / dt)
mu = Constant(mesh, PETSc.ScalarType(0.001))  # Dynamic viscosity
rho = Constant(mesh, PETSc.ScalarType(1))  # Density
# ```{admonition} Reduced end-time of problem
# In the current demo, we have reduced the run time to one second to make it easier to illustrate the concepts of the benchmark. By increasing the end-time `T` to 8, the runtime in a notebook is approximately 25 minutes. If you convert the notebook to a python file and use `mpirun`, you can reduce the runtime of the problem.
# ## Boundary conditions
# As we have created the mesh and relevant mesh tags, we can now specify the function spaces `V` and `Q` along with the boundary conditions. As the `ft` contains markers for facets, we use this class to find the facets for the inlet and walls.
v_cg2 = element("Lagrange", mesh.topology.cell_name(), 2, shape=(mesh.geometry.dim,))
s_cg1 = element("Lagrange", mesh.topology.cell_name(), 1)
V = functionspace(mesh, v_cg2)
Q = functionspace(mesh, s_cg1)
# Define boundary conditions
class InletVelocity:
    def __init__(self, t):
        self.t = t
    def __call__(self, x):
        values = np.zeros((gdim, x.shape[1]), dtype=PETSc.ScalarType)
        values[0] = (
            4 * 1.5 * np.sin(self.t * np.pi / 8) * x[1] * (0.41 - x[1]) / (0.41**2)
        return values
# Inlet
u_inlet = Function(V)
inlet_velocity = InletVelocity(t)
u_inlet.interpolate(inlet_velocity)
bcu_inflow = dirichletbc(
    u_inlet, locate_dofs_topological(V, fdim, ft.find(inlet_marker))
# Walls
u_nonslip = np.array((0,) * mesh.geometry.dim, dtype=PETSc.ScalarType)
bcu_walls = dirichletbc(
    u_nonslip, locate_dofs_topological(V, fdim, ft.find(wall_marker)), V
# Obstacle
bcu_obstacle = dirichletbc(
    u_nonslip, locate_dofs_topological(V, fdim, ft.find(obstacle_marker)), V
bcu = [bcu_inflow, bcu_obstacle, bcu_walls]
# Outlet
bcp_outlet = dirichletbc(
    PETSc.ScalarType(0), locate_dofs_topological(Q, fdim, ft.find(outlet_marker)), Q
bcp = [bcp_outlet]
# ## Variational form
# As opposed to [Pouseille flow](./ns_code1.ipynb), we will use a Crank-Nicolson discretization, and an semi-implicit Adams-Bashforth approximation.
# The first step can be written as
# \rho\left(\frac{u^*- u^n}{\delta t} + \left(\frac{3}{2}u^{n} - \frac{1}{2} u^{n-1}\right)\cdot \frac{1}{2}\nabla (u^*+u^n) \right) - \frac{1}{2}\mu \Delta( u^*+ u^n )+ \nabla p^{n-1/2} = f^{n+\frac{1}{2}} \qquad \text{ in } \Omega
# u^{*}=g(\cdot, t^{n+1}) \qquad \text{ on } \partial \Omega_{D}
# \frac{1}{2}\nu \nabla (u^*+u^n) \cdot n = p^{n-\frac{1}{2}} \qquad \text{ on } \partial \Omega_{N}
# where we have used the two previous time steps in the temporal derivative for the velocity, and compute the pressure staggered in time, at the time between the previous and current solution. The second step becomes
# \nabla \phi = -\frac{\rho}{\delta t} \nabla \cdot u^* \qquad\text{in } \Omega,
# \nabla \phi \cdot n = 0 \qquad \text{on } \partial \Omega_D,
# \phi = 0 \qquad\text{on } \partial\Omega_N
# where $p^{n+\frac{1}{2}}=p^{n-\frac{1}{2}} + \phi$.
# Finally, the third step is
# \rho (u^{n+1}-u^{*}) = -\delta t \nabla\phi.
# We start by defining all the variables used in the variational formulations.
u_ = Function(V)
u_.name = "u"
u_s = Function(V)
u_n = Function(V)
u_n1 = Function(V)
q = TestFunction(Q)
p_ = Function(Q)
p_.name = "p"
phi = Function(Q)
# Next, we define the variational formulation for the first step, where we have integrated the diffusion term, as well as the pressure term by parts.
f = Constant(mesh, PETSc.ScalarType((0, 0)))
F1 = rho / k * dot(u - u_n, v) * dx
F1 += inner(dot(1.5 * u_n - 0.5 * u_n1, 0.5 * nabla_grad(u + u_n)), v) * dx
F1 += 0.5 * mu * inner(grad(u + u_n), grad(v)) * dx - dot(p_, div(v)) * dx
F1 += dot(f, v) * dx
a1 = form(lhs(F1))
L1 = form(rhs(F1))
A1 = create_matrix(a1)
b1 = create_vector(L1)
# Next we define the second step
a2 = form(dot(grad(p), grad(q)) * dx)
L2 = form(-rho / k * dot(div(u_s), q) * dx)
A2.assemble()
b2 = create_vector(L2)
# We finally create the last step
a3 = form(rho * dot(u, v) * dx)
L3 = form(rho * dot(u_s, v) * dx - k * dot(nabla_grad(phi), v) * dx)
A3 = assemble_matrix(a3)
A3.assemble()
b3 = create_vector(L3)
# As in the previous tutorials, we use PETSc as a linear algebra backend.
# Solver for step 1
solver1 = PETSc.KSP().create(mesh.comm)
solver1.setOperators(A1)
pc1 = solver1.getPC()
pc1.setType(PETSc.PC.Type.JACOBI)
# Solver for step 2
solver2 = PETSc.KSP().create(mesh.comm)
solver2.setOperators(A2)
solver2.setType(PETSc.KSP.Type.MINRES)
pc2 = solver2.getPC()
pc2.setHYPREType("boomeramg")
# Solver for step 3
solver3 = PETSc.KSP().create(mesh.comm)
solver3.setOperators(A3)
pc3 = solver3.getPC()
# ## Verification of the implementation compute known physical quantities
# As a further verification of our implementation, we compute the drag and lift coefficients over the obstacle, defined as
#     C_{\text{D}}(u,p,t,\partial\Omega_S) = \frac{2}{\rho L U_{mean}^2}\int_{\partial\Omega_S}\rho \nu n \cdot \nabla u_{t_S}(t)n_y -p(t)n_x~\mathrm{d} s,
#     C_{\text{L}}(u,p,t,\partial\Omega_S) = -\frac{2}{\rho L U_{mean}^2}\int_{\partial\Omega_S}\rho \nu n \cdot \nabla u_{t_S}(t)n_x + p(t)n_y~\mathrm{d} s,
# where $u_{t_S}$ is the tangential velocity component at the interface of the obstacle $\partial\Omega_S$, defined as $u_{t_S}=u\cdot (n_y,-n_x)$, $U_{mean}=1$ the average inflow velocity, and $L$ the length of the channel. We use `UFL` to create the relevant integrals, and assemble them at each time step.
n = -FacetNormal(mesh)  # Normal pointing out of obstacle
dObs = Measure("ds", domain=mesh, subdomain_data=ft, subdomain_id=obstacle_marker)
u_t = inner(as_vector((n[1], -n[0])), u_)
drag = form(2 / 0.1 * (mu / rho * inner(grad(u_t), n) * n[1] - p_ * n[0]) * dObs)
lift = form(-2 / 0.1 * (mu / rho * inner(grad(u_t), n) * n[0] + p_ * n[1]) * dObs)
if mesh.comm.rank == 0:
    C_D = np.zeros(num_steps, dtype=PETSc.ScalarType)
    C_L = np.zeros(num_steps, dtype=PETSc.ScalarType)
    t_u = np.zeros(num_steps, dtype=np.float64)
    t_p = np.zeros(num_steps, dtype=np.float64)
# We will also evaluate the pressure at two points, one in front of the obstacle, $(0.15, 0.2)$, and one behind the obstacle, $(0.25, 0.2)$. To do this, we have to find which cell contains each of the points, so that we can create a linear combination of the local basis functions and coefficients.
tree = bb_tree(mesh, mesh.geometry.dim)
points = np.array([[0.15, 0.2, 0], [0.25, 0.2, 0]])
cell_candidates = compute_collisions_points(tree, points)
colliding_cells = compute_colliding_cells(mesh, cell_candidates, points)
front_cells = colliding_cells.links(0)
back_cells = colliding_cells.links(1)
    p_diff = np.zeros(num_steps, dtype=PETSc.ScalarType)
# ## Solving the time-dependent problem
# ```{admonition} Stability of the Navier-Stokes equation
# Note that the current splitting scheme has to fullfil the a [Courant–Friedrichs–Lewy condition](https://en.wikipedia.org/wiki/Courant%E2%80%93Friedrichs%E2%80%93Lewy_condition). This limits the spatial discretization with respect to the inlet velocity and temporal discretization.
# Other temporal discretization schemes such as the second order backward difference discretization or Crank-Nicholson discretization with Adams-Bashforth linearization are better behaved than our simple backward difference scheme.
# As in the previous example, we create output files for the velocity and pressure and solve the time-dependent problem. As we are solving a time dependent problem with many time steps, we use the `tqdm`-package to visualize the progress. This package can be installed with `pip3`.
from pathlib import Path
folder = Path("results")
folder.mkdir(exist_ok=True, parents=True)
vtx_u = VTXWriter(mesh.comm, "dfg2D-3-u.bp", [u_], engine="BP4")
vtx_p = VTXWriter(mesh.comm, "dfg2D-3-p.bp", [p_], engine="BP4")
vtx_u.write(t)
vtx_p.write(t)
progress = tqdm.autonotebook.tqdm(desc="Solving PDE", total=num_steps)
for i in range(num_steps):
    progress.update(1)
    # Update current time step
    # Update inlet velocity
    inlet_velocity.t = t
    A1.zeroEntries()
    assemble_matrix(A1, a1, bcs=bcu)
    A1.assemble()
    with b1.localForm() as loc:
        loc.set(0)
    assemble_vector(b1, L1)
    set_bc(b1, bcu)
    solver1.solve(b1, u_s.vector)
    u_s.x.scatter_forward()
    # Step 2: Pressure corrrection step
    with b2.localForm() as loc:
        loc.set(0)
    assemble_vector(b2, L2)
    set_bc(b2, bcp)
    solver2.solve(b2, phi.vector)
    phi.x.scatter_forward()
    p_.vector.axpy(1, phi.vector)
    p_.x.scatter_forward()
    with b3.localForm() as loc:
        loc.set(0)
    assemble_vector(b3, L3)
    solver3.solve(b3, u_.vector)
    u_.x.scatter_forward()
    # Write solutions to file
    vtx_u.write(t)
    vtx_p.write(t)
    with u_.vector.localForm() as loc_, u_n.vector.localForm() as loc_n, u_n1.vector.localForm() as loc_n1:
        loc_n.copy(loc_n1)
        loc_.copy(loc_n)
    # Compute physical quantities
    # For this to work in paralell, we gather contributions from all processors
    # to processor zero and sum the contributions.
    drag_coeff = mesh.comm.gather(assemble_scalar(drag), root=0)
    lift_coeff = mesh.comm.gather(assemble_scalar(lift), root=0)
    p_front = None
    if len(front_cells) > 0:
        p_front = p_.eval(points[0], front_cells[:1])
    p_front = mesh.comm.gather(p_front, root=0)
    p_back = None
    if len(back_cells) > 0:
        p_back = p_.eval(points[1], back_cells[:1])
    p_back = mesh.comm.gather(p_back, root=0)
        t_u[i] = t
        t_p[i] = t - dt / 2
        C_D[i] = sum(drag_coeff)
        C_L[i] = sum(lift_coeff)
        # Choose first pressure that is found from the different processors
        for pressure in p_front:
            if pressure is not None:
                p_diff[i] = pressure[0]
                break
        for pressure in p_back:
                p_diff[i] -= pressure[0]
                break
vtx_u.close()
vtx_p.close()
# ## Verification using data from FEATFLOW
# As FEATFLOW has provided data for different discretization levels, we compare our numerical data with the data provided using `matplotlib`.
    if not os.path.exists("figures"):
        os.mkdir("figures")
    num_velocity_dofs = V.dofmap.index_map_bs * V.dofmap.index_map.size_global
    num_pressure_dofs = Q.dofmap.index_map_bs * V.dofmap.index_map.size_global
    turek = np.loadtxt("bdforces_lv4")
    turek_p = np.loadtxt("pointvalues_lv4")
    fig = plt.figure(figsize=(25, 8))
    l1 = plt.plot(
        t_u,
        C_D,
        label=r"FEniCSx  ({0:d} dofs)".format(num_velocity_dofs + num_pressure_dofs),
        linewidth=2,
    l2 = plt.plot(
        turek[1:, 1],
        turek[1:, 3],
        marker="x",
        markevery=50,
        linestyle="",
        markersize=4,
        label="FEATFLOW (42016 dofs)",
    plt.title("Drag coefficient")
    plt.grid()
    plt.legend()
    plt.savefig("figures/drag_comparison.png")
    l1 = plt.plot(
        t_u,
        C_L,
        linewidth=2,
    l2 = plt.plot(
        turek[1:, 1],
        turek[1:, 4],
        marker="x",
        markevery=50,
        linestyle="",
        markersize=4,
    plt.title("Lift coefficient")
    plt.grid()
    plt.legend()
    plt.savefig("figures/lift_comparison.png")
    l1 = plt.plot(
        t_p,
        p_diff,
        linewidth=2,
    l2 = plt.plot(
        turek[1:, 1],
        turek_p[1:, 6] - turek_p[1:, -1],
        marker="x",
        markevery=50,
        linestyle="",
        markersize=4,
    plt.title("Pressure difference")
    plt.grid()
    plt.legend()
    plt.savefig("figures/pressure_comparison.png")
with the following flow (at the end time T=8):
and comparisons
Indicating that the mesh is too coarse.
I am not going to debug your full code to find the differences.
Using a constant inflow profile, as in the old tutorial,changing T=5
and the inlet profile to
        self.t = t
        values[0] = 4 * 1.5 * x[1] * (0.41 - x[1]) / (0.41**2)
        return values
yields
at time equal to 1, so I think you have done something wrong in your implementation.
It is unclear what code you have actually used to reproduce the turbulent wake at t = 1: may you please post it ?
Also, please consider that if one follows the procedure in Oasisx webpage, an additional term appears which is not present in the webpage. Yes, it is negligible compared to the term 1/\Delta t to which it is summed, but, if this is the reason why it is neglected, it should be stated clearly.
The code above, where i changed the time dependent inlet to a time independent inlet.
I pointed to the two changes in my previous post.
Sure, it should be stated, as it is the case that it is neglected for that reason. Feel free to make an issue.
Please bear in mind that i maintain these docs to help people. It is not a textbook or published article. I’ve just tried to gather information from various papers to make it easier for people to understand splitting schemes. I will post a comment in the other post wrt the additional term
I don’t see why in the comment in your code you write
while it should be \nabla \phi = +\frac{\rho}{\delta t} \nabla \cdot u^* . However, you got the right sign in the weak formulation
so it may just be an error in the comment.
Here \Delta should be \nabla.
Thank you for this detailed reply, I am looking into it!
I’ve corrected the equation (as it was also missing \nabla^2 \phi for the Laplacian on the LHS of that equation).
Ref: Pressure correction equation fix by jorgensd · Pull Request #196 · jorgensd/dolfinx-tutorial · GitHub
No? It could be written as \nabla^2 or as \Delta to denote the Laplace operator.
Oh sorry \Delta is the Latex symbol for the inverted triangle
In your code, the velocity velocity profile oscillates in time (see the \sin(t \pi/8)), so your code is different with respect to the Fenics example as well as from my code, where there is no oscillation.
Do you get the oscillating, turbulent wake by using the same inflow profile as in the Fenics example?
As I stated above, yes, i replaced the oscillating flow with:
which is time-independent to get the latter picture:
Oh I see, thank you.
I found out what was wrong with my code:
I reproduce your results if I add, at every time iteration
    A1v = assemble(a1v)
As far as I understand, this is necessary with this formulation because, now that the functional in the weak formulation reads
F_1 = \langle \left( \frac{3}{2} u^{n-1}_j - \frac{1}{2} u^{n-2}_j \right) \partial_j \frac{u^*_i + u^{n-1}_i}{2}\rangle + \cdots
when this problem is transformed into a linear-algebra problem such as solving for the vector \bf x, which represents \bf u^\ast, the equation A \cdot \bf x = \bf b, now the matrix A will depend on u^n, so it needs to be re-computed at every time step.
Is it something along these lines?
Best,
Yes, a1v has to be re-assembled as it depends on the previous time steps.
