Operands could not be broadcast together with shapes. How can we address this problem
 t1 = 0
 for (i, t) in enumerate(T[1:]):
     print("t = %g" % (t))
     eps0t.t=t
     dt=t-t1
     K1 = inner(sigma_0(du,alpha),eps(v))*dx-inner(((1-alpha)**2+Constant(1e-6))*
     (lmbda*tr(eps0)*Identity(ndim)),eps(v))*dx
     a, L = lhs(K1), rhs(K1)
     a_M = rho*inner(du,v)*dx
     M = lhs(a_M)
     solve(a+M == L, Accel, bcs)
     A           = M+betaN*dt*dt*a
     UN1T=UN0+dt*DUN0+(1./2.-betaN)*dt*dt*Accel
     DUN1T=DUN0+(1.-gamma)*dt*Accel
      K           = assemble(a)
      KK = K.array()
314 b = KK*UN1T
solve(A==L+b, Accel,bcs)
**Error message **
line 314, in
b = KK*UN1T
ValueError: operands could not be broadcast together with shapes (14760,14760) (2,)
You need to provide a minimal reproducable example, i.e. a code that reproduces the error message you are receiving.
t1 = 0
V_u=VectorFunctionSpace(mesh, "CG", 1)
UN1T=Function(V_u)
     eps0t.t=t
     dt=t-t1
     M = lhs(a_M)
     A           = M+betaN*dt*dt*a
      K           = assemble(a)
      KK = K.array()
      b = KK*UN1T
      résoudre(A==L+b, Accel,bcs)
This error comes from this code that I put above. especially at the level of b = KK*UN1T.
Your problem is not reproducible, as it cannot be copy pasted to another computer and then be executed. Please make sure all variables in your code are defined, and that the problem is as small as possible.
