Hello everyone,
I am trying to adapt the example “Optimal control in DOLFINx interfacing with scipy” (Optimal control in DOLFINx interfacing with scipy — FEniCS Workshop) to solve an inverse problem in hyperelasticity.
I am having the following issue: ufl.algorithms.check_arities.ArityMismatch: Applying nonlinear operator Exp to expression depending on form argument v_0.
I know where it does come from, but have no clue how to fix it, since it is the expression of the nonlinear forward problem.
The error appears when I am trying to create the adjoint problem:
adj_problem = LinearSolver(ufl.replace(dFdu_adj, {uh: v}), -dJdu, lmbda, bcs)
Below is a piece of code (I cleaned a little bit):
domain = dolfinx.mesh.create_unit_cube(MPI.COMM_WORLD, 8, 8, 8, mesh.CellType.hexahedron)
ud = prob_hiperelastico(domain)
V = dolfinx.fem.functionspace(domain, ("Lagrange", 1, (domain.geometry.dim,)))
W = dolfinx.fem.functionspace(domain, ("Lagrange", 1,))
du = ufl.TrialFunction(V)
uh = dolfinx.fem.Function(V)
# Equacao de Estado (Fun)
def left(x):
return np.isclose(x[0], 0)
def right(x):
return np.isclose(x[0], 1)
# Concatenate and sort the arrays based on facet indices. Left facets marked with 1, right facets with two
marked_values = np.hstack([np.full_like(left_facets, 1), np.full_like(right_facets, 2)])
facet_tag = mesh.meshtags(domain, fdim, marked_facets[sorted_facets], marked_values[sorted_facets])
u_bc = np.array((0,) * domain.geometry.dim, dtype=default_scalar_type)
left_dofs = fem.locate_dofs_topological(V, facet_tag.dim, facet_tag.find(1))
bcs = [fem.dirichletbc(u_bc, left_dofs, V)]
# Kinematics
# Spatial dimension
d = len(uh)
# Identity tensor
I = ufl.variable(ufl.Identity(d))
# Deformation gradient
F = ufl.variable(I + ufl.grad(uh))
J = ufl.variable(ufl.det(F))
# Right Cauchy-Green tensor
C = ufl.variable(F.T * F)
E = 0.5*(C - I)
f0 = as_vector([ 1.0, 0.0, 0.0 ])
s0 = as_vector([ 0.0, 1.0, 0.0 ])
n0 = as_vector([ 0.0, 0.0, 1.0 ])
# Constitutive model
def ctrue_expr(x):
return 4.0 - 3.8 * ((x[0] - 0.7)**2 + (x[1] - 0.5)**2 + (x[2] - 0.5)**2 < 0.3**2)
Va = fem.functionspace(domain, ("Lagrange", 1))
cj_true = fem.Function(Va)
cj_true.interpolate(ctrue_expr)
# C = default_scalar_type(2.0)
CC = cj_true
bf = default_scalar_type(8.0)
bt = default_scalar_type(2.0)
bfs = default_scalar_type(4.0)
e1 = f0
e2 = s0
e3 = n0
kappa = 1e2
kappa = fem.Constant(domain,kappa)
Cs = J**(-2/3) * F.T * F
Es = 0.5 * (Cs - I)
E11 = ufl.inner(Es*e1, e1)
Q = bf*E11**2
# energia
Wpassive = CC/2.0 * (ufl.exp(Q) - 1)
Wactive = 0.0
Wincompr = kappa * (J*ufl.ln(J) - J + 1)
strain_energy = Wpassive + Wactive + Wincompr
P = ufl.diff(strain_energy, F)
p_right = fem.Constant(domain,0.0)
ds = ufl.Measure('ds', domain=domain, subdomain_data=facet_tag, metadata=metadata)
# Definition of the weak form:
N = ufl.FacetNormal(domain)
Gext = -p_right * ufl.inner(v, det(F) * ufl.inv(F) * N) * ds(2) #ds(2) = right boundary
# forward prob
Fun = ufl.inner(P, ufl.grad(v)) * dx + Gext
# explorar
alpha = dolfinx.fem.Constant(domain, 1.0e-10)
J = (1/2) * ufl.inner(uh - ud, uh - ud) * ufl.dx + (alpha/2) * ufl.inner(ufl.grad(CC), ufl.grad(CC)) * ufl.dx
forward_problem = NonLinearSolver(Fun, uh=uh, bcs=bcs)
lmbda = dolfinx.fem.Function(V)
dFdu = ufl.derivative(Fun, uh, du)
dFdu_adj = ufl.adjoint(dFdu)
dJdu = ufl.derivative(J, uh, v)
-dJdu,
lmbda,
bcs
I hope this can make the question clear.
Any help is appreciated.
Best regards,
Bernardo M. Rocha
