Order of element on a 1D sutructure
Hi community,
I try to create a simple case of a 1D structure where the Helmholtz equation is solved with bc. It works perfectly when I use a space function with Lagrangian polynomial of degree 1, but it doesn’t work with quadratic element, here is the code and the output error :
from ufl import TrialFunction, TestFunction, dx, grad, inner, div, ds, as_vector, Measure, conj
from basix.ufl import element
from dolfinx.fem import Function, FunctionSpace, assemble_scalar, form, functionspace, assemble_vector
from dolfinx.fem import petsc
from dolfinx.mesh import create_interval, locate_entities_boundary, meshtags
# Problem parameters
Lf = 1.0  # Domain length (1 meter)
rho_0 = 1.21  # Volumic masse of air (kg/m^3)
c = 343.0  # Speed of sound in the air (m/s)
omega = 2 * np.pi * 1000  # Angular frequency
k = omega / c  # Wave number
Z_n = rho_0 * c  # Acoustic impedance
# 1D mesh
nb_cells = 100
mesh = create_interval(MPI.COMM_WORLD, nb_cells, [0, Lf])
cells_mesh = mesh.ufl_cell()
# Space function
deg = 2
#Ve = element("Lagrange", mesh.ufl_cell(), deg)
V = functionspace(mesh, ("Lagrange", deg))
# Test and Trial functions
p = TrialFunction(V)
# Variational formulation
a = inner(grad(p), grad(v)) * dx - k**2 * inner(p, v) * dx
# Detect the boundaries
def left_boundary(x):
    return np.isclose(x[0], 0)
def right_boundary(x):
    return np.isclose(x[0], Lf)
# Find the facets
facets_left = locate_entities_boundary(mesh, mesh.topology.dim - 1, left_boundary)
facets_right = locate_entities_boundary(mesh, mesh.topology.dim - 1, right_boundary)
# Create a MeshTag for the facets
facet_tags = meshtags(mesh, mesh.topology.dim - 1,
                      np.concatenate([facets_left, facets_right]),
                      np.array([0] * len(facets_left) + [1] * len(facets_right)))
# Define a Measure, surface integral on boundaries
ds_boundary = Measure("ds", domain=mesh, subdomain_data=facet_tags)
a += inner((1j * omega * rho_0 / Z_n) * p,  v) * ds_boundary(1)
# Source term
f = omega**2 * rho_0 * 1.0
L = inner(f, v) * ds_boundary(0)
# Solving the linear system
problem = LinearProblem(a, L, petsc_options={"ksp_type": "preonly",
                                            "pc_type": "lu",
                                            "pc_factor_mat_solver_type": "mumps"})
p_solution = problem.solve()
u_f = p_solution.x.array
x = np.linspace(0, Lf, 1000)
k = omega/c
p_ana = 1j*rho_0*c*omega*1.0*np.exp(1j*k*x)
plt.plot(x, p_ana.real, label = 'Analytical')
plt.plot(np.linspace(0,Lf, (nb_cells*deg) + 1), u_f.real, label = 'Numerical')
plt.legend()
# Sauvegarde et visualisation
if True:
    with XDMFFile(MPI.COMM_WORLD, "solution_helmholtz.xdmf", "w") as xdmf:
        xdmf.write_mesh(mesh)
        #xdmf.write_function(p_solution) #This line is changed
        u1 = Function(V)
        u1.interpolate(p_solution)
        # Sauvegarde de la fonction projetée
        xdmf.write_function(u1)
The error :
TypeError                                 Traceback (most recent call last)
/usr/local/lib/python3.10/dist-packages/dolfinx/fem/function.py in interpolate(self, u0, cells0, cells1)
    458             # u is a Function or Expression (or pointer to one)
--> 459             _interpolate(u0)
    460         except TypeError:
3 frames
TypeError: interpolate(): incompatible function arguments. The following argument types are supported:
    1. interpolate(self, f: ndarray[dtype=complex128, shape=(*), order='C', writable=False], cells: ndarray[dtype=int32, shape=(*), order='C', writable=False]) -> None
    2. interpolate(self, f: ndarray[dtype=complex128, shape=(*, *), order='C', writable=False], cells: ndarray[dtype=int32, shape=(*), order='C', writable=False]) -> None
    3. interpolate(self, u: dolfinx.cpp.fem.Function_complex128, cells0: ndarray[dtype=int32, shape=(*), order='C', writable=False], cells1: ndarray[dtype=int32, shape=(*), order='C', writable=False]) -> None
    4. interpolate(self, u: dolfinx.cpp.fem.Function_complex128, cells: ndarray[dtype=int32, shape=(*), order='C', writable=False], interpolation_data: dolfinx.cpp.geometry.PointOwnershipData_float64) -> None
    5. interpolate(self, e0: dolfinx.cpp.fem.Expression_complex128, cells0: ndarray[dtype=int32, order='C', writable=False], cells1: ndarray[dtype=int32, order='C', writable=False]) -> None
Invoked with types: dolfinx.cpp.fem.Function_complex128, ndarray, ndarray, ndarray
AssertionError                            Traceback (most recent call last)
    461             # u0 is callable
--> 462             assert callable(u0)
    463             x = _cpp.fem.interpolation_coords(
    464                 self._V.element, self._V.mesh.geometry._cpp_object, cells0
AssertionError:
Thanks a lot
Running with the current main I get
  File "/file.py", line 94, in <module>
  File "lib/python3.12/site-packages/dolfinx/io/utils.py", line 252, in write_function
    super().write_function(getattr(u, "_cpp_object", u), t, mesh_xpath)
RuntimeError: Degree of output Function must be same as mesh degree. Maybe the Function needs to be interpolated?
which may be more informative in telling you what to do to fix the error.
