Currently I have a mesh that I have imported externally from a .xml file in order to examine the surface facets of the mesh which i tagged in a group when making the mesh. Currently, I can output the midpoints of each facet and the normal vectors using:
tag = 1 #Tag for 'surface' group in .msh file
surfacefacetindices = np.where(boundaries.array() == tag)[0]
surfacefacets = np.array(list(facets(mesh)))[surfacefacetindices]
coordinates = []
normalvec = []
for f in surfacefacets:
coordinates.append(f.midpoint().array())
normalvec.append(f.normal().array())
What I would like to know is, is there anyway to output the area of each surface facet from this tagged list? Thanks in advance
Edit: Given my problem, it is difficult to replicate using an in built mesh, therefore the link to the required files are here: Sphere - Google Drive
The minimal example is shown below:
from collections import defaultdict
data = 'sphere'
mesh = Mesh()
hdf = HDF5File(mesh.mpi_comm(), data+'.h5', 'r')
hdf.read(mesh, '/mesh', False)
cells_f = MeshFunction('size_t', mesh, 3)
hdf.read(cells_f, '/cells')
facets_f = MeshFunction('size_t', mesh, 2)
hdf.read(facets_f, '/facets')
boundaries = MeshFunction('size_t', mesh, 'sphere_facet_region.xml')
Space = FunctionSpace(mesh,'P', 1)
x_Space = Space.tabulate_dof_coordinates().reshape((-1,mesh.geometry().dim()))
V = FunctionSpace(mesh,'P', 1)
coordinates = []
normalvec = []
For further questions, please consider making a similar example to what I have presented above (using a built-in mesh) as it is then easier for others to contribute and reproduce your issue.
I have added a minimal working example and a link to the required files as I could not replicate it using an in built mesh. In addition, I am confused what the role of f_to_c and c_to_f are within this code
The code I posted above shows exactly what you would like to produce. It prints the area of each facet marked with the value 1. c_to_f maps a cell index to its facets, while f_to_c maps from a facet to the cell(s) that contains it.
If I extend your example code to 3D using UnitCubeMesh and then I try to use the same method to print the facet area for facets that lie on two different boundaries (which is something I am attempting to do in my much larger project), I get this error:
File "simpletest.py", line 31, in <module>
cell = all_cells[f_to_c(facet.index())[0]]
IndexError: index 6096 is out of bounds for axis 0 with size 6000
Any idea on how I can get this to successfully print the facet area for both boundaries in 3D? The working example is below:
