Paraview to visualize a field like in the tutorial
I realize it’s a question related to Paraview more than FEniCS, but I am trying to reproduce the views of magnetostatics.py from the FEniCS tutorial. I am talking about the figure 15 and figure 16 of https://fenicsproject.org/pub/tutorial/html/._ftut1015.html.
When I plot the vector potential using Paraview, by default it is a flat 2D surface that looks like it could become the picture of the FEniCS tutorial if I managed to make it three dimensional, but I haven’t found out how to achieve this. Any idea?
And regarding the magnetic field itself (figure 16), Paraview shows, by default, a single color (and no indication of any value). Examining the field.vtu file with a text editor seems to indicate non zero values, so Paraview should in principle be able to show some patterns instead of a flat color. I am not sure how to reproduce figure 16 at all. Any pointer?
Use the Warp by Scalar Filter. (I’ve recently updated this demo to be used with dolfin-X, and I’ve mentioned this feature specifically at the end of https://jorgensd.github.io/dolfinx-tutorial/chapter3/em.html).
In general, in paraview you have an option to chose the variable you would like to visualize.
button
Below it says vtkBlockColors, and can be changed to the field of interest.
First of all, thanks a lot for the very quick response. I was not aware of the documentation for dolfinx, I will try to switch to it.
Thanks to your guidance I was able to reproduce the vector potential in Paraview. I also had to increase the “scale factor” in Paraview for the 3D view to appear.
However I am still unable to visualize the magnetic field.
Now, when selecting the field, all I get is the following (low resolution? So strange…) picture.
It looks very different than figure 16 of the tutorial.
The magnetic field is a vector field, and can be visualized either by using the Glyphs filter (with corresponding scaling), or the Stream Tracer to create a plot similar to the one in figure 16.
I would hold off switching for a little while, we are making quite a few interface changes atm, to make it easier for end-users. However, feel free to leave feedback on the tutorial, using the issue tracker on the top of the page/
Alright. On the top of my head, right now, I would say a documentation (I guess it already exists?) about how to import mesh files that are generated for example with gmsh, as I believe the support for mshr is dropped now and the only way to deal with a mesh is with an external generation.
I have a two tutorials on my personal web page:
And there are several examples (the EM example and deflection of a membrane) that used the Gmsh Python interface to create meshes in the dolfin-x tutorial.
