Parent facet map
Is there an equivalent for the facets of:
mesh.data().array("parent_cell", mesh.topology().dim())
I need the map between the initial and the refined mesh facets and i coudn’t find anywhere all the possible array name to use in data().array().
Thanks in advance.
Since you havent supplied a minimal working example of your code, this is just guesswork from me, but could you do
mesh.data().array("parent_cell", mesh.topology().dim()-1)?
Sadly i already tried both
mesh.data().array("parent_cell", mesh.topology().dim-1)
and
mesh.data().array("parent_facet", mesh.topology().dim-1)
without any luck.
If you want any help on this topic, you Need to supply a minimal example of the code until the point Where you are stuck
Thanks for the replies, here is a mwe, it’s just a simple refinement of a mesh on which i want to find the map between parent and child but i have no clue how.
mesh = UnitSquareMesh(2,2)
File('mesh.pvd') << (mesh,0)
mark = MeshFunction('bool', mesh, mesh.topology().dim(), False)
m = [0]
mark.array()[m] = True
mesh2 = refine(mesh, mark)
File('mesh2.pvd') << mesh2
rmap = mesh2.data().array("parent_cell", mesh2.topology().dim())
#fmap = (?) facet map between parent and child
Thanks in advance.
