I am trying to solve the Stokes flow (having same form as the elastic equilibrium equation) on a square grid with Periodic Boundary Condition (PBC) along both the x and y directions. The code is generating somewhat sensible outputs but I am having large errors at the corners.
Could you please suggest me how I can get rid of these larger errors at the corners of the square domain. I have copied my code below where I have implemented the PBCs on both directions. Is this the correct way of implementing PBC? At the end of this post I have attached the plots of the solution vector components.
Thanks!
### Linear elasticity example FEniCSx tutorial ###
### importing packages and defining parameters starts ###
from __future__ import annotations
from pathlib import Path
from typing import Union
import dolfinx.fem as fem
import scipy.sparse.linalg
from dolfinx.common import Timer, TimingType, list_timings
from dolfinx.mesh import create_unit_square, locate_entities_boundary
from ufl import (SpatialCoordinate, TestFunction, TrialFunction, as_vector, dx,
exp, grad, inner, pi, sin, cos)
import dolfinx_mpc.utils
from dolfinx_mpc import LinearProblem, MultiPointConstraint
import pandas as pd
import pyvista
from dolfinx import mesh, fem, plot, io
default_scalar_type = PETSc.ScalarType
#L = 1
#W = 0.2
mu = 0.001 ### 0.001, 1
#rho = 1
#delta = W / L
#gamma = 0.4 * delta**2
#beta = 1.25
#lambda_ = beta
lambda_ = 1
print("Value of mu: {}, and lambda: {}".format(mu,lambda_))
#g = gamma
### importing packages and defining parameters ends ###
### defining mesh starts ###
# domain = mesh.create_box(MPI.COMM_WORLD, [np.array([0, 0, 0]), np.array([L, W, W])],
# [20, 6, 6], cell_type=mesh.CellType.hexahedron)
# nx, ny = 50, 50
# domain = mesh.create_rectangle(MPI.COMM_WORLD, [np.array([-2, -2]), np.array([2, 2])],
# [nx, ny], mesh.CellType.triangle)
# Get PETSc int and scalar types
complex_mode = True if np.dtype(default_scalar_type).kind == 'c' else False
# Create mesh and finite element
NX = 50
NY = 50
mesh = create_unit_square(MPI.COMM_WORLD, NX, NY)
#V = fem.functionspace(mesh, ("Lagrange", 1, (mesh.geometry.dim, )))
V = fem.functionspace(mesh, ("Lagrange", 2, (mesh.geometry.dim, )))
tol = 250 * np.finfo(default_scalar_type).resolution
# Listing space points ###
dof_coordinates = V.tabulate_dof_coordinates()
df = pd.DataFrame(dof_coordinates)
df.to_csv('outdata/planenodesPeriodic.csv', index = None, header=False)
### defining mesh ends ###
### boundary conditions starts ###
# def dirichletboundary(x):
# return np.logical_or(np.isclose(x[1], 0, atol=tol), np.isclose(x[1], 1, atol=tol))
# # Create Dirichlet boundary condition
# facets = locate_entities_boundary(mesh, 1, dirichletboundary)
# topological_dofs = fem.locate_dofs_topological(V, 1, facets)
# zero = np.array([0, 0], dtype=default_scalar_type)
# bc = fem.dirichletbc(zero, topological_dofs, V)
# bcs = [bc]
bcs = []
# Sub domain for Periodic boundary condition
def periodic_boundary0(x):
return np.isclose(x[0], 1, atol=tol)
def periodic_boundary1(x):
return np.isclose(x[1], 1, atol=tol)
# def periodic_relation(x):
# out_x = np.zeros_like(x)
# out_x[0] = 1 - x[0]
# out_x[1] = x[1]
# out_x[2] = x[2]
# return out_x
def periodic_relation0(x):
out_x[0] = 1 - x[0]
out_x[1] = x[1]
out_x[2] = x[2]
return out_x
def periodic_relation1(x):
out_x[0] = x[0]
out_x[1] = 1 - x[1]
out_x[2] = x[2]
return out_x
with Timer("~PERIODIC: Initialize MPC"):
mpc = MultiPointConstraint(V)
mpc.create_periodic_constraint_geometrical(V, periodic_boundary0, periodic_relation0, bcs)
mpc.create_periodic_constraint_geometrical(V, periodic_boundary1, periodic_relation1, bcs)
#mpc.create_periodic_constraint_geometrical(V, periodic_boundary, periodic_relation, bcs)
mpc.finalize()
### traction free BC starts on other faces ###
T = fem.Constant(mesh, default_scalar_type((0, 0)))
### traction free BC ends on other faces ###
### defining surface integral over the boundary starts ###
ds = ufl.Measure("ds", domain=mesh)
### defining surface integral over the boundary ends ###
### boundary conditions end ###
### variational formulation starts ###
return ufl.sym(ufl.grad(u)) # Equivalent to 0.5*(ufl.nabla_grad(u) + ufl.nabla_grad(u).T)
def sigma(u):
u = ufl.TrialFunction(V)
x = SpatialCoordinate(mesh)
#f = as_vector((sin(2 * pi * x[0]), 0))
f = as_vector((1000 * cos(2 * pi * x[0] + 2 * pi * x[1]), 1000 * cos(2 * pi * x[0] + 2 * pi * x[1])))
#f = fem.Constant(mesh, default_scalar_type((0, 0)))
#f = as_vector((x[0] * sin(5.0 * pi * x[1]) + 1.0 * exp(-(dx_ * dx_ + dy_ * dy_) / 0.02), 0.3 * x[1]))
### variational formulation ends ###
### solving variational problem starts ###
# problem = LinearProblem(a, L, bcs=[bc], petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
# #problem = LinearProblem(a, L, petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
# uh = problem.solve()
# Setup MPC system
with Timer("~PERIODIC: Initialize varitional problem"):
problem = LinearProblem(a, L, mpc, bcs=bcs)
solver = problem.solver
# Give PETSc solver options a unique prefix
solver_prefix = "dolfinx_mpc_solve_{}".format(id(solver))
solver.setOptionsPrefix(solver_prefix)
petsc_options: dict[str, Union[str, int, float]]
if complex_mode or default_scalar_type == np.float32:
petsc_options = {"ksp_type": "preonly", "pc_type": "lu"}
petsc_options = {"ksp_type": "cg", "ksp_rtol": 1e-6, "pc_type": "hypre", "pc_hypre_type": "boomeramg",
"pc_hypre_boomeramg_max_iter": 1, "pc_hypre_boomeramg_cycle_type": "v" # ,
# "pc_hypre_boomeramg_print_statistics": 1
# Set PETSc options
opts = PETSc.Options() # type: ignore
opts.prefixPush(solver_prefix)
if petsc_options is not None:
for k, v in petsc_options.items():
opts[k] = v
opts.prefixPop()
solver.setFromOptions()
with Timer("~PERIODIC: Assemble and solve MPC problem"):
# solver.view()
it = solver.getIterationNumber()
print("Constrained solver iterations {0:d}".format(it))
### solving variational problem ends ###
usol = uh.x.array
numpoints = int(len(usol)/2)
usol = np.reshape(usol, (numpoints,2))
#print(usol.tolist())
df = pd.DataFrame(usol)
df.to_csv('outdata/planedisplacementsPeriodic.csv', index = None, header=False)
print("Number of nodes {}".format(len(dof_coordinates)))
print("Number of sol points {}".format(len(usol)))
