Petsc Snes solver in dolfinx
Hello everyone,
I am trying to use the petsc snes solver in the dolfinx. I am very new to the dolfinx. I am taking the help from the old discussion
The code for petsc snes in dolfin is working and provides the desired results. Here is the code I am using for that
N = 5
mesh = UnitSquareMesh(N, N)
d = Function(V)
dlb = Function(V)
dub = Function(V)
dub.interpolate(Constant(1.))
d_ = TestFunction(V)
dd = TrialFunction(V)
energy = ((d-0.5)**2)*dx
F = derivative(energy, d, d_)
J = derivative(F, d, dd)
b = Function(V).vector()
A = PETScMatrix()
def function(solver, x):
    return assemble(energy)
def gradient(solver,  x, b):
    d.vector()[:] = x
    b = PETScVector(b)
    return assemble(F, tensor=b)
def hessian(solver,  x, A, P):
    A = PETScMatrix(A)
    return assemble(J, tensor=A)
snes_solver = PETSc.SNES().create(PETSc.COMM_WORLD)
PETScOptions.set("snes_monitor")
snes_solver.setFromOptions()
snes_solver.setType(PETSc.SNES.Type.VINEWTONSSLS)
snes_solver.setFunction(gradient, b.vec())
snes_solver.setJacobian(hessian, A.mat())
snes_solver.setVariableBounds(dlb.vector().vec(), dub.vector().vec())
snes_solver.solve(None, d.vector().vec())
print("Succeeded SNES Solve", d.vector()[:])
In similar way, the code for dolfinx is developed and the code is as follows:
from dolfinx import mesh
N = 5
domain = mesh.create_unit_square(MPI.COMM_WORLD, 8, 8,  mesh.CellType.quadrilateral)
V = dolfinx.fem.FunctionSpace(domain, ('CG', 1))
def one(x):
    return np.ones(x.shape[1])
d = dolfinx.fem.Function(V)
dlb = dolfinx.fem.Function(V)
dub = dolfinx.fem.Function(V)
dub.interpolate(one)
d_ = ufl.TestFunction(V)
dd = ufl.TrialFunction(V)
energy = ((d-0.5)**2)*ufl.dx
F = ufl.derivative(energy, d, d_)
J = ufl.derivative(F, d, dd)
b = dolfinx.fem.petsc.create_vector(dolfinx.fem.form(F))
A = dolfinx.fem.petsc.create_matrix(dolfinx.fem.form(J))
    return dolfinx.fem.petsc.assemble_scalar(energy)
#    x.ghostUpdate(addv=PETSc.InsertMode.INSERT, mode=PETSc.ScatterMode.FORWARD)
        #print('q')
 #   x.copy(d.vector)
  #  d.vector.ghostUpdate(addv=PETSc.InsertMode.INSERT, mode=PETSc.ScatterMode.FORWARD)
    b = b.copy()
    with b.localForm() as loc:
        loc.set(0)
    return dolfinx.fem.petsc.assemble_vector(b,dolfinx.fem.form(F))
    A = A.copy()
    A.setZeroEntries()
    return dolfinx.fem.petsc.assemble_matrix(A, dolfinx.fem.form(J))
snes_solver = PETSc.SNES().create(MPI.COMM_WORLD)
opts = PETSc.Options()
opts["snes_monitor"] = None
snes_solver.setFunction(gradient, b)
snes_solver.setJacobian(hessian, A)
snes_solver.setVariableBounds(dlb.vector, dub.vector)
snes_solver.solve(None, d.vector)
print("Succeeded SNES Solve")
The code in dolfinx is running without any error but the snes solver is giving zero norm in the first iteration which is not correct. Please, guide me where is making mistake.
Thank you,
Manish
See for example dolfinx/python/test/unit/nls/test_newton.py at main · FEniCS/dolfinx · GitHub and corresponding dolfinx/python/test/unit/nls/test_newton.py at main · FEniCS/dolfinx · GitHub.
