@skatulla Ah! You caught me not paying close attention. ![]()
It looks like you should not apply your Dirichlet bcs to the collapsed subspaces, i.e. replacing
bc1 = fem.dirichletbc(fixed_displacement, left_u_dofs, V0)
bc2 = fem.dirichletbc(incremented_displacement, right_u_dofs, V0)
bc3 = fem.dirichletbc(fixed_director, top_wf_dofs, V1)
bc4 = fem.dirichletbc(fixed_director, bottom_wf_dofs,V1)
with
bc1 = fem.dirichletbc(fixed_displacement, left_u_dofs, VY.sub(0))
bc2 = fem.dirichletbc(incremented_displacement, right_u_dofs, VY.sub(0))
bc3 = fem.dirichletbc(fixed_director, top_wf_dofs, VY.sub(1))
bc4 = fem.dirichletbc(fixed_director, bottom_wf_dofs,VY.sub(1))
achieves convergence for me.
Complete code:
from contextlib import ExitStack
from dolfinx import fem, nls, mesh, plot, log, io
import pdb
# Create a box mesh of a beam
L = 20.0
H = 1.0
msh = mesh.create_box(MPI.COMM_WORLD, [np.array([0.0, 0.0, 0.0]), np.array([L, H, H])], [10, 1, 1],
mesh.CellType.hexahedron)
P1 = ufl.VectorElement("CG", msh.ufl_cell(), 1, dim=3) # Lagrange family, 1st order
P2 = ufl.VectorElement("CG", msh.ufl_cell(), 1, dim=3) # Lagrange family, 1st order
VY = fem.FunctionSpace(msh, ufl.MixedElement([P1, P2]))
# Boundary conditions and body loads
def left(x):
return np.isclose(x[0], 0)
def right(x):
return np.isclose(x[0], L)
def top(x):
return np.isclose(x[1], 1)
def bottom(x):
return np.isclose(x[1], 0)
def fixed_displacement_expression(x):
return np.stack((np.zeros(x.shape[1]), np.zeros(x.shape[1]), np.zeros(x.shape[1])))
def incremented_displacement_expression(x):
return np.stack((np.full(x.shape[1], 1.0e-02), np.zeros(x.shape[1]), np.zeros(x.shape[1])))
def fixed_director_expression(x):
# Dirichlet boundary application to affected displacement dofs
# Fix displacement DOF on left face and apply axial displacement on right face
V0, submap = VY.sub(0).collapse()
fixed_displacement = fem.Function(V0)
fixed_displacement.interpolate(fixed_displacement_expression)
incremented_displacement = fem.Function(V0)
incremented_displacement.interpolate(incremented_displacement_expression)
left_u_dofs = fem.locate_dofs_geometrical((VY.sub(0),V0), left)
right_u_dofs = fem.locate_dofs_geometrical((VY.sub(0),V0), right)
# Fix ALL change of director degrees of freedom in the domain
V1, submap = VY.sub(1).collapse()
fixed_director = fem.Function(V1)
fixed_director.interpolate(fixed_director_expression)
top_wf_dofs = fem.locate_dofs_geometrical((VY.sub(1),V1), top)
bottom_wf_dofs = fem.locate_dofs_geometrical((VY.sub(1),V1), bottom)
bcs = [bc1, bc2, bc3, bc4]
pdb.set_trace()
# Function space
v, yf = ufl.TestFunctions(VY) # test functions
uwf = fem.Function(VY) # current displacement and change of director
u, wf = ufl.split(uwf)
# Kinematics
# Spatial dimension
d = len(u)
# Identity tensor
I = ufl.variable(ufl.Identity(d))
# Deformation gradient
F = ufl.variable(I + ufl.grad(u))
# Right Cauchy-Green tensor
C = ufl.variable(F.T * F)
# Invariants
Ic = ufl.variable(ufl.tr(C))
J = ufl.variable(ufl.det(F))
# Constitutive law
# Set the elasticity parameters
E = PETSc.ScalarType(1.0e4)
nu = PETSc.ScalarType(0.3)
mu = fem.Constant(msh, E/(2*(1 + nu)))
lmbda = fem.Constant(msh, E*nu/((1 + nu)*(1 - 2*nu)))
# Stored strain energy density (compressible neo-Hookean model)
psi_m = (mu / 2.0) * (Ic - 3.0) - mu * ufl.ln(J) + (lmbda / 2.0) * (ufl.ln(J))**2
# 1st Piola Kirchhoff stress tensor
P = ufl.diff(psi_m, F) # 1st Piola Kirchhoff stress tensor
df = fem.Constant(msh, PETSc.ScalarType((0.0, 0.0, 0.0))) # dummy director stress
# Variational formulation
metadata = {"quadrature_degree": 3}
dx = ufl.Measure("dx", domain=msh, metadata=metadata)
# Define form Pi (we want to find u such that Pi(u) = 0)
Pi = ufl.inner(P, ufl.grad(v))*dx + ufl.inner(df, yf)*dx
# Initialize nonlinear problem
problem = fem.petsc.NonlinearProblem(Pi, uwf, bcs)
# Initialise Newton Rhapson solver
solver = nls.petsc.NewtonSolver(msh.comm, problem)
# Set Newton solver options
solver.atol = 1e-8
solver.rtol = 1e-8
solver.convergence_criterion = "incremental"
# Incremental application of the traction loading
log.set_log_level(log.LogLevel.INFO)
for n in range(1, 2):
num_its, converged = solver.solve(uwf)
assert(converged)
