Setting vector component-wise Dirichlet BCs
You can apply the .sub() function repeatedly without collapsing the subspaces, i.e.:
right_u_dofs = fem.locate_dofs_geometrical((VY.sub(0).sub(0),V0x), right)
bc2 = fem.dirichletbc(incremented_displacement, right_u_dofs, VY.sub(0).sub(0))
When you call sub(), a subspace is returned that retains a link to its parent subspace. When you collapse a subspace, a new FunctionSpace is created that has no knowledge of its parent function space. When you pass the collapsed subspace to fem.dirichletbc, the Dirichlet bc has no knowledge of the parent function space and thus the bc cannot affect the dofs of the function you are trying to solve (since it is in the parent subspace).
Here’s an adapted code based on my previous answer that applies the incremented bc only to u_x:
from contextlib import ExitStack
from dolfinx import fem, nls, mesh, plot, log, io
import pdb
# Create a box mesh of a beam
L = 20.0
H = 1.0
msh = mesh.create_box(MPI.COMM_WORLD, [np.array([0.0, 0.0, 0.0]), np.array([L, H, H])], [10, 1, 1],
                      mesh.CellType.hexahedron)
P1 = ufl.VectorElement("CG", msh.ufl_cell(), 1, dim=3)  # Lagrange family, 1st order
P2 = ufl.VectorElement("CG", msh.ufl_cell(), 1, dim=3)  # Lagrange family, 1st order
VY = fem.FunctionSpace(msh, ufl.MixedElement([P1, P2]))
# Boundary conditions and body loads
def left(x):
    return np.isclose(x[0], 0)
def right(x):
    return np.isclose(x[0], L)
def top(x):
    return np.isclose(x[1], 1)
def bottom(x):
    return np.isclose(x[1], 0)
def fixed_displacement_expression(x):
    return np.stack((np.zeros(x.shape[1]), np.zeros(x.shape[1]), np.zeros(x.shape[1])))
def incremented_displacement_expression(x):
    return np.full(x.shape[1], 1.0e-02)
def fixed_director_expression(x):
# Dirichlet boundary application to affected displacement dofs
# Fix displacement DOF on left face and apply axial displacement on right face
V0, submap = VY.sub(0).collapse()
V0x, subsubmap = V0.sub(0).collapse()
fixed_displacement = fem.Function(V0)
fixed_displacement.interpolate(fixed_displacement_expression)
incremented_displacement = fem.Function(V0x)
incremented_displacement.interpolate(incremented_displacement_expression)
left_u_dofs = fem.locate_dofs_geometrical((VY.sub(0),V0), left)
bc1 = fem.dirichletbc(fixed_displacement, left_u_dofs, VY.sub(0))
# Fix ALL change of director degrees of freedom in the domain
V1, submap = VY.sub(1).collapse()
fixed_director = fem.Function(V1)
fixed_director.interpolate(fixed_director_expression)
top_wf_dofs = fem.locate_dofs_geometrical((VY.sub(1),V1), top)
bottom_wf_dofs = fem.locate_dofs_geometrical((VY.sub(1),V1), bottom)
bc3 = fem.dirichletbc(fixed_director, top_wf_dofs, VY.sub(1))
bc4 = fem.dirichletbc(fixed_director, bottom_wf_dofs,VY.sub(1))
bcs = [bc1,  bc2, bc3, bc4]
pdb.set_trace()
# Function space
v, yf = ufl.TestFunctions(VY)     # test functions
uwf = fem.Function(VY)            # current displacement and change of director
u, wf = ufl.split(uwf)
# Kinematics
# Spatial dimension
d = len(u)
# Identity tensor
I = ufl.variable(ufl.Identity(d))
# Deformation gradient
F = ufl.variable(I + ufl.grad(u))
# Right Cauchy-Green tensor
C = ufl.variable(F.T * F)
# Invariants
Ic = ufl.variable(ufl.tr(C))
J  = ufl.variable(ufl.det(F))
# Constitutive law
# Set the elasticity parameters
E = PETSc.ScalarType(1.0e4)
nu = PETSc.ScalarType(0.3)
mu = fem.Constant(msh, E/(2*(1 + nu)))
lmbda = fem.Constant(msh, E*nu/((1 + nu)*(1 - 2*nu)))
# Stored strain energy density (compressible neo-Hookean model)
psi_m = (mu / 2.0) * (Ic - 3.0) - mu * ufl.ln(J) + (lmbda / 2.0) * (ufl.ln(J))**2
# 1st Piola Kirchhoff stress tensor
P = ufl.diff(psi_m, F)                                     # 1st Piola Kirchhoff stress tensor
df = fem.Constant(msh, PETSc.ScalarType((0.0, 0.0, 0.0)))  # dummy director stress
# Variational formulation
metadata = {"quadrature_degree": 3}
dx = ufl.Measure("dx", domain=msh, metadata=metadata)
# Define form Pi (we want to find u such that Pi(u) = 0)
Pi = ufl.inner(P, ufl.grad(v))*dx + ufl.inner(df, yf)*dx
# Initialize nonlinear problem
problem = fem.petsc.NonlinearProblem(Pi, uwf, bcs)
# Initialise Newton Rhapson solver
solver = nls.petsc.NewtonSolver(msh.comm, problem)
# Set Newton solver options
solver.atol = 1e-8
solver.rtol = 1e-8
solver.convergence_criterion = "incremental"
# Incremental application of the traction loading
log.set_log_level(log.LogLevel.INFO)
for n in range(1, 2):
    num_its, converged = solver.solve(uwf)
    assert(converged)
with io.XDMFFile(MPI.COMM_WORLD, "u.xdmf", "w") as xdmf:
    xdmf.write_mesh(msh)
    xdmf.write_function(uwf.split()[0])
