Dear community, i have the following poisson problem defined on a 3D cubic mesh:
from dolfinx.mesh import *
from dolfinx import fem, mesh, plot
from ufl import dx, grad, inner
# mesh, space
msh = create_box(MPI.COMM_WORLD, [[0.0, 0.0, 0.0], [1, 1, 1]], [20,20,20], CellType.hexahedron)
V = fem.functionspace(msh, ("Lagrange", 1))
# BC
facets = mesh.locate_entities_boundary(msh, dim=1,
marker=lambda x: np.logical_or.reduce((
np.isclose(x[0], 0.0),
np.isclose(x[0], 1.0),
np.isclose(x[1], 0.0),
np.isclose(x[1], 1.0),
np.isclose(x[2], 0.0),
np.isclose(x[2], 1.0))))
dofs = fem.locate_dofs_topological(V=V, entity_dim=1, entities=facets)
bc = fem.dirichletbc(0.0, dofs=dofs, V=V)
# Next, the variational problem is defined:
u = ufl.TrialFunction(V)
f = 10
L = inner(f, v) * dx
# linear problem brings together var probl, BC and solver (here: LU)
uh = problem.solve()
# plots
import pyvista
cells, types, x = plot.vtk_mesh(V)
grid = pyvista.UnstructuredGrid(cells, types, x)
grid.point_data["u"] = uh.x.array.real
grid.set_active_scalars("u")
plotter = pyvista.Plotter()
plotter.show()
How can I plot a cross section through a defined plane instead of the outside of the cube (which obviously shows nothing but the boundary values)?
Thank you!
