import mshr
from __future__ import division
from ufl import nabla_div
from dolfin import mesh as module
# Load mesh and define function space
L = 8.
W = 1.
n0 = int(L*6)
n1 = int(W*6)
n2 = int(W*6)
# Mesh for cantilever beam
Omega = BoxMesh(Point(0, 0, 0), Point(L, W, W), 10, 3, 3)
# = Box(0., 0., 0., d0, d1, d2, n0, n1, n2)
Omega.init()
V = VectorFunctionSpace(Omega, "CG", 1)
tol = 1.e-8 # tolerance
# Left boundary
class Left(SubDomain):
return near(x[0], 0.0)
# Right boundary
class Right(SubDomain):
return near(x[0], 8.0)
# Point (8,0.5,0.5) at which load is added
class point(SubDomain):
return near(x[0],8.) and near(x[1],0.5,1e-2) and near(x[2],0.5,1e-2)
#Boundary segments
left = Left()
pt = point()
right = Right()
boundaries = MeshFunction("size_t", Omega,0)
boundaries.set_all(0)
left.mark(boundaries, 1)
pt.mark(boundaries, 2)
f = Constant((0.0, 0.0, 00.0))
# Elasticity parameters
E = 210000.0
nu = 0.3
mu, lmbda = Constant(E/(2*(1 + nu))), Constant(E*nu/((1 + nu)*(1 - 2*nu)))
# Strain
def eps(u):
return sym(grad(v))
model = "plane_stress"
mu = E/2/(1+nu)
lmbda = E*nu/(1+nu)/(1-2*nu)
if model == "plane_stress":
lmbda = 2*mu*lmbda/(lmbda+2*mu)
def sigma(u):
return lmbda*tr(eps(u))*Identity(2) + 2.0*mu*eps(u)
ds = ds(subdomain_data=boundaries)
ds= Measure("ds")(subdomain_data=boundaries)
g_T= Constant((0.0, 0.0, -0.3))
a = inner(sigma(u), eps(v))*dx
left_end_displacement = Constant((0.0, 0.0, 0.0))
#bc = [DirichletBC(V, left_end_displacement, left)]
bc = [DirichletBC(V, left_end_displacement, left),DirichletBC(V, g_T, pt, method="pointwise")]
L= dot(f, v)*dx +dot(v,g_T)*ds(2)
# Compute solution
solve(a == L, u, bc);`
hello can anyone help me to fix
this code, there is an error after running a,variational form is wrong I guess
As far as i can see, you are doing a 3D problem, and then you have to use Identity(3) in the definition of sigma.
I am new on FEM and fenics and modified an example I found on the internet. I am still getting an error, I guess there is another mistake in the definition of l
It would help if you post the actual error message
in ()
1 u = Function(V)
----> 2 solve(a ==l, u, bc);
/usr/lib/python3/dist-packages/dolfin/fem/solving.py in solve(*args, **kwargs)
218 # tolerance)
219 elif isinstance(args[0], ufl.classes.Equation):
–> 220 _solve_varproblem(*args, **kwargs)
221
222 # Default case, just call the wrapped C++ solve function
/usr/lib/python3/dist-packages/dolfin/fem/solving.py in _solve_varproblem(*args, **kwargs)
245 solver = LinearVariationalSolver(problem)
246 solver.parameters.update(solver_parameters)
–> 247 solver.solve()
248
249 # Solve nonlinear variational problem
RuntimeError:
*** Error: Unable to extract mesh from form.
*** Reason: Non-matching meshes for function spaces and/or measures.
*** Where: This error was encountered inside Form.cpp.
*** Process: 0
*** DOLFIN version: 2019.1.0
*** Git changeset: unknown
I am running this code now, and getting the error above
import mshr
from future import print_function
from future import division
L = 8.
W = 1.
n0 = int(L6)
n1 = int(W6)
n2 = int(W*6)
Omega.init()
V = VectorFunctionSpace(Omega, “CG”, 1)
Left boundary
Right boundary
#Boundary segments
left = Left()
pt = point()
right = Right()
Initialize mesh function for boundary domains
#boundaries = MeshFunction(“size_t”, Omega, file)#“size_t”, mesh, 2, mesh.domains()
#boundaries.set_all(0)
#left.mark(boundaries, 1)
#pt.mark(boundaries, 2)
boundaries = MeshFunction(“size_t”, Omega,0) #mesh omega yerinde kalmisti
#boundaries = CellFunction(‘size_t’, mesh)
#all_boundary.mark(boundaries, 1)
E = 210000.0
nu = 0.3
mu, lmbda = Constant(E/(2*(1 + nu))), Constant(Enu/((1 + nu)(1 - 2*nu)))
Strain
def eps(v):
return sym(grad(v))
model = “plane_stress”
mu = E/2/(1+nu)
lmbda = Enu/(1+nu)/(1-2nu)
if model == “plane_stress”:
lmbda = 2mulmbda/(lmbda+2*mu)
def sigma(v):
return lmbdatr(eps(v))Identity(3) + 2.0mueps(v)
ds= Measure(“ds”)(subdomain_data=boundaries)
du = TrialFunction(V)
u_ = TestFunction(V)
a = inner(sigma(du), eps(u_))*dx
bc = [DirichletBC(V, left_end_displacement, left),DirichletBC(V, g_T, pt, method=“pointwise”)]
l= dot(f, v)*dx +dot(v,g_T)*ds(2)
Your code was riddled with typos. Please be more careful when writing your code. The first error is because you did not supply the domain when defining the measure. The next error was due to the fact that you use v inside def eps, which should be a function of u.
The following cleaned up code runs:
L = 8.
W = 1.
Omega.init()
# Left boundary
# Right boundary
#Boundary segments
left = Left()
pt = point()
right = Right()
E = 210000.0
nu = 0.3
# Strain
def eps(u):
return sym(grad(u))
mu = E/2/(1+nu)
def sigma(u):
return lmbda*tr(eps(u))*Identity(3) + 2.0*mu*eps(u)
ds= Measure("ds", domain=Omega, subdomain_data=boundaries)
a = inner(sigma(u), grad(v))*dx
# Compute solution
Thank you so much, and how should I learn the displacement at the free end also plot this deformation
There are many demos at bitbucket. For instance demo for elasticity.
Instead of using matplotlib you can also save the function and visualize it in Paraview
I will look at it thank you
Would you tell me ,
-u(10,1,1)[2] is this this command correct? What does [2] mean here ?
It’s the z component of the deformation
which is the displacement then, right
My other question is: In this code if I put an end load, I am not getting logical results. My deflection formula is the superposition of point load and distributed load. I am expecting better prediction of displacement when I increase the mesh.
δ=(qL^4)/8EI+(FL^3)/3EIδ=(qL^4)/8EI+(FL^3)/3EI
Where am I doing a mistake?
You need to make a minimal code that illustrates how the behavior is different from what you expect.
actually, I am questioning this superposition formula, it is true for Euler Beam right
Here for instance I am not considering the body force, and FL^3/3EI gives 0,032.
This code gives 0.79 with 100 elements and with 10 elements it is 0.17
L = 20.
W = 1.
Omega = BoxMesh(Point(0, 0, 0), Point(L, W, W),100, 3, 3)
Omega.init()
Left boundary
Right boundary
return near(x[0], L)
return near(x[0],L) and near(x[1],0.5,1e-2) and near(x[2],0.5,1e-2)
#Boundary segments
left = Left()
pt = point()
right = Right()
f = Constant((0.0, 0.0, -0))
E = 1e5
nu = 0.3
Strain
def eps(u):
return sym(grad(u))
mu = E/2/(1+nu)
lmbda = 2mulmbda/(lmbda+2mu)
def sigma(u):
return lmbdatr(eps(u))Identity(3) + 2.0mu*eps(u)
ds= Measure(“ds”, domain=Omega, subdomain_data=boundaries)
g_T= Constant((0.0, 0.0, -1e-1))
Compute solution
solve(a == l, u, bc)
print(“Maximal deflection:”, -u(20,1,1)[2])
I am tring to use quadratic elements instead of linear elements. if I change 1 to 2 in this code, would it be correct
V = VectorFunctionSpace(Omega, “CG”, 2)
Yes. This is a trivial question. Please read through the FEniCS tutorial which will guide you
