jupyter-notebook version 6.0.3
on Ubuntu 20.04
FEniCS version 2019.1.0
The code from the tutorial “Solving the Poisson equation” behaves strangely when I increase the resolution of the mesh.
Firstly, the errors seem to increase (or at least fluctuate) with finer meshes:
# mesh 8x8
error_L2 = 0.008235098073354848
error_max = 1.3322676295501878e-15
# mesh 16x16
error_L2 = 2.1118912621708272
error_max = 5.329070518200751e-15
#mesh 32x32
error_L2 = 2.0750004430294164
error_max = 2.1760371282653068e-14
But the strangest thing happens at a 64x64 mesh: The solution changes on each run and the errors are huge:
# mesh 64
error_L2 = 6.071644593466394
error_max = 26.340951344432604
# mesh 64 again
error_L2 = 3.904042361757662
error_max = 15.981625955363619
# mesh 64 again
error_L2 = 11.473897896657363
error_max = 46.409562760391076
This is also visible in the plot, where we seem to see a changing cluster of random extrema (yellow/blue spots) and incorrectly constant boundary values (green near the boundary).
Aside from the mesh resolution, my code is unchanged from the tutorial page (my actual problem is a cubic polynomial, but the strange behaviour is the same):
mesh = UnitSquareMesh(8, 8)
# Define boundary condition
u_D = Expression('1 + x[0]*x[0] + 2*x[1]*x[1]', degree=2)
def boundary(x, on_boundary):
return on_boundary
f = Constant(-6.0)
a = dot(grad(u), grad(v))*dx
L = f*v*dx
# Compute solution
solve(a == L, u, bc)
# Plot solution and mesh
plot(u)
# Save solution to file in VTK format
vtkfile = File('poisson/solution.pvd')
vtkfile << u
# Compute error in L2 norm
error_L2 = errornorm(u_D, u, 'L2')
# Compute maximum error at vertices
vertex_values_u_D = u_D.compute_vertex_values(mesh)
error_max = np.max(np.abs(vertex_values_u_D - vertex_values_u))
# Print errors
print('error_L2 =', error_L2)
print('error_max =', error_max)
(A similar error was described here with no solution.)
