Precondition appears not to happen
Hi all,
For a Navier-Stokes problem, I want to separately precondition the u block (Jacobi) and the p block (algebraic multigrid on the Schur complement), while using mixed spaces.
I believe I have everything set up correctly, and am (finally :face_exhaling:) no longer getting the PETSc warning “There are unused database options”. But when I activate solver verbosity (setting ksp_view), then none of my own settings are mentioned in the output. Instead it mentions LU or MUMPS preconditioners (depending on mpi run with 1 or multiple cores).
Here is a MWE of a lid driven cavity:
from dolfinx import mesh, fem
from ufl import div, nabla_grad, dot, inner, outer, dx, sym
# User parameters
Re = 10 # Reynolds number
N = 5 # Elements in x & y
Pu = 2 # Polynomial order u
Pp = 1 # Polynomial order p
# Function space
L = 1 # Domain size
domain = mesh.create_rectangle(MPI.COMM_WORLD, [(0,0),(L,L)], [N,N], mesh.CellType.quadrilateral)
Ve = element("Lagrange", domain.basix_cell(), Pu, shape=(domain.geometry.dim,))
Qe = element("Lagrange", domain.basix_cell(), Pp)
W_el = mixed_element([Ve, Qe])
W = fem.functionspace(domain, W_el)
V, WV_map = W.sub(0).collapse() # DOF map from W to V
Q, WQ_map = W.sub(1).collapse() # DOF map from W to Q
# Trial and test functions
w_trial = ufl.TrialFunction(W)
v, q = ufl.TestFunctions(W)
u_p = fem.Function(W)
u, p = ufl.split(u_p)
# Navier-Stokes weak form
nu = fem.Constant(domain, PETSc.ScalarType(1/Re)) # Viscosity
B = - inner( outer(u,u), nabla_grad(v) )*dx \
    + dot( q, div(u) )*dx \
    - dot( div(v), p )*dx \
    + inner( 2*nu*sym(nabla_grad(u)), sym(nabla_grad(v)) )*dx
# Boundary conditions
def node_origin(x):
    return np.logical_and(np.isclose(x[0],0),np.isclose(x[1],0))
dof_origin_p = fem.locate_dofs_geometrical((W.sub(1), Q), node_origin)
bc_zero_p = fem.dirichletbc(fem.Function(Q), dof_origin_p, W.sub(1))
def walls(x):
    return np.isclose(x[0],0) | np.isclose(x[0], L) | np.isclose(x[1],0)
facets_wall = mesh.locate_entities_boundary(domain, domain.geometry.dim-1, walls)
dofs_walls = fem.locate_dofs_topological((W.sub(0), V), domain.geometry.dim-1, facets_wall)
bc_zero_u = fem.dirichletbc(fem.Function(V), dofs_walls, W.sub(0))
def lid(x):
    return np.isclose(x[1], L)
facets_lid = mesh.locate_entities_boundary(domain, domain.geometry.dim-1, lid)
dofs_lid = fem.locate_dofs_topological((W.sub(0), V), domain.geometry.dim-1, facets_lid)
u_unit = fem.Function(V)
u_unit.interpolate(lambda x: (np.ones(x.shape[1]),np.zeros(x.shape[1])) )
bc_unit_u = fem.dirichletbc(u_unit, dofs_lid, W.sub(0))
bcs = [bc_zero_p,bc_zero_u,bc_unit_u]
# Below is where the solver and its settings are
J = ufl.derivative(B,u_p,w_trial)
ns_problem = NonlinearProblem(B,u_p,bcs=bcs,J=J)
newton_solver = NewtonSolver(domain.comm,ns_problem)
opts = PETSc.Options()
ksp = newton_solver.krylov_solver
opts[f"{option_prefix}ksp_type"] = "gmres"
opts[f"{option_prefix}ksp_pc_side"] = "right" # Use right preconditioning: ( K M^-1 ) M x = b. This preserves the residual.
opts[f"{option_prefix}ksp_view"] = None
pc = ksp.getPC() # Preconditioning object
pc.setType("fieldsplit") # Different preconditioning for different blocks
IS_u = PETSc.IS().createGeneral(WV_map, domain.comm)
pc.setFieldSplitIS(('u',IS_u))
IS_p = PETSc.IS().createGeneral(WQ_map, domain.comm)
pc.setFieldSplitIS(('p',IS_p))
ksp_u, ksp_p = pc.getFieldSplitSubKSP()
pc.setFieldSplitType(PETSc.PC.CompositeType.SCHUR)
pc.setFieldSplitSchurFactType(PETSc.PC.FieldSplitSchurFactType.UPPER)
pc.setFieldSplitSchurPreType(PETSc.PC.FieldSplitSchurPreType.SELFP)
option_prefix_u = ksp_u.getOptionsPrefix()
opts[f"{option_prefix_u}ksp_type"] = "preonly" # Precondition only once in Newton iterations
opts[f"{option_prefix_u}pc_type"] = "jacobi"
option_prefix_p = ksp_p.getOptionsPrefix()
opts[f"{option_prefix_p}ksp_type"] = "preonly" # Precondition only once in Newton iterations
opts[f"{option_prefix_p}pc_type"] = "hypre" # Hypre (algebraic multigrid) preconditioning for p-block
opts[f"{option_prefix_p}pc_hypre_type"] = "boomeramg" # Choice of implementation
opts[f"{option_prefix_p}pc_hypre_boomeramg_coarsen_type"] = "pmis" # Grid coarsening strategy
opts[f"{option_prefix_p}pc_hypre_boomeramg_interp_type"] = "FF1" # Projection on to coarser grid
opts[f"{option_prefix_p}pc_hypre_boomeramg_strong_threshold"] = "0.5" # Coarsening limit
ksp_u.setFromOptions()
ksp_p.setFromOptions()
ksp.setFromOptions()
# Above is where the solver and its settings are
it,_ = newton_solver.solve(u_p)
print(f"Solved in {it} iterations.")
And this is the output for a single-core run:
KSP Object: (nls_solve_) 1 MPI process
  type: gmres
    restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
    happy breakdown tolerance 1e-30
  maximum iterations=10000, initial guess is zero
  tolerances: relative=1e-05, absolute=1e-50, divergence=10000.
  using UNPRECONDITIONED norm type for convergence test
PC Object: (nls_solve_) 1 MPI process
  type: lu
   out-of-place factorization
    tolerance for zero pivot 2.22045e-14
    matrix ordering: nd
    factor fill ratio given 5., needed 1.47955
      Factored matrix follows:
        Mat Object: (nls_solve_) 1 MPI process
          type: seqaij
          rows=278, cols=278
          package used to perform factorization: petsc
          total: nonzeros=14328, allocated nonzeros=14328
            using I-node routines: found 103 nodes, limit used is 5
  linear system matrix = precond matrix:
  Mat Object: 1 MPI process
    type: seqaij
    rows=278, cols=278
    total: nonzeros=9684, allocated nonzeros=9684
    total number of mallocs used during MatSetValues calls=0
      using I-node routines: found 142 nodes, limit used is 5
Any help would be much appreciated!
Best,
Stein
The issue seems to be NewtonSolver related. The same code (but Stokes) with solver=LinearProblem(B,F,bcs=bcs) and ksp = solver._solver properly implements the preconditioning.
How do I make the Newton solver apply preconditioning settings?
One step forward, two steps back.
I managed to get both the linear and nonlinear solver to apply the preconditioner by starting the option setting code with: ksp.setOptionsPrefix(""). No idea why.
Everything seems to work, until I run with mpi and more than 1 core. For a tiny problem it says:
RuntimeError: Failed to successfully call PETSc function 'KSPSolve'. PETSc error code is: 55, Out of memory
So I would still much appreciate any help…
Here is the updated code snippet:
# User parameters
# Function space
L = 1 # Domain size
def node_origin(x):
def walls(x):
def lid(x):
ksp.setOptionsPrefix("") # This fixes the issue with the nonlinear solver
IS_u = PETSc.IS().createGeneral(WV_map, domain.comm).sort()
IS_p = PETSc.IS().createGeneral(WQ_map, domain.comm).sort()
pc.setFieldSplitIS(('u',IS_u),('p',IS_p))
The problem was that WV_map and WQ_map reference (cpu-)local dof numbers, whereas PETSc’s index-set requires global numbers. Secondly, the ghost dofs need to be thrown out. The following tweak fixes the parallel runnability:
W_indexmap = W.dofmap.index_map
globaldofs_u = np.setdiff1d( W_indexmap.local_to_global(np.array(WV_map)), W_indexmap.ghosts ) # getting the global velocity dofs that live on this core
globaldofs_p = np.setdiff1d( W_indexmap.local_to_global(np.array(WQ_map)), W_indexmap.ghosts ) # getting the global pressure dofs that live on this core
IS_u = PETSc.IS().createGeneral(np.array(globaldofs_u,dtype=np.int32), comm=domain.comm).sort()
IS_p = PETSc.IS().createGeneral(np.array(globaldofs_p,dtype=np.int32), comm=domain.comm).sort()
I’ll post a small scaling study when I find the time
I ran a little scaling study, focusing on the effect of increasing polynomial order. I’m comparing three different solvers:
For relevancy of the testcase, I am considering a 3D domain (cube) and I added an advective term to the stokes equation to mimick a Newton iteration in a Navier-Stokes solve. I’ve added the code below.
For weak scaling I obtain:
with wall-clock runtime of the solve step on the y-axis, and DOF-count on the x-axis. Each marker corresponds to an increase in core numbers: 1, 2, 4, 8, 16, 32 and 48. I’ve tried to stick to roughly 100k dofs per core.
For the higher-order cases, the runtime was severely limited by the assembly/integration and not by the solve. This implies strong scaling is more important:
with on the x-axis number of cores. It doesn’t appear to scale so great, but that’s due to the limited number of 800k dofs. I’m just happy to see that GMRes outperforms mumps in all cases.
Here is the code:
import os
from dolfinx.fem.petsc import assemble_matrix, assemble_vector, NonlinearProblem, LinearProblem
import time
import pickle
def main(outputdir:str = "", # Directory for storing output
         CASE:int = 0, # 0: MUMPS, 1: GMRes with block diagonal precon, 2: GMRes with block Schur precon
         Re:float = 10, # Reynolds number. With using domainsize and unit advective velocity, this is 1/nu
         N:int =  10, # Elements in x & y
         Pu:int = 2, # Polynomial order u
         Pp:int = 1, # Polynomial order p
     # Function space
     L = 1 # Domain size
     domain = mesh.create_box(MPI.COMM_WORLD, [(0,0,0),(L,L,L)], [N,N,N], mesh.CellType.hexahedron)
     u, p = ufl.split(w_trial)
     # Physical parameters
     u_adv = fem.Function(V) # Dummy advection velocity, to mimic a Navier-Stokes solve
     u_adv.interpolate( lambda x: ( np.sin(2*np.pi*x[0,:]/L)*np.cos(2*np.pi*x[1,:]/L)*np.sin(np.pi*x[2,:]/L), \
                                   -np.cos(2*np.pi*x[0,:]/L)*np.sin(2*np.pi*x[1,:]/L)*np.sin(np.pi*x[2,:]/L),
                                    0*x[0,:] )   )
     # Linearized Navier-Stokes weak form
     B = inner( dot(u_adv,nabla_grad(u)), v )*dx \
       + inner( 2*nu*sym(nabla_grad(u)), sym(nabla_grad(v)) )*dx \
       - dot( q, div(u) )*dx \
     F = dot( q, fem.Constant(domain, PETSc.ScalarType(0)) )*dx
     P = inner( dot(u_adv,nabla_grad(u)), v )*dx \
       + dot( 1/nu*q, p )*dx
     def node_origin(x):
          return np.logical_and(np.isclose(x[0],0),np.logical_and(np.isclose(x[1],0),np.isclose(x[2],0)))
     def walls(x):
          return np.isclose(x[0],0) | np.isclose(x[0], L) | np.isclose(x[1],0) | np.isclose(x[2], 0) | np.isclose(x[2], L)
     def lid(x):
     u_unit.interpolate(lambda x: (np.ones(x.shape[1]),np.zeros(x.shape[1]),np.zeros(x.shape[1])) )
     # Assemble matrices
     Bmat = assemble_matrix(fem.form(B), bcs=bcs)
     Bmat.assemble()
     Pmat = assemble_matrix(fem.form(P), bcs=bcs)
     Pmat.assemble()
     Fvec = assemble_vector(fem.form(F))
     fem.petsc.apply_lifting(Fvec, [fem.form(B)], bcs=[bcs])
     Fvec.ghostUpdate(addv=PETSc.InsertMode.ADD, mode=PETSc.ScatterMode.REVERSE)
     fem.petsc.set_bc(Fvec, bcs)
     ksp = PETSc.KSP().create(domain.comm)
     if CASE == 1:
          ksp.setOperators(Bmat, Pmat)
          ksp.setOperators(Bmat)
     if CASE == 0:
          # Direct solve
          # GMRes with block-based preconditioning
          localdofs_u = np.setdiff1d( W_indexmap.local_to_global(np.array(WV_map)), W_indexmap.ghosts ) # getting the global velocity dofs that live on this core
          localdofs_p = np.setdiff1d( W_indexmap.local_to_global(np.array(WQ_map)), W_indexmap.ghosts ) # getting the global pressure dofs that live on this core
          IS_u = PETSc.IS().createGeneral(np.array(localdofs_u,dtype=np.int32), comm=domain.comm).sort()
          IS_p = PETSc.IS().createGeneral(np.array(localdofs_p,dtype=np.int32), comm=domain.comm).sort()
          pc = ksp.getPC()
          if CASE == 1:
               # Block-diagonal precondition, AMG on velocity, Jacobi on pressure mass
               pc.setFieldSplitType(PETSc.PC.CompositeType.ADDITIVE)
          elif CASE == 2:
               # Schur-based precondition, AMG on velocity, Jacobi on Schur complement.
          opts[f"{option_prefix_u}pc_type"] = "hypre" # Hypre (algebraic multigrid) preconditioning for p-block
          opts[f"{option_prefix_u}pc_hypre_type"] = "boomeramg" # Choice of implementation
          opts[f"{option_prefix_u}pc_hypre_boomeramg_coarsen_type"] = "pmis" # Grid coarsening strategy
          opts[f"{option_prefix_u}pc_hypre_boomeramg_interp_type"] = "FF1" # Projection on to coarser grid
          opts[f"{option_prefix_u}pc_hypre_boomeramg_strong_threshold"] = "0.5" # Coarsening limit
          opts[f"{option_prefix_p}pc_type"] = "jacobi"
     start = time.time()
     ksp.solve(Fvec, u_p.x.petsc_vec)
     end = time.time()
     u_sol,p_sol = [ f.collapse() for f in u_p.split() ]
     uL2 = fem.assemble_scalar( fem.form(ufl.inner(u_sol, u_sol) * ufl.dx) )
     uL2 = domain.comm.allreduce(uL2, op=MPI.SUM)
     if MPI.COMM_WORLD.rank == 0:
          print('runtime:', end - start)
          print('dofs:', (N*Pu-1)**3*3+(N*Pp+1)**3)
          print('L2 norm:', uL2)
          postprocessing_data = {'case':CASE,'Re':Re,'N':N,'Pu':Pu,'Pp':Pp,'time':float(end-start),'dofs':(N*Pu-1)**3*3+(N*Pp+1)**3}
          with open(outputdir+'/postprocessdata.pickle', 'wb') as handle:
               pickle.dump(postprocessing_data, handle, protocol=pickle.HIGHEST_PROTOCOL)
While the Schur-based preconditioner performs quite well, it doesn’t show perfect weak scaling. I believe that is to be expected due to the ‘selfp’ option. Better would be to combine the two iterative approaches; approximate the Schur complement with the pressure mass matrix, while retaining the ‘upper’ block. That should give near-perfect (weak) scaling. I believe this is done in:
Those implementations are a bit too invasive for me now, but if someone is interested in implementing a light-weight version thereof I’d be interested to be kept in the loop.
