Problem in mixed-function space boundary conditions for stokes equation
Hello Everyone,
I am trying to understand the mixed function spaces implementation in the context of stokes problem. I am using Taylor-Hood elements. I have followed the Mixed formulation for the Poisson equation demo from the fenicsx documentation for setting up spaces, bcs etc. However, I am getting inf solution for velocity and pressure everywhere. It should atleast be equal to the applied boundary condition values at the Dirichlet dofs. I checked my identified degrees of freedom for velocity and pressure, which seems correct. Can someone point out what I might be missing?
from dolfinx import fem, mesh, io, geometry
# Create mesh
domain = mesh.create_unit_square(MPI.COMM_WORLD, 1, 1)
# Taylor-Hood elements (P2-P1)
P2 = element("Lagrange", domain.basix_cell(), 2, shape=(2,))  # Vector element for velocity
P1 = element("Lagrange", domain.basix_cell(), 1)              # Scalar element for pressure
TH = mixed_element([P2, P1])
W = fem.functionspace(domain, TH)
# Get subspace of V
V0 = W.sub(0)
Q0 = W.sub(1)
V, V_to_W = W.sub(0).collapse()
Q, Q_to_W = W.sub(1).collapse()
(v, q) = ufl.TestFunctions(W)  # Test functions
# Define manufactured solution
u_exact = ufl.as_vector([
    ufl.sin(2 * np.pi * x[0]) * ufl.cos(2 * np.pi * x[1]),
    -ufl.cos(2 * np.pi * x[0]) * ufl.sin(2 * np.pi * x[1])])
p_exact = ufl.sin(2 * np.pi * x[0]) * ufl.sin(2 * np.pi * x[1])
# Create a Function to hold the exact solution
u_exact_func = fem.Function(V)
u_exact_func.interpolate(lambda x: np.array([
    np.sin(2 * np.pi * x[0]) * np.cos(2 * np.pi * x[1]),
    -np.cos(2 * np.pi * x[0]) * np.sin(2 * np.pi * x[1])
], dtype=np.float64))
# Apply boundary conditions
facets = mesh.locate_entities_boundary(domain, 1, lambda x: np.full(x.shape[1], True))
dofs_V = fem.locate_dofs_topological((V0, V), 1, facets)
print("velocity essential dofs", dofs_V)
bc = fem.dirichletbc(u_exact_func, dofs_V, V0)
# Fix pressure at one point to remove null space
# Find a point (e.g., first vertex)
def is_corner(x, tol=1e-5):
    return np.logical_and(np.isclose(x[0], 0.0, atol=tol),
                          np.isclose(x[1], 0.0, atol=tol))
corner = mesh.locate_entities_boundary(domain, 0, is_corner)
pressure_dof = fem.locate_dofs_topological((Q0, Q), 0, corner)
print("pressure essential dofs", pressure_dof)
# Create pressure constraint
zero = fem.Function(Q)
zero.interpolate(lambda x: np.array([0.0], dtype=np.float64))
bc_p = fem.dirichletbc(zero, pressure_dof, Q0)
# Combine BCs
bcs = [bc, bc_p]
# Compute f = -νΔu + ∇p
ν = 1.0
f = -ν * ufl.div(ufl.grad(u_exact)) + ufl.grad(p_exact)
a = ν * ufl.inner(ufl.grad(u), ufl.grad(v)) * ufl.dx - p * ufl.div(v) * ufl.dx - q * ufl.div(u) * ufl.dx
L = ufl.inner(f, v) * ufl.dx
# Solve
wh = fem.Function(W)
problem = fem.petsc.LinearProblem(a, L, bcs= bcs,
                                petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
wh = problem.solve()
uh, ph = wh.sub(0), wh.sub(1)  # Split solution
print(uh.x.array)
print(ph.x.array)
## Verify solution
print("Velocity min/max:", np.min(uh.x.array), np.max(uh.x.array))
print("Pressure min/max:", np.min(ph.x.array), np.max(ph.x.array))
# Compute errors
error_u = fem.assemble_scalar(fem.form(ufl.inner(uh - u_exact, uh - u_exact) * ufl.dx)) ** 0.5
error_p = fem.assemble_scalar(fem.form((ph - p_exact)**2 * ufl.dx)) ** 0.5
print(f"Taylor-Hood errors: u_L2 = {error_u:.2e}, p_L2 = {error_p:.2e}")
The output looks like this.
velocity dofs [array([ 0,  1,  2,  3,  4,  5,  6,  7, 10, 11, 15, 16, 17, 18, 19, 20],
      dtype=int32), array([ 6,  7,  0,  1,  8,  9,  2,  3,  4,  5, 12, 13, 14, 15, 16, 17],
      dtype=int32)]
pressure dofs [array([12], dtype=int32), array([0], dtype=int32)]
[inf inf inf inf inf inf inf inf inf inf inf inf inf inf inf inf inf inf
 inf inf inf inf]
 inf inf inf inf]
Velocity min/max: inf inf
Pressure min/max: inf inf
Taylor-Hood errors: u_L2 = nan, p_L2 = inf
First, I would say: Stokes equations using Taylor-Hood elements — DOLFINx 0.9.0 documentation
would give you some hints.
The first is tuning the LU-solver.
I would use:
    a,
    L,
    bcs=bcs,
    petsc_options={
        "pc_type": "lu",
        "ksp_error_if_not_converged": True,
        "mat_mumps_icntl_24": 1,
        "mat_mumps_icntl_25": 0,
I would also increase the mesh-size from 1x1 to say 10x10.
Finally, for looking at the values of the solution, I would do:
uh, ph = wh.sub(0).collapse(), wh.sub(1).collapse()  # Split solution
## Verify solution
Complete code:
# Create mesh
domain = mesh.create_unit_square(MPI.COMM_WORLD, 10, 10)
P2 = element(
# Get subspace of V
V0 = W.sub(0)
Q0 = W.sub(1)
        -ufl.cos(2 * np.pi * x[0]) * ufl.sin(2 * np.pi * x[1]),
    lambda x: np.array(
            -np.cos(2 * np.pi * x[0]) * np.sin(2 * np.pi * x[1]),
        dtype=np.float64,
        np.isclose(x[0], 0.0, atol=tol), np.isclose(x[1], 0.0, atol=tol)
# Combine BCs
bcs = [bc, bc_p]
ν = 1.0
a = (
# Solve
    a,
    L,
    bcs=bcs,
    petsc_options={
        "pc_type": "lu",
print(uh.x.array)
print(ph.x.array)
## Verify solution
# Compute errors
error_u = (
error_p = fem.assemble_scalar(fem.form((ph - p_exact) ** 2 * ufl.dx)) ** 0.5
with dolfinx.io.VTXWriter(
    MPI.COMM_WORLD,
    "output.bp",
    [uh],
) as vtk:
    vtk.write(0.0)
with output
Velocity min/max: -1.0 1.0
Pressure min/max: -0.9241271481311483 1.020048274066652
Taylor-Hood errors: u_L2 = 3.15e-03, p_L2 = 5.05e-02
Hi @dokken, thanks for your help. It works.
However, something really weird is happening. I ran the code once, and I get the same results as yours. When, I ran the same code again, the results are different and near inf. Does it imply faulty installation?
Are you now talking about the pressure, or both pressure and velocity?
Both pressure and velocity. The output is as follows:
Velocity min/max: -3.086480136725926e+154 8.394637962972945e+153
Pressure min/max: 5.262859580023891e+170 5.262859580023954e+170
Taylor-Hood errors: u_L2 = inf, p_L2 = inf
If I restart the computer and run the code, the solution is correct for the first time. If I rerun it, I am getting the above garbage solution.
Are you running with all the options:
        "pc_type": "lu",
from
as I would expect PETSc to complain if you hit these limits.
Edit:
I also occupationally see “mumps” struggle with this system.
What you could do is to remove the “pressure” bc, and set the constant pressure nullspace:
import dolfinx.fem.petsc
# Create mesh
P2 = element(
# Get subspace of V
V0 = W.sub(0)
Q0 = W.sub(1)
    lambda x: np.array(
        dtype=np.float64,
# Combine BCs
bcs = [bc]
ν = 1.0
a = (
# Solve
    a,
    L,
    bcs=bcs,
    petsc_options={
        "pc_type": "lu",
nsp = PETSc.NullSpace().create(constant=True)
problem.A.setNullSpace(nsp)
print(uh.x.array)
print(ph.x.array)
## Verify solution
# Compute errors
error_u = (
    MPI.COMM_WORLD,
    "output.bp",
    [uh],
) as vtk:
    vtk.write(0.0)
Alternatively, change the options to;
  petsc_options={
        "pc_type": "lu",
which gives me a constant solution (here you would need to normalize the pressure after the fact).
Setting the constant pressure nullspace works. However, I was avoiding it as I plan to extend this to NS equations, where I will use nonlinear solver. I am not sure how nullspace works with nonlinear problems, if it works at all.
Still, the unusual behavior of mumps is puzzling.
Inspecting the output with:
        "mat_mumps_icntl_4": 3,
I observe that the major difference between a working and failing simulation is:
 ****** SOLVE & CHECK STEP ********
 GLOBAL STATISTICS PRIOR SOLVE PHASE ...........
 Number of right-hand-sides                    =           1
 Blocking factor for multiple rhs              =           1
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           0
  --- (30)                                     =           0
  --- (35)                                     =           0
  --- (48) (effective)                         =           0
 Vector solution for column            1
 RHS
  -9.510565D-01  8.365346D-18 -2.449294D-16  2.707083D-17 -7.568733D-17
  -9.510565D-01 -1.981520D-16 -5.877853D-01  1.130382D+38 -1.651398D+38
and
Entering DMUMPS 5.7.3 from C interface with JOB, N, NNZ =   3         278           7234
      executing #MPI =      1, without OMP
 ICNTL (9)                                     =           1
  --- (10)                                     =           0
  --- (11)                                     =           0
  --- (20)                                     =           0
  --- (21)                                     =           0
  --- (30)                                     =           0
  --- (35)                                     =           0
 RHS
  -9.510565D-01 -1.981520D-16 -5.877853D-01 -4.669933D-01 -4.669933D-01
 ** Space in MBYTES used for solve                        :         0
which can be traced back to a difference in the RHS.
This is due to:
which is not correct.
It should be:
zero.interpolate(lambda x: np.zeros_like(x[1], dtype=np.float64))
I am suprised the code above actually doesn’t throw an error.
Thanks @dokken for your help.
