I have been running a reaction-diffusion problem which is getting quite large. Before deploying it on an HPC, I played around with a few cores on my laptop but noticed that running time increases substantially with increasing number of cores used.
I have looked at the similar discussion topics below but could not solve my issue.
https://fenicsproject.discourse.group/t/mumps-in-parallel-slower-than-in-serial/662
https://fenicsproject.discourse.group/t/fenics-mpi-on-docker-inefficient/3510
Also, I get the following warning: [WARNING] yaksa: 3 leaked handle pool objects. I don’t understand it.
Would you have any suggestion as to how to reduce the computational time?
I am running dolfinx in a Singularity container.
I have reproduced the issue with the minimal example below (1 core= 24 sec, 2 cores=49 sec, 3 cores: 102 sec )
Many thanks for your help!
L = 1
W = 0.2
diffusion_time_step=0.1
end_time=10
simu_start_time=0
from dolfinx import mesh, fem, plot, io
from dolfinx.fem import FunctionSpace,VectorFunctionSpace, Function,TensorFunctionSpace, Constant
from ufl import TestFunction, TrialFunction, dx, inner,grad, Measure,derivative,system
import time
startT = time.time()
domain = mesh.create_box(MPI.COMM_WORLD, [np.array([0,0,0]), np.array([L, W, W])],
[20,20,20], cell_type=mesh.CellType.hexahedron)
V=VectorFunctionSpace(domain, ("CG", 1), dim=3)
p = TestFunction(V)
prc_prev = Function(V)
prc = TrialFunction(V)
prc_mid = 0.5*(prc + prc_prev)
dt=Constant(domain, diffusion_time_step)
D_p = Constant(domain,2.4e3)
D_pr = Constant(domain,2.4e-15)
kap = Constant(domain,1e5)
kdp = Constant(domain,1.86e-3)
psi_p = Constant(domain,0.01)
psi_pr = Constant(domain,1e-50)
psi_cp = Constant(domain,1e-15)
# Supply term
def sup_func(x):
return np.exp(-100*(x[0]%0.1+x[1]%0.1+x[2]%0.1))
p_i = Function(V.sub(0).collapse()[0])
p_i.interpolate(sup_func)
p_sup = p_i
# Variational problem
F = (
(- (prc[0] - prc_prev[0])*p[0]
- (prc[1] - prc_prev[1])*p[1]
- (prc[2] - prc_prev[2])*p[2])*dx()
+ (- dt*inner(D_p*grad(prc_mid[0]), grad(p[0])))*dx()
+ (+ dt*p_sup*p[0])*dx()
+ (+ dt*(- kap*prc_prev[0]*prc_mid[1]*p[0]
- kap*prc_mid[0]*prc_prev[1]*p[1]
+ kap*prc_prev[0]*prc_prev[1]*p[2]
+ kdp*prc_prev[2]*p[0]
+ kdp*prc_prev[2]*p[1]
- kdp*prc_mid[2]*p[2]))*dx()
+ (+ dt*(- psi_p*prc_mid[0]*p[0]
- psi_pr*prc_mid[1]*p[1]
- psi_cp*prc_mid[2]*p[2]))*dx()
# Create boundary condition
tdim = V.mesh.topology.dim
fdim = tdim - 1
boundary_facets = mesh.exterior_facet_indices(V.mesh.topology)
fixed_dofs_0 = fem.locate_dofs_topological(V.sub(0), fdim, boundary_facets)
fixed_dofs_1 = fem.locate_dofs_topological(V.sub(1), fdim, boundary_facets)
fixed_dofs_2 = fem.locate_dofs_topological(V.sub(2), fdim, boundary_facets)
bc0 = fem.dirichletbc(PETSc.ScalarType(0), fixed_dofs_0, V.sub(0))
bc1 = fem.dirichletbc(PETSc.ScalarType(0), fixed_dofs_1, V.sub(1))
bc2 = fem.dirichletbc(PETSc.ScalarType(0), fixed_dofs_2, V.sub(2))
# Define problem
(a, L) = system(F)
problem=fem.petsc.LinearProblem(a, L, bcs=[bc0,bc1,bc2],petsc_options={"ksp_type": "cg", "ksp_rtol":1e-8, "ksp_atol":1e-8})
# Solve problem
simu_time=simu_start_time
while simu_time < end_time:
prc = problem.solve()
prc.x.scatter_forward()
prc_prev.x.array[:]=prc.x.array
simu_time += dt.value
endT = time.time()
print("The time of execution of above program is :",(endT-startT),flush=True)
