Problem with building a RHS vector containing conditional statements for boundary conditions
Good day everyone,
I am trying to build a right hand side vector where I need to use a conditional statement to exclude a possible “divide by zero” condition. The key code elements are the Hinc class at the beginning and the “Build RHS” segment at the end of the code snippet. Code follows:
import sys
from scipy import optimize as opt
from scipy import special as sp
from mpi4py import MPI as nMPI
import basix.ufl
from dolfinx.mesh import locate_entities_boundary, meshtags
from dolfinx.io import gmshio
from dolfinx import fem
from dolfinx import io
eps = 1.0e-4 # global geometric tolerance
# Incident field
class Hinc:
    def __init__(self, b, kc, H):
        self.beta = b
        self.kc = kc
        self.H = H
    def eval(self, x):
        rr = np.sqrt(x[0] * x[0] + x[1] * x[1])
        s = ufl.conditional(ufl.gt(rr, eps), x[1]/rr, 0.0)
        c = ufl.conditional(ufl.gt(rr, eps), x[0]/rr, 1.0)
        hphi = ufl.conditional(ufl.gt(rr, eps), 1j * self.beta * self.H * sp.jvp(1, rr, 0) * s / (self.kc * self.kc * rr), 0.0)
        hr = -1j * self.beta * self.H * sp.jvp(1, rr, 1) * c / self.kc
        hz = np.full_like(hr, 0.0+0j, dtype=np.complex128)
        hx = hr * c - hphi * s
        hy = hr * s + hphi * c
        return(hx, hy, hz)
def Model(x):
    comm = nMPI.COMM_WORLD
    mpiRank = comm.rank
    modelRank = 0 # where GMSH runs
    a = x[0] # Waveguide radius
    h = x[1] # horn length
    b = x[2] # horn mouth radius
    wl1 = 1.0
    wl2 = 1.0 # waveguide lengths
    r = 6.0 # rad sphere radius
    t = 0.1 # WG thickness
    Plot = 1
    k = 2.0 * np.pi * x[3] / 3.0e10 # k0 as a function of frequency
    eta0 = 377.0
    kc = 1.84 / a
    beta = np.sqrt(k * k - kc * kc)
    lm = 0.3
    ls = 0.025
    if mpiRank == modelRank:
        print("Waveguide radius = {0:<f}, Horn length = {1:<f}, Horn radius = {2:<f}, Freq = {3:<f}".format(a, h, b, x[3]))
        gmsh.option.setNumber('General.Terminal', 1)
        gmsh.model.add('Feed Horn')
        #Rad hemisphere
        gmsh.model.occ.addSphere(0, 0, 0, r, 1)
        gmsh.model.occ.addBox(-r, -r, 0, 2*r, 2*r, r, 2)
        gmsh.model.occ.intersect([(3,1)], [(3,2)], 3, removeObject=True, removeTool=True)
        # Stick short waveguide on bottom
        gmsh.model.occ.addCylinder(0, 0, -wl2, 0, 0, wl2, a, 2, 2.0*np.pi)
        gmsh.model.occ.fuse([(3,3)], [(3,2)], 1, removeObject=True, removeTool=True)
        # Make cutout for horn geometry
        gmsh.model.occ.addCylinder(0, 0, 0, 0, 0, wl1+h, b+t, 2, 2.0*np.pi)
        gmsh.model.occ.addCylinder(0, 0, 0, 0, 0, wl1, a, 3, 2.0*np.pi)
        gmsh.model.occ.addCone(0, 0, wl1, 0, 0, h, a, b, 4, 2.0*np.pi)
        gmsh.model.occ.cut([(3,2)], [(3,3), (3,4)], 5, removeObject=True, removeTool=True)
        gmsh.model.occ.cut([(3,1)], [(3,5)], 6, removeObject=True, removeTool=True)
        # Let's only model 1/4 of the geometry to reduce compute needs.
        gmsh.model.occ.addBox(0, 0, -wl2, r, r, r+wl2, 2)
        gmsh.model.occ.intersect([(3,6)], [(3,2)], 1, removeObject=True, removeTool=True)
        gmsh.model.occ.synchronize()
        pt = gmsh.model.getEntities(dim=0)
        gmsh.model.mesh.setSize(pt, lm)
        pt = gmsh.model.getEntitiesInBoundingBox(-eps, -eps, wl1+h-eps, b+t+eps, b+t+eps, wl1+h+eps)
        gmsh.model.mesh.setSize(pt, ls)
        pt
        gmsh.option.setNumber('Mesh.MeshSizeMin', 0.01)
        gmsh.option.setNumber('Mesh.MeshSizeMax', 1.2)
        gmsh.option.setNumber('Mesh.Algorithm', 6) #1=Mesh Adapt, 2=Auto, 3=Initial mesh only, 5=Delaunay, 6=Frontal-Delaunay
        gmsh.option.setNumber('Mesh.MshFileVersion', 2.2)
        gmsh.option.setNumber('Mesh.Format', 1)
        gmsh.option.setNumber('Mesh.MinimumCirclePoints', 30)
        gmsh.option.setNumber('Mesh.CharacteristicLengthFromCurvature', 1)
        gmsh.option.setNumber('Mesh.Tetrahedra', 0)
        bb = gmsh.model.getEntities(dim=3)
        pt = gmsh.model.getBoundary(bb, combined=True, oriented=False, recursive=False)
        CoaxPort = []
        RAD = []
        PMC = []
        PEC = []
        for bnd in pt:
            CoM = gmsh.model.occ.getCenterOfMass(bnd[0], bnd[1])
            print(CoM)
            if np.abs(CoM[2] + wl2) < eps:
                CoaxPort.append(bnd[1])
            elif np.abs(CoM[0]) < eps:
                PMC.append(bnd[1])
            elif (np.abs(CoM[2]) > wl1 + h + eps) and (np.abs(CoM[0]) > eps) and (np.abs(CoM[1]) > eps):
                RAD.append(bnd[1])
                PEC.append(bnd[1])
        gmsh.model.addPhysicalGroup(3, [1], 1) # rad zone
        gmsh.model.setPhysicalName(3, 1, "RadZone")
        gmsh.model.addPhysicalGroup(2, PEC, 1)
        gmsh.model.setPhysicalName(2, 1, "PEC")
        gmsh.model.addPhysicalGroup(2, PMC, 2)
        gmsh.model.setPhysicalName(2, 2, "PMC")
        gmsh.model.addPhysicalGroup(2, CoaxPort, 3)
        gmsh.model.setPhysicalName(2, 3, "In Port")
        gmsh.model.addPhysicalGroup(2, RAD, 4)
        gmsh.model.setPhysicalName(2, 4, "Rad Surface")
        gmsh.model.mesh.generate(3)
    mesh, ct, fm = gmshio.model_to_mesh(gmsh.model, comm, modelRank, gdim=3)
        gmsh.finalize()
    elem = basix.ufl.element('Nedelec 1st kind H(curl)', mesh.basix_cell(), degree=2)
    V = fem.functionspace(mesh, elem)
    u = ufl.TrialFunction(V)
    n = ufl.FacetNormal(mesh)
    ds = ufl.Measure("ds", domain=mesh, subdomain_data=fm)
# Dirichlet BCs on PECs
    facets = fm.find(1)
    ubc = fem.Function(V)
    ubc.interpolate(lambda x:np.array([0*x[0], 0*x[1], 0*x[2]], dtype=np.complex128))
    dofs = fem.locate_dofs_topological(V, mesh.topology.dim-1, facets)
    bc = fem.dirichletbc(ubc, dofs)
# Build RHS
    uh = fem.Function(V, dtype=np.complex128)
    f = Hinc(beta, kc, 1.0+0j)
    uh.interpolate(f.eval)
    finc = 2.0j * k0 * eta0 * ufl.inner(ufl.cross(n, uh), v) * ds(3)
    uh.name = "Hinc"
    return 0
x=np.array([1.115, 1.0, 2.23, 1.0e10])
e = Model(x)
print(e)
sys.exit(0)
I know that I am doing something wrong in the UFL conditional statements. How do I do the testing correctly? I get the following error.
  File "/usr/lib/petscdir/petsc3.15/x86_64-linux-gnu-complex/lib/python3/dist-packages/dolfinx/fem/function.py", line 459, in interpolate
    _interpolate(u0)
  File "/usr/lib/python3.10/functools.py", line 889, in wrapper
  File "/usr/lib/petscdir/petsc3.15/x86_64-linux-gnu-complex/lib/python3/dist-packages/dolfinx/fem/function.py", line 440, in _interpolate
    self._cpp_object.interpolate(u0, cells0, cells1)  # type: ignore
TypeError: interpolate(): incompatible function arguments. The following argument types are supported:
    1. interpolate(self, f: ndarray[dtype=complex128, shape=(*), order='C', writable=False], cells: ndarray[dtype=int32, shape=(*), order='C', writable=False]) -> None
    2. interpolate(self, f: ndarray[dtype=complex128, shape=(*, *), order='C', writable=False], cells: ndarray[dtype=int32, shape=(*), order='C', writable=False]) -> None
    3. interpolate(self, u: dolfinx.cpp.fem.Function_complex128, cells0: ndarray[dtype=int32, shape=(*), order='C', writable=False], cells1: ndarray[dtype=int32, shape=(*), order='C', writable=False]) -> None
    4. interpolate(self, u: dolfinx.cpp.fem.Function_complex128, cells: ndarray[dtype=int32, shape=(*), order='C', writable=False], interpolation_data: dolfinx.cpp.geometry.PointOwnershipData_float64) -> None
    5. interpolate(self, e0: dolfinx.cpp.fem.Expression_complex128, cells0: ndarray[dtype=int32, order='C', writable=False], cells1: ndarray[dtype=int32, order='C', writable=False]) -> None
Invoked with types: dolfinx.cpp.fem.Function_complex128, method, ndarray, ndarray
  File "/home/bill/Cluster/Fenics2020/FeedHorn/SimpleCircHorn.py", line 194, in <module>
    _interpolate(u0)
    e = Model(x)
  File "/home/bill/Cluster/Fenics2020/FeedHorn/SimpleCircHorn.py", line 154, in Model
    _interpolate(u0)
    e = Model(x)
EDIT:
I found the error. I fell into the rabbit hole of mixing Numpy and UFL! It turns out I needed to use the generalized conditional “numpy.where” for Numpy arrays in the Hinc function like so:
class Hinc:
        self.beta = b
        self.kc = kc
        self.H = H
    def eval(self, x):
        s = np.where(rr > eps, x[1]/rr, 0.0)
        c = np.where(rr > eps, x[0]/rr, 1.0)
        hphi = np.where(rr > eps, 1j * self.beta * self.H * sp.jvp(1, rr, 0) * s / (self.kc * self.kc * rr), 0.0)
        return(hx, hy, hz)
The code now runs fine! Cheers!
