Hello everyone,
I’m having an issue when I try to use an orthonormal basis of vectors. I will be using these vectors as fiber directions in a nonlinear solid mechanics problem. For example, let’s consider a 2D domain, where I have defined two orthonormal directions \vec f and \vec s. Then I can build a tensor using these vectors as:
G = \gamma_f \vec f \otimes \vec f + \gamma_s \vec s \otimes \vec s
If \gamma_f = \gamma_s = 1, G should be equal to the identity. The problem is that I’m not getting that with Fenics, which is causing me trouble because, for example, if I don’t put any loads to a problem I still get a non-zero residual. I track the error to this. Here is a MEW:
import dolfin as d
mesh = d.RectangleMesh(d.Point(-5, -5), d.Point(5, 5), 5, 5)
V = d.VectorFunctionSpace(mesh, 'DG', 2)
N1 = d.Expression(('cos(x[0])/sqrt(pow(cos(x[0]), 2) + pow(sin(x[1]), 2))', 'sin(x[1])/sqrt(pow(cos(x[0]), 2) + pow(sin(x[1]), 2))'), element = V.ufl_element())
N2 = d.Expression(('-sin(x[1])/sqrt(pow(cos(x[0]), 2) + pow(sin(x[1]), 2))', 'cos(x[0])/sqrt(pow(cos(x[0]), 2) + pow(sin(x[1]), 2))'), element = V.ufl_element())
N1 = d.project(N1, V)
N2 = d.project(N2, V)
d.File('testN1.pvd') << N1
d.File('testN2.pvd') << N2
T = d.TensorFunctionSpace(mesh, 'DG', 2)
I_df = d.outer(N1, N1) + d.outer(N2, N2)
F = d.dot(I_df, I_df)
I_df_ = d.project(I_df, T)
F = d.project(F, T)
print(I_df_.vector().get_local().reshape([-1,2,2]))
for i in range(N1.vector().get_local().reshape([-1,2]).shape[0]):
n1 = N1.vector().get_local().reshape([-1,2])[i]
n2 = N2.vector().get_local().reshape([-1,2])[i]
if np.abs(np.dot(n1,n2)) > 1e-12: # Check that the vectors are perpendicular
print(i)
if np.abs(np.dot(n1, n1) - 1) > 1e-12:
print(i)
if np.abs(np.dot(n2, n2) - 1) > 1e-12:
print(i)
I_np = np.outer(n1,n1) + np.outer(n2,n2)
The output is
[[[ 1.07626026e+00 -5.71851283e-16]
[-5.71851283e-16 1.07626026e+00]]
[[ 7.36428348e-01 -1.67397705e-17]
[-1.67397705e-17 7.36428348e-01]]
[[ 7.55745073e-01 -1.67397705e-17]
[-1.67397705e-17 7.55745073e-01]]
[[ 1.07723900e+00 -1.52486776e-16]
[-1.52486776e-16 1.07723900e+00]]
[[ 1.04033445e+00 1.93728740e-17]
[ 1.93728740e-17 1.04033445e+00]]
[[ 1.07945641e+00 2.66692601e-17]
[ 2.66692601e-17 1.07945641e+00]]]
which is not the identity anywhere. I checked that the vectors at the nodes were orthonormal in the nodes and they are. I’m using a DG element of second degree because that’s what I need to use in further applications. If I refine the mesh it does get better, however, I won’t be able to do that in a bigger problem. I’m thinking that when fenics projects is evaluating the vector functions in the quadrature points, where, because of the interpolation, they might not be orthonormal. Is there a way to enforce orthonormality everywhere in the functions? I’m using docker with the development version of fenics.
Thank you in advance!
