Problem with project in 3D
Hi everyone,
I have developed a model in 2D CFD model in FEniCS which works fine, now I am trying it on 3D geometries. However, in 3D I get an error in the following lines of script, which has to do with the project() function:
velocity_degree = 2
V_X2V= VectorFunctionSpace(mesh, 'CG', velocity_degree)
SM = Function(V_X2V)
SM0 = Constant((0,)*mesh.geometry().dim())
# if tstep = 1
    body_force = project(SM0, V_X2V)
# else
    body_force = project(SM, V_X2V)
If tstep is not 0, SM is a function that varies over the nodes. For both the project() lines I get the following error:
Error: Unable to successfully call PETSc function 'KSPSolve'
Reason: PETSc error code is: 76 (Error in external library)
Where: This error was encountered inside /build/dolfin-fyfCiA/dolfin-2017.2.0.post0/doolfin/la/PETScKrylovSolver.cpp
I already tried to change project() to interpolate(), but this only works for tstep=0. For body_force = interpolate(SM, V_X2V) I get:
TypeError: in method 'Function_interpolate', argument 2 of type 'dolfin::GenericFunction const &'
Does anyone know what I am doing wrong, and how to fix/workaround this?
Thanks in advance!
It could be that the solver is running out of memory in 3D. I believe the default is a direct solver, which I try to avoid in 3D. Try specifying an iterative solver, e.g.,
N = 10
mesh = UnitCubeMesh(N,N,N)
V = VectorFunctionSpace(mesh,"CG",1)
d = mesh.geometry().dim()
u = project(Constant(d*(1,)),V,
            solver_type="cg",preconditioner_type="jacobi")
