Problem with read a external mesh
Hi everyone.
I’m trying to read a mesh generated by Ansys in FEniCSx. The mesh is in .msh. I change the format with
meshio convert fluent.msh venturi_1600.xdmf
but when I try to open
##########################################################################################################3
    # Read the mesh
with dolfinx.io.XDMFFile(MPI.COMM_WORLD, "venturi_1600.xdmf", "r") as xdmf:
    domain = xdmf.read_mesh(name='Grid')
I obtain
Cell In[2], line 5
      1 import dolfinx
      4 with dolfinx.io.XDMFFile(MPI.COMM_WORLD, "venturi_1600.xdmf", "r") as xdmf:
----> 5     domain = xdmf.read_mesh(name='Grid')
      7 tdim = domain.topology.dim
      8 tree = dolfinx.geometry.BoundingBoxTree(domain, tdim)
File /usr/lib/petsc/lib/python3/dist-packages/dolfinx/io/utils.py:154, in XDMFFile.read_mesh(self, ghost_mode, name, xpath)
    152 def read_mesh(self, ghost_mode=GhostMode.shared_facet, name="mesh", xpath="/Xdmf/Domain") -> Mesh:
    153     """Read mesh data from file"""
--> 154     cell_shape, cell_degree = super().read_cell_type(name, xpath)
    155     cells = super().read_topology_data(name, xpath)
    156     x = super().read_geometry_data(name, xpath)
RuntimeError: Cannot recognise cell type. Unknown value: mixed
but the mesh has a unique element (Quadrilateral).
I can export the mesh with different formats:
The mesh is in this folder:
Does anyone has a idea to solve?
Thank you so much!
See: Can dolfinx read a GMSH file containing 1D mesh of an ellipse? - #2 by dokken
I have tried that code with the following change:
meshio.write("venturi_1600.xdmf, create_mesh, (mesh, "quadrilateral", True))
and I get the next error
KeyError: 'quadrilateral'
I find the name of elements here:
https://fenicsproject.org/olddocs/dolfinx/dev/python/generated/dolfinx.cpp.mesh.html
This does not make sense, it should be:
meshio.write("venturi_1600.xdmf, create_mesh(mesh, "quad", True))
if mesh is a meshio mesh.
See https://github.com/nschloe/meshio/blob/0138cc8692b806b44b32d344f7961e8370121ff7/src/meshio/_mesh.py#L14
Thank you @dokken, but now I try
    out_mesh = meshio.Mesh(points=points, cells={cell_type: cells}, cell_data = {"name_to_read": [cell_data]})
    return out_mesh
mesh = meshio.read("fluent.msh")
meshio.write("venturi_1600.xdmf", create_mesh(mesh,"quad", True))
and obtain:
KeyError                                  Traceback (most recent call last)
Cell In[1], line 36
     32     return out_mesh
     34 mesh = meshio.read("fluent.msh")
---> 36 meshio.write("venturi_1600.xdmf", create_mesh(mesh,"quad", True))
Cell In[1], line 29, in create_mesh(mesh, cell_type, prune_z)
     27 def create_mesh(mesh, cell_type, prune_z=False):
     28     cells = mesh.get_cells_type(cell_type)
---> 29     cell_data = mesh.get_cell_data("gmsh:physical", cell_type)
     30     points = mesh.points[:,:2] if prune_z else mesh.points
     31     out_mesh = meshio.Mesh(points=points, cells={cell_type: cells}, cell_data = {"name_to_read": [cell_data]})
File ~/.local/lib/python3.10/site-packages/meshio/_mesh.py:250, in Mesh.get_cell_data(self, name, cell_type)
    248 def get_cell_data(self, name: str, cell_type: str):
    249     return np.concatenate(
--> 250         [d for c, d in zip(self.cells, self.cell_data[name]) if c.type == cell_type]
    251     )
KeyError: 'gmsh:physical'
I try
print(mesh.cell_data)
and obtain
I think you need to remove the cell_data part and try like -
    out_mesh = meshio.Mesh(points=points, cells={cell_type: cells})
    return out_mesh
sorry for the delay. When I run it, I get this error.
Warnig: py.warning:/urs/local/lib/python3.10/dist-packages/h5py/__init__.py:36 UserWarning: h5py is running against HDF5 1.10.7 when it was bulit against 1.12.2, this may cause problems
and the kernel dies…
I tried to install these version but I get the same error…
See The kernel appears to have died. It will restart automatically - #13 by dokken
I followed the steps, uninstalled h5py and ran in terminalI followed the steps, uninstalled h5py and ran in terminal
python3 -m pip install --no-binary=h5py h5py meshio
and I get
Defaulting to user installation because normal site-packages is not writeable
Collecting h5py
  Using cached h5py-3.9.0.tar.gz (402 kB)
  Installing build dependencies ... done
  Getting requirements to build wheel ... done
  Installing backend dependencies ... done
  Preparing metadata (pyproject.toml) ... done
Requirement already satisfied: meshio in ./.local/lib/python3.10/site-packages (5.3.4)
Requirement already satisfied: numpy>=1.17.3 in /usr/lib/python3/dist-packages (from h5py) (1.21.5)
Requirement already satisfied: rich in ./.local/lib/python3.10/site-packages (from meshio) (13.3.4)
Requirement already satisfied: pygments<3.0.0,>=2.13.0 in ./.local/lib/python3.10/site-packages (from rich->meshio) (2.15.0)
Requirement already satisfied: markdown-it-py<3.0.0,>=2.2.0 in ./.local/lib/python3.10/site-packages (from rich->meshio) (2.2.0)
Requirement already satisfied: mdurl~=0.1 in ./.local/lib/python3.10/site-packages (from markdown-it-py<3.0.0,>=2.2.0->rich->meshio) (0.1.2)
Building wheels for collected packages: h5py
  Building wheel for h5py (pyproject.toml) ... error
  error: subprocess-exited-with-error
  × Building wheel for h5py (pyproject.toml) did not run successfully.
  │ exit code: 1
  ╰─> [89 lines of output]
      running bdist_wheel
      running build
      running build_ext
      Error compiling Cython file:
      cdef struct err_data_t:
          H5E_error_t err
          int n
      cdef herr_t walk_cb(unsigned int n, const H5E_error_t *desc, void *e) nogil noexcept:
      h5py/_errors.pyx:97:76: Syntax error in C variable declaration
      Loading library to get build settings and version: /usr/lib/x86_64-linux-gnu/hdf5/openmpi/libhdf5.so
                             Summary of the h5py configuration
        HDF5 include dirs: [
        '/usr/include/hdf5/openmpi'
        '/usr/lib/x86_64-linux-gnu/openmpi/include'
        '/usr/lib/x86_64-linux-gnu/openmpi/include/openmpi'
        HDF5 library dirs: [
        '/usr/lib/x86_64-linux-gnu/hdf5/openmpi'
        '/usr/lib/x86_64-linux-gnu/openmpi/lib'
             HDF5 Version: (1, 10, 7)
              MPI Enabled: False
         ROS3 VFD Enabled: True
       DIRECT VFD Enabled: False
         Rebuild Required: True
           MS-MPI Enabled: False
      MS-MPI include dirs: []
      MS-MPI library dirs: []
      Executing api_gen rebuild of defs
      Updated /tmp/pip-install-mz8ute5r/h5py_7dbb00c2e84c4528a56317c969e584e7/h5py/config.pxi
      Executing cythonize()
      [ 1/24] Cythonizing /tmp/pip-install-mz8ute5r/h5py_7dbb00c2e84c4528a56317c969e584e7/h5py/_conv.pyx
      [ 2/24] Cythonizing /tmp/pip-install-mz8ute5r/h5py_7dbb00c2e84c4528a56317c969e584e7/h5py/_errors.pyx
        File "/usr/lib/python3/dist-packages/pip/_vendor/pep517/in_process/_in_process.py", line 363, in <module>
          main()
        File "/usr/lib/python3/dist-packages/pip/_vendor/pep517/in_process/_in_process.py", line 345, in main
          json_out['return_val'] = hook(**hook_input['kwargs'])
        File "/usr/lib/python3/dist-packages/pip/_vendor/pep517/in_process/_in_process.py", line 261, in build_wheel
          return _build_backend().build_wheel(wheel_directory, config_settings,
        File "/usr/lib/python3/dist-packages/setuptools/build_meta.py", line 230, in build_wheel
          return self._build_with_temp_dir(['bdist_wheel'], '.whl',
        File "/usr/lib/python3/dist-packages/setuptools/build_meta.py", line 215, in _build_with_temp_dir
          self.run_setup()
        File "/usr/lib/python3/dist-packages/setuptools/build_meta.py", line 158, in run_setup
          exec(compile(code, __file__, 'exec'), locals())
        File "setup.py", line 68, in <module>
          setup(
        File "/usr/lib/python3/dist-packages/setuptools/__init__.py", line 153, in setup
          return distutils.core.setup(**attrs)
        File "/usr/lib/python3/dist-packages/setuptools/_distutils/core.py", line 148, in setup
          return run_commands(dist)
        File "/usr/lib/python3/dist-packages/setuptools/_distutils/core.py", line 163, in run_commands
          dist.run_commands()
        File "/usr/lib/python3/dist-packages/setuptools/_distutils/dist.py", line 967, in run_commands
          self.run_command(cmd)
        File "/usr/lib/python3/dist-packages/setuptools/_distutils/dist.py", line 986, in run_command
          cmd_obj.run()
        File "/usr/lib/python3/dist-packages/wheel/bdist_wheel.py", line 299, in run
          self.run_command('build')
        File "/usr/lib/python3/dist-packages/setuptools/_distutils/cmd.py", line 313, in run_command
          self.distribution.run_command(command)
          cmd_obj.run()
        File "/usr/lib/python3/dist-packages/setuptools/_distutils/command/build.py", line 135, in run
          self.run_command(cmd_name)
          cmd_obj.run()
        File "/tmp/pip-install-mz8ute5r/h5py_7dbb00c2e84c4528a56317c969e584e7/setup_build.py", line 171, in run
          self.extensions = cythonize(self._make_extensions(config),
        File "/usr/lib/python3/dist-packages/Cython/Build/Dependencies.py", line 1127, in cythonize
          cythonize_one(*args)
        File "/usr/lib/python3/dist-packages/Cython/Build/Dependencies.py", line 1250, in cythonize_one
          raise CompileError(None, pyx_file)
      Cython.Compiler.Errors.CompileError: /tmp/pip-install-mz8ute5r/h5py_7dbb00c2e84c4528a56317c969e584e7/h5py/_errors.pyx
      [end of output]
  note: This error originates from a subprocess, and is likely not a problem with pip.
  ERROR: Failed building wheel for h5py
Failed to build h5py
ERROR: Could not build wheels for h5py, which is required to install pyproject.toml-based projects
Could you check what cython version you have on your system, as they just released a new version 2 days ago (it might be that you need to pin it to an earlier version of cython).
I have
Cython version 0.29.28
What system are you running on?
Can you produce an environment that reproduces this error (say with docker)?
I use Ubuntu 22.04.2 LTS.
I have never used docker. how can I do it?
How did you install dolfinx? Through apt-Get?
with this
add-apt-repository ppa:fenics-packages/fenics
apt update
apt install fenicsx
I cannot reproduce this error with a clean ubuntu system:
Dockerfile:
FROM ubuntu:22.04
ENV DEBIAN_FRONTEND=noninteractive
RUN apt-get update && \
    apt-get install -y software-properties-common && \
    add-apt-repository ppa:fenics-packages/fenics && \
    apt-get install -y fenicsx python3-pip
RUN python3 -m pip install --no-binary=h5py h5py meshio
built with:
docker build -t dx_meshio .
Do you have any suggestions?
I just need to transform the mesh and do the rest in my original code.
Its hard when I cant reproduce the error. What happens if you use the Gmsh Python interface to read the msh file and use dolfinx.io.gmshio.read_from_msh or dolfinx.io.gmshio.model_to_mesh?
If I use
mesh = dolfinx.io.gmshio.read_from_msh("fluent.msh", MPI.COMM_WORLD,gdim=2)
I get
Error   : 'fluent.msh', line 1: syntax error (()
Exception                                 Traceback (most recent call last)
Cell In[4], line 27
     22 import meshio
     23 ##########################################################################################################3
     24
     25     # Read the mesh
---> 27 mesh = dolfinx.io.gmshio.read_from_msh("fluent.msh", MPI.COMM_WORLD,gdim=2)
     29 def create_mesh(mesh, cell_type, prune_z=False):
     30     cells = mesh.get_cells_type(cell_type)
File /usr/lib/petsc/lib/python3/dist-packages/dolfinx/io/gmshio.py:306, in read_from_msh(filename, comm, rank, gdim, partitioner)
    304 gmsh.initialize()
    305 gmsh.model.add("Mesh from file")
--> 306 gmsh.merge(filename)
    307 msh = model_to_mesh(gmsh.model, comm, rank, gdim=gdim, partitioner=partitioner)
    308 gmsh.finalize()
File /usr/local/lib/python3.10/dist-packages/gmsh.py:354, in merge(fileName)
    350 lib.gmshMerge(
    351     c_char_p(fileName.encode()),
    352     byref(ierr))
    353 if ierr.value != 0:
--> 354     raise Exception(logger.getLastError())
Exception: 'fluent.msh', line 1: syntax error (()
and with
mesh, cell_markers, facet_markers = dolfinx.io.gmshio.model_to_mesh("fluent.msh", MPI.COMM_WORLD, 0 ,gdim=2)
Cell In[7], line 27
     22 import meshio
     24
     25     # Read the mesh
---> 27 mesh, cell_markers, facet_markers = dolfinx.io.gmshio.model_to_mesh("fluent.msh", MPI.COMM_WORLD, 0 ,gdim=2)
File /usr/lib/petsc/lib/python3/dist-packages/dolfinx/io/gmshio.py:199, in model_to_mesh(model, comm, rank, gdim, partitioner)
    173 """Given a Gmsh model, take all physical entities of the highest
    174 topological dimension and create the corresponding DOLFINx mesh.
    175
    194     if found in Gmsh model.
    195 """
    197 if comm.rank == rank:
    198     # Get mesh geometry and mesh topology for each element
--> 199     x = extract_geometry(model)
    200     topologies = extract_topology_and_markers(model)
    202     # Extract Gmsh cell id, dimension of cell and number of
    203     # nodes to cell for each
File /usr/lib/petsc/lib/python3/dist-packages/dolfinx/io/gmshio.py:153, in extract_geometry(model, name)
    149     model.setCurrent(name)
    151 # Get the unique tag and coordinates for nodes
    152 # in mesh
--> 153 indices, points, _ = model.mesh.getNodes()
    154 points = points.reshape(-1, 3)
    156 # Gmsh indices starts at 1. We therefore subtract one to use
    157 # zero-based numbering
AttributeError: 'str' object has no attribute 'mesh'
I have tried a somewhat rough solution. I have downloaded a dolfinx image for docker
docker run -ti dolfinx/dolfinx:stable
and copied the .msh file to that container.
if I use this version of the code,
from dolfinx import geometry
from dolfinx import io
    # Read the mesh
    cell_data = mesh.get_cell_data( "gmsh:physical", cell_type)
    #points = mesh.points[:,:2] if prune_z else mesh.points
    if prune_z:
    out_mesh = meshio.Mesh(points=points, cells={cell_type: cells}, cell_data={"name_to_read": [cell_data]})
    #out_mesh = meshio.Mesh(points=points, cells={cell_type: cells})
    return out_mesh
I get
  File "/root/Venuri_fenicsx2D_m1600.py", line 33, in <module>
  File "/root/Venuri_fenicsx2D_m1600.py", line 22, in create_mesh
  File "/usr/local/lib/python3.10/dist-packages/meshio/_mesh.py", line 250, in get_cell_data
with this version, using a previous suggestion.
    # Read the mesh
    #cell_data = mesh.get_cell_data( "gmsh:physical", cell_type)
    if prune_z:
    #out_mesh = meshio.Mesh(points=points, cells={cell_type: cells}, cell_data={"name_to_read": [cell_data]})
    return out_mesh
seems to work…
But, when I open the .xdmf file with paraview nothing appears, but in information it does appear in number of points and dimensions.
If I try to define a function with that mesh and open it with paraview, it appears completely empty.
