Problem with solving the heat equation
Hello all,
This has been a problem that I have been trying to solve for a while but could not figure out what is the issue.
IBVP:
Cubic domain of 1mm x 1mm x 1mm
Initial Temperature: 300K
Dirichlet BCs: Temperature: 320K at boundary X=0, Y=0, Z =0
Neumann BCs: Heat flux of -1000 mW/mm^2 at boundary X=1, Y=1, Z=1
dt = 1e-5
NSteps = 1000
Using approximate material properties of steel.
I get the following output for temperature profile (Paraview)
I also find that the temperature goes below the initial temperature, but this should not happen.
What could I be doing wrong when using CG1 elements? The following is the code:
#Using dolfin 2019.02.dev
import time
t_tot           = 1.e-5
num_steps       = 1000
dt              = t_tot / num_steps
rho             =  8.e-6
Flux            = -1000.e0
Cv              =  0.5e6
T_init          = Constant(300.0)
Tref            = Constant(300.0)
K               = Constant(16.3e0)
X_Len           = 1.0
Y_Len           = 1.0
Z_Len           = 1.0
EX              = 8
EY              = 8
EZ              = 8
mesh            = UnitCubeMesh.create(EX, EY, EZ, CellType.Type.tetrahedron)
ScalarSpace     = FunctionSpace(mesh,'CG',1)
def X0(x, on_boundary):     return near(x[0],0.,DOLFIN_EPS) and on_boundary
def X1(x, on_boundary):     return near(x[0],X_Len,DOLFIN_EPS) and on_boundary
def Y0(x, on_boundary):     return near(x[1],0.,DOLFIN_EPS) and on_boundary
def Y1(x, on_boundary):     return near(x[1],Y_Len,DOLFIN_EPS) and on_boundary
def Z0(x, on_boundary):     return near(x[2],0.,DOLFIN_EPS) and on_boundary
def Z1(x, on_boundary):     return near(x[2],Z_Len,DOLFIN_EPS) and on_boundary
boundary_subdomains = MeshFunction("size_t", mesh, mesh.topology().dim() - 1)
boundary_subdomains.set_all(0)
AutoSubDomain(X0).mark(boundary_subdomains, 1)
AutoSubDomain(X1).mark(boundary_subdomains, 2)
AutoSubDomain(Y0).mark(boundary_subdomains, 3)
AutoSubDomain(Y1).mark(boundary_subdomains, 4)
AutoSubDomain(Z0).mark(boundary_subdomains, 5)
AutoSubDomain(Z1).mark(boundary_subdomains, 6)
dss     = ds(subdomain_data=boundary_subdomains)
bcTX0           = DirichletBC(ScalarSpace,      Constant(320.0),X0)
bcTY0           = DirichletBC(ScalarSpace,      Constant(320.0),Y0)
bcTZ0           = DirichletBC(ScalarSpace,      Constant(320.0),Z0)
bcT             = [bcTX0,bcTY0,bcTZ0]
def q(theta):
    return (-K*grad(theta))
T_n             = Function(ScalarSpace)
T_n             = project(T_init, ScalarSpace)
T               = TrialFunction(ScalarSpace)
vT              = TestFunction(ScalarSpace)
ThermalForm     = rho*Cv*(T-T_n)/dt*vT*dx  + Flux*vT*dss(2) + Flux*vT*dss(4) + Flux*vT*dss(6) - dot(q(T),grad(vT))*dx
aT, LT          = lhs(ThermalForm), rhs(ThermalForm)
fileResults         = XDMFFile("Solution/HeatEquation.xdmf") # the output is written in a .xdmf file and could be open with Paraview
fileResults.parameters["flush_output"]          = True
fileResults.parameters["functions_share_mesh"]  = True
T = Function(ScalarSpace)
T = project(T_init,ScalarSpace)
T.rename("Temperature","label")
t = 0.
fileResults.write(T,t)
for n in range(num_steps):
    print('Step', n+1)
    solve(aT == LT, T, bcT)
    T_n.vector()[:] = T.vector()
print("Solution Complete.")
Thank you!
Looks like your boundary conditions are not consistent with your initial conditions, so you’re effectively seeing Gibb’s phenomenon.
Hi Nate,
Could you tell me more about how I could correct this?
If boundary conditions, what should it satisfy?
Thank you!
see, e.g. here.
