Problems encountered in solving thermoelastic problems
Hi all, recently I’m trying to learn some code to solve the thermoplastic problem with the following code:
from arguments import args
from utils import walltime
import fenics as fe
import os
import glob
fe.parameters["form_compiler"]["representation"] = 'uflacs'
import warnings
from ffc.quadrature.deprecation import QuadratureRepresentationDeprecationWarning
warnings.simplefilter("once", QuadratureRepresentationDeprecationWarning)
@walltime
def simulation():
    ambient_T = args.T_ambient
    rho = args.rho
    Cp = args.c_p
    k = args.kappa_T
    h = args.h_conv
    eta = args.power_fraction
    r = args.r_beam
    P = args.power
    EPS = 1e-8
    E = fe.Constant(70e3)
    nu = fe.Constant(0.3)
    lmbda = E*nu/(1+nu)/(1-2*nu)
    mu = E/2./(1+nu)
    sig0 = fe.Constant(250.)
    Et = E/100.  ###  切向模量
    H = E*Et/(E-Et)  ###  塑性模量,又称硬化系数
    x0 = 0.2*args.domain_x
    y0 = 0.5*args.domain_y
    total_t = 1200*1e-6
    vel = 0.6*args.domain_x/total_t
    dt = 1e-6
    ts = np.arange(0., total_t + dt, dt)
    print(f"total time steps = {len(ts)}")
    ele_size = 0.01
    mesh = fe.BoxMesh(fe.Point(0., 0., 0.), fe.Point(args.domain_x, args.domain_y, args.domain_z),
                      round(args.domain_x/ele_size), round(args.domain_y/ele_size), round(args.domain_z/ele_size))
    mesh_file = fe.File(f'data/vtk/pbf/mesh/mesh.pvd')
    mesh_file << mesh
    # Define bottom surface
    class Bottom(fe.SubDomain):
            # The condition for a point x to be on bottom side is that x[2] < EPS
            return on_boundary and x[2] < EPS
    # Define top surface
    class Top(fe.SubDomain):
            return on_boundary and x[2] > args.domain_z - EPS
    # Define the other four surfaces
    class SurroundingSurfaces(fe.SubDomain):
            return on_boundary and (x[0] < EPS or x[0] > args.domain_x - EPS or x[1] < EPS or x[1] > args.domain_y - EPS)
    bottom = Bottom()
    top = Top()
    surrounding_surfaces = SurroundingSurfaces()
    boundaries = fe.MeshFunction("size_t", mesh, mesh.topology().dim() - 1)
    boundaries.set_all(0)
    bottom.mark(boundaries, 1)
    top.mark(boundaries, 2)
    surrounding_surfaces.mark(boundaries, 3)
    ds = fe.Measure('ds')(subdomain_data=boundaries)
    normal = fe.FacetNormal(mesh)
    deg_u = 2
    deg_stress = 2
    # TODO: can we do a tensor element?
    U = fe.VectorFunctionSpace(mesh, "CG", deg_u)
    We = fe.VectorElement("Quadrature", mesh.ufl_cell(), degree=deg_stress, dim=9, quad_scheme='default')
    W = fe.FunctionSpace(mesh, We)
    # We = fe.TensorElement("Quadrature", mesh.ufl_cell(), degree=deg_stress, quad_scheme='default')
    # W = fe.FunctionSpace(mesh, We)
    W0e = fe.FiniteElement("Quadrature", mesh.ufl_cell(), degree=deg_stress, quad_scheme='default')
    W0 = fe.FunctionSpace(mesh, W0e)
    sig = fe.Function(W)
    sig_old = fe.Function(W)
    n_elas = fe.Function(W)
    beta = fe.Function(W0)
    # name = "a b" is bad (having a space)!
    p = fe.Function(W0, name="Cumulative plastic strain")
    u = fe.Function(U, name="Total displacement")
    du = fe.Function(U, name="Iteration correction")
    Du = fe.Function(U, name="Current increment")
    v = fe.TrialFunction(U)
    u_ = fe.TestFunction(U)
    u_bcs = [fe.DirichletBC(U, fe.Constant((0., 0., 0.)), bottom)]
    def eps(v):
        e = fe.sym(fe.grad(v))
        return e
    def sigma(eps_el):
        return lmbda*fe.tr(eps_el)*fe.Identity(3) + 2*mu*eps_el
    def as_3D_tensor(X):
        return fe.as_tensor([[X[0], X[1], X[2]],
                             [X[3], X[4], X[5]],
                             [X[6], X[7], X[8]]])
    def as_long_vector(X):
        return fe.as_vector([X[0, 0], X[0, 1], X[0, 2], X[1, 0], X[1, 1], X[1, 2], X[2, 0], X[2, 1], X[2, 2]])
    ppos = lambda x: (x+abs(x))/2.
    def thermal_strain(dT):
        alpha_V = 1e-5
        return alpha_V*dT*fe.Identity(3)
    def proj_sig(deps, dT, sig_old, p_old):
        sig_n = as_3D_tensor(sig_old)   ### 将旧的应力场转为三维张量
        # sig_elas = sig_n + sigma(deps)
        d_eps_T = thermal_strain(dT)   ### 计算温度变化dT引起的热应变
        sig_elas = sig_n + sigma(deps - d_eps_T)   ### 计算当前弹性应力张量
        s = fe.dev(sig_elas)   ### 计算弹性应力张量的偏量部分
        sig_eq = fe.sqrt(3/2.*fe.inner(s, s))   ### 计算等效应力
        f_elas = sig_eq - sig0 - H*p_old   ###   计算弹性力,用于评估是否需要激活塑性本构。>0,应力状态超过屈服应力;
        dp = ppos(f_elas)/(3*mu+H)   ###  计算塑性应变增量
        n_elas = s/sig_eq*ppos(f_elas)/f_elas   ###   计算弹性流动方向张量
        beta = 3*mu*dp/sig_eq   ###  计算硬化参数
        new_sig = sig_elas-beta*s   ###   更新应力张量
        return as_long_vector(new_sig), as_long_vector(n_elas), beta, dp
    def sigma_tang(e):
        N_elas = as_3D_tensor(n_elas)
        return sigma(e) - 3*mu*(3*mu/(3*mu+H)-beta)*fe.inner(N_elas, e)*N_elas-2*mu*beta*fe.dev(e)
    metadata = {"quadrature_degree": deg_stress, "quadrature_scheme": "default"}
    dxm = fe.dx(metadata=metadata)
    # TODO
    a_Newton = fe.inner(eps(v), sigma_tang(eps(u_)))*dxm
    res = -fe.inner(as_3D_tensor(sig), eps(u_))*dxm + 1e-10*fe.dot(normal, u_)*ds(2)
        dv = fe.TrialFunction(V)
        v_ = fe.TestFunction(V)
        a_proj = fe.inner(dv, v_)*dxm
        b_proj = fe.inner(v, v_)*dxm
        solver = fe.LocalSolver(a_proj, b_proj)
        solver.factorize()
        if u is None:
            u = fe.Function(V)
            solver.solve_local_rhs(u)
            return u
    def global_project(v, V, u=None):
        Not working.
        AssertionError: Mismatch of quadrature points!
        if u is None:
            return fe.project(v, V)
            u.assign(fe.project(v, V))
    P0 = fe.FunctionSpace(mesh, "DG", 0)
    p_avg = fe.Function(P0, name="Plastic strain")
    V = fe.FunctionSpace(mesh, 'CG', 1)
    T_crt = fe.interpolate(fe.Constant(ambient_T), V)
    T_pre = fe.interpolate(fe.Constant(ambient_T), V)
    T_old = fe.interpolate(fe.Constant(ambient_T), V)
    T_old.rename('T', 'T')
    v = fe.TestFunction(V)
    # If theta = 0., we recover implicit Eulear; if theta = 1., we recover explicit Euler; theta = 0.5 seems to be a good choice.
    theta = 0.5
    T_rhs = theta*T_pre + (1 - theta)*T_crt
    T_bcs = [fe.DirichletBC(V, fe.Constant(ambient_T), bottom)]
    class LaserExpression(fe.UserExpression):
        def __init__(self, t):
            super(LaserExpression, self).__init__()
            self.t = t
        def eval(self, values, x):
            t = self.t
            values[0] = 2*P*eta/(np.pi*r**2) * np.exp(-2*((x[0] - x0 - vel*t)**2 + (x[1] - y0)**2) / r**2)
        def value_shape(self):
            return ()
    q_laser = LaserExpression(None)
    q_convection = h * (T_rhs - ambient_T)
    q_top = q_convection + q_laser
    q_surr = q_convection
    res_T = rho*Cp/dt*(T_crt - T_pre) * v * fe.dx + k * fe.dot(fe.grad(T_rhs), fe.grad(v)) * fe.dx \
                - q_top * v * ds(2) - q_surr * v * ds(3)
    files_vtk = glob.glob('data/vtk/pbf/sols' + f"/*")
    files_xdmf = glob.glob('data/xdmf/pbf/' + f"/*")
    for f in files_vtk + files_xdmf:
        os.remove(f)
    T_vtk_file = fe.File(f'data/vtk/pbf/sols/T.pvd')
    T_vtk_file << T_old
    u_vtk_file = fe.File(f'data/vtk/pbf/sols/u.pvd')
    u_vtk_file << u
    p_vtk_file = fe.File(f'data/vtk/pbf/sols/p.pvd')
    p_vtk_file << p_avg
    file_results = fe.XDMFFile('data/xdmf/pbf/u.xdmf')
    file_results.write(T_old, 0)
    file_results.write(u, 0)
    file_results.write(p_avg, 0)
    plastic_inverval = 10
    for i in range(len(ts) - 1):
    # for i in range(100):
        print(f"step {i + 1}, time = {ts[i + 1]}")
        q_laser.t = theta*ts[i] + (1 - theta)*ts[i + 1]
        solver_parameters = {'newton_solver': {'maximum_iterations': 20, 'linear_solver': 'mumps'}}
        fe.solve(res_T == 0, T_crt, T_bcs, solver_parameters=solver_parameters)
        T_pre.assign(T_crt)
        print(f"min T = {np.min(np.array(T_pre.vector()))}")
        print(f"max T = {np.max(np.array(T_pre.vector()))}")
        if (i + 1) % plastic_inverval == 0:
            T_crt_array = np.array(T_crt.vector())
            T_crt_array = np.where(T_crt_array < args.T_ambient, args.T_ambient, T_crt_array)
            T_crt_array = np.where(T_crt_array > args.T_melt, args.T_melt, T_crt_array)
            T_old_array = np.array(T_old.vector())
            T_old_array = np.where(T_old_array < args.T_ambient, args.T_ambient, T_old_array)
            T_old_array = np.where(T_old_array > args.T_melt, args.T_melt, T_old_array)
            dT = fe.Function(V)
            dT.vector()[:] = T_crt_array - T_old_array
            Nitermax, tol = 200, 1e-8  # parameters of the Newton-Raphson procedure
            Nincr = 20
            A, Res = fe.assemble_system(a_Newton, res, u_bcs)
            nRes0 = Res.norm("l2")
            nRes = nRes0
            Du.interpolate(fe.Constant((0., 0., 0.)))
            niter = 0
            nRes = 1.
            tol = 1e-8
            # while nRes/nRes0 > tol and niter < Nitermax:
            # while niter < Nitermax:
            while nRes > tol:
                print("\n")
                fe.solve(A, du.vector(), Res, "mumps")
                Du.assign(Du+du)
                deps = eps(Du)
                print(f"du norm = {np.linalg.norm(np.array(du.vector()))}")
                sig_, n_elas_, beta_, dp_ = proj_sig(deps, dT, sig_old, p)
                local_project(sig_, W, sig)
                local_project(n_elas_, W, n_elas)
                local_project(beta_, W0, beta)
                print(f"sig dof = {np.array(sig.vector()).shape}")
                print(f"sig norm = {np.linalg.norm(np.array(sig.vector()))}")
                print(f"n_elas norm = {np.linalg.norm(np.array(n_elas.vector()))}")
                print(f"beta norm = {np.linalg.norm(np.array(beta.vector()))}")
                nRes = Res.norm("l2")
                print(f"Residual: {nRes}")
                niter += 1
            u.assign(u + Du)
            sig_old.assign(sig)
            p.assign(p + local_project(dp_, W0))
            p_avg.assign(fe.project(p, P0))
            T_old.assign(T_crt)
            T_vtk_file << T_old
            u_vtk_file << u
            p_vtk_file << p_avg
            file_results.write(T_old, i)
            file_results.write(u, i)
            file_results.write(p_avg, i)
if __name__ == '__main__':
    simulation()
However, the following error occurs in the runtime:
Moving new file over differing existing file:
src: /home/ljr/plasticity-main/src/jitfailure-ffc_form_a4835aa8bc5992adce9bec698822651d96d78c16/error.log.57b0160c06294e748ca68aac62a9c044
dst: /home/ljr/plasticity-main/src/jitfailure-ffc_form_a4835aa8bc5992adce9bec698822651d96d78c16/error.log
backup: /home/ljr/plasticity-main/src/jitfailure-ffc_form_a4835aa8bc5992adce9bec698822651d96d78c16/error.log.old
Backup file exists, overwriting.
------------------- Start compiler output ------------------------
/tmp/tmpx7xoc3ez/ffc_form_a4835aa8bc5992adce9bec698822651d96d78c16.cpp: In member function 'virtual void ffc_form_a4835aa8bc5992adce9bec698822651d96d78c16_cell_integral_main_otherwise::tabulate_tensor(double*, const double* const*, const double*, int) const':
/tmp/tmpx7xoc3ez/ffc_form_a4835aa8bc5992adce9bec698822651d96d78c16.cpp:124:29: error: 'FE17_C0_Q4' was not declared in this scope
  124 |             TF0[iq] = fw0 * FE17_C0_Q4[0][iq][iq];
/tmp/tmpx7xoc3ez/ffc_form_a4835aa8bc5992adce9bec698822651d96d78c16.cpp:125:34: error: 'FE17_C0_Q4' was not declared in this scope
  125 |         BF0[iq][iq] += TF0[iq] * FE17_C0_Q4[0][iq][iq];
-------------------  End compiler output  ------------------------
Compilation failed! Sources, command, and errors have been written to: /home/ljr/plasticity-main/src/jitfailure-ffc_form_a4835aa8bc5992adce9bec698822651d96d78c16
DijitsoError                              Traceback (most recent call last)
Cell In[8], line 320
    315             file_results.write(p_avg, i)
    319 if __name__ == '__main__':
--> 320     simulation()
File ~/plasticity-main/src/utils.py:9, in walltime.<locals>.wrapper(*list_args, **keyword_wargs)
      7 def wrapper(*list_args, **keyword_wargs):
      8     start_time = time.time()
----> 9     func(*list_args, **keyword_wargs)
     10     end_time = time.time()
     11     time_elapsed = end_time - start_time
Cell In[8], line 287, in simulation()
    283 print(f"du norm = {np.linalg.norm(np.array(du.vector()))}")
    285 sig_, n_elas_, beta_, dp_ = proj_sig(deps, dT, sig_old, p)
--> 287 local_project(sig_, W, sig)
    288 local_project(n_elas_, W, n_elas)
    289 local_project(beta_, W0, beta)
Cell In[8], line 164, in simulation.<locals>.local_project(v, V, u)
    162 a_proj = fe.inner(dv, v_)*dxm
    163 b_proj = fe.inner(v, v_)*dxm
--> 164 solver = fe.LocalSolver(a_proj, b_proj)
    165 solver.factorize()
    166 if u is None:
File ~/anaconda3/envs/fenicsproject/lib/python3.12/site-packages/dolfin/fem/solvers.py:39, in LocalSolver.__init__(self, a, L, solver_type)
     36 self.L_ufl = L
     38 # Wrap as DOLFIN forms
---> 39 a = Form(a)
     40 if L is None:
     41     # Initialize C++ base class
     42     cpp.fem.LocalSolver.__init__(self, a, solver_type)
File ~/anaconda3/envs/fenicsproject/lib/python3.12/site-packages/dolfin/fem/form.py:43, in Form.__init__(self, form, **kwargs)
     40 if form_compiler_parameters is None:
     41     form_compiler_parameters = {"external_include_dirs": dolfin_pc["include_dirs"]}
---> 43 ufc_form = ffc_jit(form, form_compiler_parameters=form_compiler_parameters,
     44                    mpi_comm=mesh.mpi_comm())
     45 ufc_form = cpp.fem.make_ufc_form(ufc_form[0])
     47 function_spaces = kwargs.get("function_spaces")
File ~/anaconda3/envs/fenicsproject/lib/python3.12/site-packages/dolfin/jit/jit.py:47, in mpi_jit_decorator.<locals>.mpi_jit(*args, **kwargs)
     45 # Just call JIT compiler when running in serial
     46 if MPI.size(mpi_comm) == 1:
---> 47     return local_jit(*args, **kwargs)
     49 # Default status (0 == ok, 1 == fail)
     50 status = 0
File ~/anaconda3/envs/fenicsproject/lib/python3.12/site-packages/dolfin/jit/jit.py:97, in ffc_jit(ufl_form, form_compiler_parameters)
     95 p.update(dict(parameters["form_compiler"]))
     96 p.update(form_compiler_parameters or {})
---> 97 return ffc.jit(ufl_form, parameters=p)
File ~/anaconda3/envs/fenicsproject/lib/python3.12/site-packages/ffc/jitcompiler.py:217, in jit(ufl_object, parameters, indirect)
    214 kind, module_name = compute_jit_prefix(ufl_object, parameters)
    216 # Inspect cache and generate+build if necessary
--> 217 module = jit_build(ufl_object, module_name, parameters)
    219 # Raise exception on failure to build or import module
    220 if module is None:
    221     # TODO: To communicate directory name here, need dijitso params to call
    222     #fail_dir = dijitso.cache.create_fail_dir_path(signature, dijitso_cache_params)
File ~/anaconda3/envs/fenicsproject/lib/python3.12/site-packages/ffc/jitcompiler.py:130, in jit_build(ufl_object, module_name, parameters)
    123 params = dijitso.validate_params({
    124     "cache": cache_params,
    125     "build": build_params,
    126     "generator": parameters,  # ffc parameters, just passed on to jit_generate
    127 })
    129 # Carry out jit compilation, calling jit_generate only if needed
--> 130 module, signature = dijitso.jit(jitable=ufl_object,
    131                                 name=module_name,
    132                                 params=params,
    133                                 generate=jit_generate)
    134 return module
File ~/anaconda3/envs/fenicsproject/lib/python3.12/site-packages/dijitso/jit.py:216, in jit(jitable, name, params, generate, send, receive, wait)
    212     lib = load_library(signature, cache_params)
    214 if err_info:
    215     # TODO: Parse output to find error(s) for better error messages
--> 216     raise DijitsoError("Dijitso JIT compilation failed, see '%s' for details"
    217                        % err_info['fail_dir'], err_info)
    219 # Return built library and its signature
    220 return lib, signature
DijitsoError: Dijitso JIT compilation failed, see '/home/ljr/plasticity-main/src/jitfailure-ffc_form_a4835aa8bc5992adce9bec698822651d96d78c16' for details
Quadrature elements have always been fishy in the legacy FEniCS, yielding strange errors such as this one. I suggest switching to FEniCSx (dolfinx v0.8.0) in which everything works better
Thanks for your suggestion, I tried to use fenicsx to solve the thermoelasticity problem with the following code:
from dolfinx import fem
import glob
import os
import sys
import basix
from pprint import pprint
comm = MPI.COMM_WORLD
def mpi_print(msg):
    if comm.rank == 0:
        print(f"Rank {comm.rank} print: {msg}")
        sys.stdout.flush()
@walltime
def simulation():
    case_name = 'mechanical'
    if comm.rank == 0:
        files_vtk = glob.glob(f'data/vtk/{case_name}/sols' + f"/*")
        files_xdmf = glob.glob(f'data/xdmf/{case_name}/' + f"/*")
            os.remove(f)
    rho = args.rho
    Cp = args.c_p
    k = args.kappa_T
    h = args.h_conv
    r = args.r_beam
    P = args.power
    simulation_t = 2400*1e-6
    total_t = 1200*1e-6
    dt = 1e-6
    ts = np.arange(0., simulation_t + dt, dt)
    mpi_print(f"total time steps = {len(ts)}")
    ele_size = 0.01
    Nx, Ny, Nz = round(args.domain_x/ele_size), round(args.domain_y/ele_size), round(args.domain_z/ele_size)
    mpi_print(f"Nx = {Nx}, Ny = {Ny}, Nz = {Nz}")
    mesh = dolfinx.mesh.create_box(MPI.COMM_WORLD, [np.array([0., 0., 0.]), np.array([args.domain_x, args.domain_y, args.domain_z])],
                                   [Nx, Ny, Nz], cell_type=dolfinx.mesh.CellType.hexahedron)  # cell_type=mesh.CellType.hexahedron/tetrahedron
    mesh_vtk_file = dolfinx.io.VTKFile(MPI.COMM_WORLD, f'data/vtk/{case_name}/mesh/mesh.pvd', 'w')
    mesh_vtk_file.write_mesh(mesh)
    # pprint(dir(mesh.geometry))
    print(f"Total number of local mesh vertices {len(mesh.geometry.x)}" )
    def bottom(x):
        return np.isclose(x[2], 0.)
    def top(x):
        return np.isclose(x[2], args.domain_z)
    fdim = mesh.topology.dim - 1
    bottom_facets = dolfinx.mesh.locate_entities_boundary(mesh, fdim, bottom)
    top_facets = dolfinx.mesh.locate_entities_boundary(mesh, fdim, top)
    mpi_print(f"bottom_facets.shape = {bottom_facets.shape}")
    marked_facets = np.hstack([bottom_facets, top_facets])
    marked_values = np.hstack([np.full(len(bottom_facets), 1, dtype=np.int32), np.full(len(top_facets), 2, dtype=np.int32)])
    facet_tag = dolfinx.mesh.meshtags(mesh, fdim, marked_facets[sorted_facets], marked_values[sorted_facets])
    deg_u = 1
    deg_stress = 2
    degree_T = 1
    # "quadrature_degree": 2 means that use 8 integrations ponits for a hexahedron element
    ds = ufl.Measure('ds', domain=mesh, subdomain_data=facet_tag, metadata=metadata)
    dxm = ufl.Measure('dx', domain=mesh, metadata=metadata)
    normal = ufl.FacetNormal(mesh)
    quadrature_points, wts = basix.make_quadrature(basix.CellType.hexahedron, deg_stress)
    P0_ele = ufl.FiniteElement("DG", mesh.ufl_cell(), 0)
    P0 = fem.FunctionSpace(mesh, P0_ele)
    p_avg = fem.Function(P0, name="Plastic_strain")
    strain_xx = fem.Function(P0, name="strain_xx")
    stress_xx = fem.Function(P0, name="stress_xx")
    phase_avg = fem.Function(P0, name="phase")
    V_ele = ufl.FiniteElement("Lagrange", mesh.ufl_cell(), degree=degree_T)
    V = fem.FunctionSpace(mesh, V_ele)
    U_ele = ufl.VectorElement("Lagrange", mesh.ufl_cell(), degree=deg_u)
    U = fem.FunctionSpace(mesh, U_ele)
    # W_ele = ufl.TensorElement("DG", mesh.ufl_cell(), 0)
    # W = fem.FunctionSpace(mesh, W_ele)
    # W0_ele = ufl.FiniteElement("DG", mesh.ufl_cell(), 0)
    # W0 = fem.FunctionSpace(mesh, W0_ele)
    # W_ele = ufl.TensorElement("Quadrature", mesh.ufl_cell(), degree=deg_stress, quad_scheme='default', symmetry=True)
    W_ele = ufl.TensorElement("Quadrature", mesh.ufl_cell(), degree=deg_stress, quad_scheme='default')
    W0_ele = ufl.FiniteElement("Quadrature", mesh.ufl_cell(), degree=deg_stress, quad_scheme='default')
    def ini_T(x):
        return np.full(x.shape[1], ambient_T)
    dT = fem.Function(V)
    T_crt = fem.Function(V)
    T_crt.interpolate(ini_T)
    T_pre = fem.Function(V)
    T_pre.interpolate(ini_T)
    T_old = fem.Function(V, name='T')
    T_old.interpolate(ini_T)
    T_trial = ufl.TrialFunction(V)
    T_test = ufl.TestFunction(V)
    phase = fem.Function(V, name='phase')
    alpha_V = fem.Function(V)
    E = fem.Function(V)
    # alpha_V.x.array[:] = 1e-5
    # E.x.array[:] = args.Young_mod
    nu = 0.3
    mu = E/2./(1+nu)
    sig0 = 250.
    Et = E/100.
    H = E*Et/(E-Et)
    sig = fem.Function(W)
    # Something like "Cumulative plastic strain" may cause an error due to the space - probably a bug of dolfinx
    cumulative_p = fem.Function(W0, name="Cumulative_plastic_strain")
    u = fem.Function(U, name="Total_displacement")
    du = fem.Function(U, name="Iteration_correction")
    Du = fem.Function(U, name="Current_increment")
    v = ufl.TrialFunction(U)
    u_ = ufl.TestFunction(U)
    mpi_print(f"facet_tag.dim = {facet_tag.dim}")
    bottom_dofs_u = fem.locate_dofs_topological(U, facet_tag.dim, bottom_facets)
    bcs_u = [fem.dirichletbc(PETSc.ScalarType((0., 0., 0.)), bottom_dofs_u, U)]
    def eps(v):
        e = ufl.sym(ufl.grad(v))
        return e
    def sigma(eps_el):
        return lmbda*ufl.tr(eps_el)*ufl.Identity(3) + 2*mu*eps_el
    deps = eps(Du)
    def thermal_strain():
        # alpha_V = 1e-5
        return alpha_V*dT*ufl.Identity(3)
    ppos = lambda x: (x + abs(x))/2.
    heaviside = lambda x: ufl.conditional(ufl.gt(x, 0.), 1., 0.)
    def proj_sig():
        EPS = 1e-10
        d_eps_T = thermal_strain()
        sig_elas = sig + sigma(deps - d_eps_T)
        s = ufl.dev(sig_elas)
        sig_eq = ufl.sqrt(3/2.*ufl.inner(s, s))
        f_elas = sig_eq - sig0 - H*cumulative_p
        # Prevent divided by zero error
        # The original example (https://comet-fenics.readthedocs.io/en/latest/demo/2D_plasticity/vonMises_plasticity.py.html)
        # didn't consider this, and can cause nan error in the solver.
        n_elas = s/(sig_eq + EPS)*heaviside(f_elas)
        beta = 3*mu*dp/(sig_eq + EPS)
        new_sig = sig_elas - beta*s
        return new_sig, n_elas, beta, dp
    def sigma_tang(e):
        return sigma(e) - 3*mu*(3*mu/(3*mu+H)-beta)*ufl.inner(n_elas, e)*n_elas  -2*mu*beta*ufl.dev(e)
    theta = 0.5
    T_rhs = theta*T_pre + (1 - theta)*T_trial
    bottom_dofs_T = fem.locate_dofs_topological(V, facet_tag.dim, facet_tag.indices[facet_tag.values==1])
    bcs_T = [fem.dirichletbc(PETSc.ScalarType(ambient_T), bottom_dofs_T, V)]
    crt_time = fem.Constant(mesh, PETSc.ScalarType(0.))
    q_laser = 2*P*eta/(np.pi*r**2) * ufl.exp(-2*((x[0] - x0 - vel*crt_time)**2 + (x[1] - y0)**2) / r**2) * ufl.conditional(ufl.gt(crt_time, total_t), 0., 1.)
    # q_laser = 2*P*eta/(np.pi*r**2) * ufl.exp(-2*((x[0] - x0 - vel*crt_time)**2 + (x[1] - y0)**2) / r**2) * heaviside(total_t - crt_time.value)
    res_T = rho*Cp/dt*(T_trial - T_pre) * T_test * dxm + k * ufl.dot(ufl.grad(T_rhs), ufl.grad(T_test)) * dxm \
                - q_laser * T_test * ds(2) - q_convection * T_test * ds
    new_sig, n_elas, beta, dp = proj_sig()
    # ufl diff might be used to automate the computation of tangent stiffness tensor
    res_u_lhs = ufl.inner(eps(v), sigma_tang(eps(u_)))*dxm
    res_u_rhs = -ufl.inner(new_sig, eps(u_))*dxm
    problem_T = fem.petsc.LinearProblem(ufl.lhs(res_T), ufl.rhs(res_T), bcs=bcs_T, petsc_options={"ksp_type": "bicg", "pc_type": "jacobi"})
    problem_u = fem.petsc.LinearProblem(res_u_lhs, res_u_rhs, bcs=bcs_u, petsc_options={"ksp_type": "bicg", "pc_type": "jacobi"})
    def l2_projection(v, V):
        dv = ufl.TrialFunction(V)
        v_ = ufl.TestFunction(V)
        a_proj = ufl.inner(dv, v_)*dxm
        b_proj = ufl.inner(v, v_)*dxm
        problem = fem.petsc.LinearProblem(a_proj, b_proj, petsc_options={"ksp_type": "bicg", "pc_type": "jacobi"})
        u = problem.solve()
        return u
    def quad_interpolation(v, V):
        See https://github.com/FEniCS/dolfinx/issues/2243
        u = fem.Function(V)
        e_expr = fem.Expression(v, quadrature_points)
        map_c = mesh.topology.index_map(mesh.topology.dim)
        num_cells = map_c.size_local + map_c.num_ghosts
        cells = np.arange(0, num_cells, dtype=np.int32)
        e_eval = e_expr.eval(cells)
        with u.vector.localForm() as u_local:
            u_local.setBlockSize(u.function_space.dofmap.bs)
            u_local.setValuesBlocked(V.dofmap.list.array, e_eval, addv=PETSc.InsertMode.INSERT)
        return u
    def update_modului():
        # 0: powder, 1: liquid, 2: solid
        T_array = T_crt.x.array
        powder_to_liquid = (phase.x.array == 0) & (T_array > args.T_melt)
        liquid_to_solid = (phase.x.array == 1) & (T_array < args.T_melt)
        phase.x.array[powder_to_liquid] = 1
        phase.x.array[liquid_to_solid] = 2
        # print(f"number of powder = {np.sum(phase.x.array == 0)}, liquid = {np.sum(phase.x.array == 1)}, solid = {np.sum(phase.x.array == 2)}")
        E.x.array[(phase.x.array == 0) | (phase.x.array == 1)]  = 1e-2*args.Young_mod
        E.x.array[phase.x.array == 2] = args.Young_mod
        alpha_V.x.array[(phase.x.array == 0) | (phase.x.array == 1)] = 0.
        alpha_V.x.array[phase.x.array == 2] = args.alpha_V
    def write_sol(file, step):
        file.write_function(T_old, step)
        file.write_function(u, step)
        file.write_function(p_avg, step)
        file.write_function(strain_xx, step)
        file.write_function(stress_xx, step)
        file.write_function(phase_avg, step)
    vtk_file = dolfinx.io.VTKFile(mesh.comm, f'data/vtk/{case_name}/sols/u.pvd', 'w')
    xdmf_file = dolfinx.io.XDMFFile(mesh.comm, f'data/xdmf/{case_name}/u.xdmf', 'w')
    xdmf_file.write_mesh(mesh)
    write_sol(vtk_file, 0)
    write_sol(xdmf_file, 0)
    plastic_inverval = 20
    # for i in range(20):
        mpi_print(f"step {i + 1}/{len(ts) - 1}, time = {ts[i + 1]}")
        crt_time.value = theta*ts[i] + (1 - theta)*ts[i + 1]
        update_modului()
        T_crt = problem_T.solve()
        T_pre.x.array[:] = T_crt.x.array
        # print(f"min T = {np.min(np.array(T_pre.x.array))}")
        # print(f"max T = {np.max(np.array(T_pre.x.array))}\n")
            T_crt_array = np.array(T_crt.x.array)
            T_old_array = np.array(T_old.x.array)
            dT.x.array[:] = T_crt_array - T_old_array
            Du.x.array[:] = 0.
            niter = 0
            nRes = 1.
            tol = 1e-8
            while nRes > tol or niter < 2:
                mpi_print(f"At iteration step {niter + 1}")
                du = problem_u.solve()
                Du.x.array[:] = Du.x.array + du.x.array
                mpi_print(f"du norm = {np.linalg.norm(du.x.array)}")
                # nRes1 = np.sqrt(mesh.comm.allreduce(np.sum(problem_u.b.array**2), op=MPI.SUM))
                nRes = problem_u.b.norm(1)
                mpi_print(f"b norm: {nRes}\n")
                niter += 1
            u.x.array[:] = u.x.array + Du.x.array
            sig.x.array[:] = quad_interpolation(new_sig, W).x.array
            mpi_print(f"sig dof = {sig.x.array.shape}")
            mpi_print(f"sig norm = {np.linalg.norm(sig.x.array)}")
            cumulative_p.x.array[:] = cumulative_p.x.array + quad_interpolation(dp, W0).x.array
            # Remark: Can we do interpolation here?
            # p_avg.interpolate(fem.Expression(cumulative_p, P0.element.interpolation_points))
            p_avg.x.array[:] = l2_projection(cumulative_p, P0).x.array
            strain_xx.x.array[:] = l2_projection(ufl.grad(u)[0, 0], P0).x.array
            stress_xx.x.array[:] = l2_projection(sig[0, 0], P0).x.array
            phase_avg.x.array[:] = l2_projection(phase, P0).x.array
            T_old.x.array[:] = T_crt.x.array
            write_sol(vtk_file, i + 1)
            write_sol(xdmf_file, i + 1)
    simulation()
Where the code for “arguments” is as follows:
##### import numpy as onp
import argparse
import sys
import numpy as onp
# Set numpy printing format
onp.random.seed(0)                  #指定随机数生成时所用算法开始的整数值
onp.set_printoptions(threshold=sys.maxsize, linewidth=1000, suppress=True)     #控制输出方式:显示所有数组元素、每行字符的数目为1000、小数以科学计数法的形式输出
onp.set_printoptions(precision=10)                                             #控制输出方式:输出结果的精度(小数点后的位数)为10
# np.set_printoptions(threshold=sys.maxsize, linewidth=1000, suppress=True)
# np.set_printoptions(precision=5)
# Manage arguments
parser = argparse.ArgumentParser()                     #创建一个解析器,ArgumentParser对象包含将命令行解析成Python数据类型的全部信息
parser.add_argument('--num_oris', type=int, default=20)
parser.add_argument('--num_grains', type=int, default=40000)
parser.add_argument('--dim', type=int, default=3)
parser.add_argument('--domain_x', type=float, help='Unit: mm', default=0.5)
parser.add_argument('--domain_y', type=float, help='Unit: mm', default=0.2)
parser.add_argument('--domain_z', type=float, help='Unit: mm', default=0.05)
# parser.add_argument('--domain_x', type=float, help='Unit: mm', default=0.05)
# parser.add_argument('--domain_y', type=float, help='Unit: mm', default=0.02)
# parser.add_argument('--domain_z', type=float, help='Unit: mm', default=0.005)
parser.add_argument('--dt', type=float, help='Unit: s', default=2e-7)
parser.add_argument('--T_melt', type=float, help='Unit: K', default=1700.)
parser.add_argument('--T_ambient', type=float, help='Unit: K', default=300.)
parser.add_argument('--rho', type=float, help='Unit: kg/mm^3', default=8.08e-6)
parser.add_argument('--c_p', type=float, help='Unit: J/(kg*K)', default=770.)
parser.add_argument('--alpha_V', type=float, help='Unit: 1/K', default=1e-5)
parser.add_argument('--Young_mod', type=float, help='Unit: MPa', default=70e3)
# parser.add_argument('--laser_vel', type=float, help='Unit: mm/s', default=500.)
parser.add_argument('--power', type=float, help='Unit: W', default=60.)
parser.add_argument('--power_fraction', type=float, help='Unit: None', default=0.4)
parser.add_argument('--r_beam', type=float, help='Unit: mm', default=0.05)
parser.add_argument('--emissivity', type=float, help='Unit:', default=0.2)
parser.add_argument('--SB_constant', type=float, help='Unit: W/(mm^2*K^4)', default=5.67e-14)
parser.add_argument('--h_conv', type=float, help='Unit: W/(mm^2*K)', default=1e-4)
parser.add_argument('--kappa_T', type=float, help='Unit: W/(mm*K)', default=1e-2)
parser.add_argument('--write_sol_interval', type=int, help='interval of writing solutions to file', default=500)
args = parser.parse_args(args=[])
# Latex style plot              #更新全局绘图参数
plt.rcParams.update({
    "text.latex.preamble": r"\usepackage{amsmath}",
    "text.usetex": True,
    "font.family": "sans-serif",
    "font.sans-serif": ["Helvetica"]})
However, the following error occurs during runtime:
usage: ipykernel_launcher.py [-h] [--num_oris NUM_ORIS]
                             [--num_grains NUM_GRAINS] [--dim DIM]
                             [--domain_x DOMAIN_X] [--domain_y DOMAIN_Y]
                             [--domain_z DOMAIN_Z] [--dt DT] [--T_melt T_MELT]
                             [--T_ambient T_AMBIENT] [--rho RHO] [--c_p C_P]
                             [--alpha_V ALPHA_V] [--Young_mod YOUNG_MOD]
                             [--power POWER] [--power_fraction POWER_FRACTION]
                             [--r_beam R_BEAM] [--emissivity EMISSIVITY]
                             [--SB_constant SB_CONSTANT] [--h_conv H_CONV]
                             [--kappa_T KAPPA_T]
                             [--write_sol_interval WRITE_SOL_INTERVAL]
ipykernel_launcher.py: error: unrecognized arguments: -f /home/ljr/.local/share/jupyter/runtime/kernel-418ab754-bea6-4cd3-9a12-d50bacc0d21e.json
An exception has occurred, use %tb to see the full traceback.
SystemExit: 2
WARNING:py.warnings:/home/ljr/anaconda3/envs/fenicsx-env/lib/python3.12/site-packages/IPython/core/interactiveshell.py:3561: UserWarning: To exit: use 'exit', 'quit', or Ctrl-D.
  warn("To exit: use 'exit', 'quit', or Ctrl-D.", stacklevel=1)
Sorry but this is far from a MWE, please make one and identify exactly on a much simpler version what is your error
You would have to switch the form_compiler representation back to “quadrature” if you want to use quadrature elements in legacy dolfin.
