Hello everybody,
i have a problem with my specific values for g (Neumann condition).
import matplotlib.pylab as plt
import math
# Gebiet und Mesh erstellen------------------------------------------------
domain_vertices = [Point(2.0, 2.0),
Point(1.0, 3.0),
Point(-1.0, 1.0),
Point(4.0, -4.0),
Point(5.0, -3.0),
Point(2.0, 0.0),
Point(0.001, 0.0)]
domain = Polygon(domain_vertices)
mesh = generate_mesh(domain,10)
coordinates = mesh.coordinates()
#Functionspace-----------------------------------------------------------
uh = Function(V)
x = SpatialCoordinate(mesh)
f = sin(2.0*pi*x[0])*cos(2.0*pi*x[1])
# Tangential gradient operator:
def grad_t(u):
return grad(u) - dot(grad(u),n)*n
# Randbedingungen-----------------------------------------------------------
class Left(SubDomain):
return on_boundary and (between(x[1], (-1.0, 1.0)) and between(x[0], (4.0, -4.0)))
class Right(SubDomain):
#return near(x[1], 1.0)
return on_boundary and ((between(x[1], (2.0, 2.0)) and between(x[0], (1.0, 3.0))) and (between(x[1], (0.1, 0.0)) and between(x[0], (2.0, 2.0))) and (between(x[1], (2.0, 0.0)) and between(x[0], (0.1, 0.0))) and (between(x[1], (5.0, -3.0)) and between(x[0], (2.0, 0.0))))
class Bottom(SubDomain):
return on_boundary and (between(x[1], (5.0, -3.0)) and between(x[0], (4.0, -4.0)))
class Top(SubDomain):
return on_boundary and (between(x[1], (1.0, 3.0)) and between(x[0], (-1.0, 1.0)))
# Initialize sub-domain instances
left = Left()
top = Top()
right = Right()
bottom = Bottom()
boundaries = MeshFunction("size_t", mesh, mesh.topology().dim()-1, 0)
boundaries.set_all(4)
left.mark(boundaries, 1)
top.mark(boundaries, 2)
right.mark(boundaries, 3)
bottom.mark(boundaries, 4)
# Define Dirichlet boundary condition at top
bc2 = DirichletBC(V, 0.0, boundaries, 2)
#Take a look at the solution:
ds=Measure('ds', domain=mesh, subdomain_data=boundaries)
area_gamma1 = assemble(1*ds(4))
g = Expression("1/area_gamma1 * x4")
leitfaehigkeit=8.6e6
# Residual of Poisson problem with the specified BC:----------------------------------------------
res2 = inner(grad(u),grad(v))*dx - leitfaehigkeit*inner(g,grad_t(v))*ds(4) - inner(f,v)*dx
solve(lhs(res2)==rhs(res2),uh, bc2)
plot(uh)
plt.savefig("solution2.png")
With x4 are my values for the current at several time steps.
I get the following error
Blockquote
g = Expression(“1/area_gamma1 * x4”)
File “/usr/local/lib/python3.6/dist-packages/dolfin/function/expression.py”, line 400, in init
File “/usr/local/lib/python3.6/dist-packages/dolfin/function/jit.py”, line 158, in compile_expression
File “/usr/local/lib/python3.6/dist-packages/dolfin/jit/jit.py”, line 170, in compile_class
raise RuntimeError(“Unable to compile C++ code with dijitso”)
Blockquote
Could somebody please help me with this? Currently i am a bit confused.
Greetings
