Projecting Cauchy stress tensor gives different results
Hi, I am trying to solve a torsion of an hyperelastic cylinder. Then I want to compute the normal force and the torque, using the formulas
N=\int^{2\pi}_{0}\int_{0}^{r_0}\sigma_{zz}r dr d\theta and T=\int^{2\pi}_{0}\int_{0}^{r_0}\sigma_{\theta z}r^2 dr d\theta. Since I am working in Cartesian coordinates I trasform these integrals and then I need to compute \sigma_{\theta z} from the component I have. I wrote the following code. The problem is that I obtain always different values for the normal force every time I run the code. I think is something linked with the lagrangian multiplier p, maybe I am taking a wrong functional space. But when I try to change the functional spaces I am using, it gives me errors and the solver does not converge. Does someone know what is going on?
from ufl import replace
import csv
from math import *
from ufl import grad as ufl_grad
def Grad(v):
    return ufl_grad(v)
# Second order identity tensor
def SecondOrderIdentity(u):
    d = u.geometric_dimension()
    return variable(Identity(d))
# Deformation gradient
def DeformationGradient(u):
    I = SecondOrderIdentity(u)
    return variable(I + Grad(u))
# Determinant of the deformation gradient
def Jacobian(u):
    F = DeformationGradient(u)
    return variable(det(F))
# Right Cauchy-Green tensor
def RightCauchyGreen(u):
    return variable(F.T*F)
# Left Cauchy-Green tensor
def LeftCauchyGreen(u):
    return variable(F*F.T)
# Invariants of an arbitrary tensor, A
def Invariants(A):
    I1 = tr(A)
    I2 = 0.5*(tr(A)**2 - tr(A*A))
    I3 = det(A)
    return [variable(I1), variable(I2), variable(I3)]
# Invariants of the (right/left) Cauchy-Green tensor
def CauchyGreenInvariants(u):
    C = RightCauchyGreen(u)
    [I1, I2, I3] = Invariants(C)
# Elastic Cauchy stress tensor
def elastic_Cauchy(u,p):
    B = LeftCauchyGreen(u)
    J = Jacobian(u)
    I1, I2, I3 = CauchyGreenInvariants(u)
    psi = (mu_0/2-c2)*(I1 - 3) + c2*(I2 - 3)
    W1 = diff(psi,I1)
    W2 = diff(psi,I2)
    Te = 2*W1*B-2*W2*inv(B)-p*I
    return variable(Te)
# First Piola-Kirchhoff stress tensor
def FirstPiola(u,p):
    J = Jacobian(u)
    T = elastic_Cauchy(u,p)
    return variable(J*T*inv(F).T)
def geometry_3d(r1,r2,h1,h2):
     #Making a cylindrical geometry
     #cylinder = Cylinder('coordinate of center of the top circle', 'coordinate of center of the bottom circle', 'radius of the circle at the top', 'radius of the circle at the bottom')
     cylinder = Cylinder(Point(0, 0, h2), Point(0, 0, h1), r1, r2)
     geometry = cylinder
     # Making Mesh (30 corresponds to the mesh density)
     mesh = generate_mesh(geometry, 30)
     boundary_parts = MeshFunction('size_t', mesh, mesh.topology().dim()-1)
     boundary_parts.set_all(0)
     bottom = AutoSubDomain(lambda x: near(x[2], h1))
     top = AutoSubDomain(lambda x: near(x[2], h2))
     bottom.mark(boundary_parts, 1)
     top.mark(boundary_parts, 2)
     return boundary_parts
# Create mesh and define function space ============================================
r1 = 12.5 #m
r2 = 12.5 #m
h1 =  0.0 #m
h2 = 10.0 #m
facet_function = geometry_3d(r1,r2,h1,h2)
mesh = facet_function.mesh()
gdim = mesh.geometry().dim()
dx = Measure("dx")
ds = Measure("ds", domain=mesh, subdomain_data=facet_function)
print('Number of nodes: ',mesh.num_vertices())
print('Number of cells: ',mesh.num_cells())
mesh_file = File("mesh.pvd")
mesh_file << mesh
# Limit quadrature degree
dx = dx(degree=4)
ds = ds(degree=4)
### Create function space
P2 = VectorElement("CG", mesh.ufl_cell(), 1) # displacement u
P1 = FiniteElement("CG", mesh.ufl_cell(), 1) # pressure p
DG = FiniteElement("DG", mesh.ufl_cell(), 0)
TH = MixedElement([P2, P1])
V = FunctionSpace(mesh, TH)
W = FunctionSpace(mesh, DG)
TT = TensorElement("DG", mesh.ufl_cell(), 0)
TS = FunctionSpace(mesh, TT)
### Define functions for variational problems
# Incremental displacement and pressure
dup = TrialFunction(V)
(du, dp) = split(dup)
# Test functions for displacement and pressure
u_, p_ = TestFunctions(V)
# Displacement and pressure (current value)
up = Function(V)
(u, p) = split(up)
# Components of Cauchy stress tensor
sigma_theta_z = Function(W)
sigma_z_z = Function(W)
# Displacement from previous iteration
#h = Torsion() # Traction force on the boundary
# Time stepping parameters
dt = 0.1
t = 0.0
Tfin = 5.0
### Boundary conditions
twist = Expression(("x[0] == 0 ? 0 : sqrt(pow(x[0],2)+pow(x[1],2))*cos(atan2(x[1],x[0])+theta*x[2])-x[0]", "x[0] == 0 ? 0 : sqrt(pow(x[0],2)+pow(x[1],2))*sin(atan2(x[1],x[0])+theta*x[2])-x[1]", "0.0"), theta=0.0, degree=1)
bc_bottom = DirichletBC(V.sub(0), Constant((0, 0, 0)), facet_function, 1)
bc_top = DirichletBC(V.sub(0), twist, facet_function, 2)
bcs = [bc_bottom, bc_top]
### Input parameters
strain0 = 0.02
t_star =  0.3
mu_0 = Constant(1.0) #+ mu_2 + mu_3
c2 = Constant(2/3*mu_0) #Pa
r = Function(W)
r.interpolate(Expression("sqrt(pow(x[0],2)+pow(x[1],2))", degree=0))
J = Jacobian(u)
P = FirstPiola(u,p)
L1 = inner(P, Grad(u_))*dx #- dot(h, u_)*ds(2)
L2 = (J-1)*p_*dx
L = L1 + L2
j = derivative(L, up, dup)
problem = NonlinearVariationalProblem(L, up, bcs, J=j)
solver.parameters['newton_solver']['relative_tolerance'] = 1e-6
solver.parameters['newton_solver']['linear_solver'] = 'mumps'
### Save in a file
displacement_file = File("u.pvd")
pressure_file = File("p.pvd")
normal_file = open("normal_num.csv", "w")
writer_normal = csv.writer(normal_file)
torque_file = open("torque_num.csv", "w")
writer_torque = csv.writer(torque_file)
tol = 1e-06
while t <= Tfin+tol:
     t = round(t,2)
     print('time: ', t)
     # Increase torsion
     if t <= t_star+tol:
        alpha = (strain0/r2)*(t/t_star)
        alpha = 1/r2*strain0
     twist.theta = alpha
     # solve and save displacement
     solver.solve()
     u, p = up.split()
     displacement_file << (u, t)
     pressure_file << (p, t)
     # Compute the normal and the torque
     Tv = elastic_Cauchy(u,p)
     sigma_v = project(Tv,TS) #Put here Cauchy stress tensor
     sigma_values = sigma_v.vector().get_local()
     for cell in cells(mesh):
        i = cell.index()
        x = cell.midpoint()[0]
        y = cell.midpoint()[1]
        z = cell.midpoint()[2]
        sigma_xx=sigma_values[9*i]
        sigma_yy=sigma_values[9*i+4]
        sigma_zz=sigma_values[9*i+8]
        sigma_xy=sigma_values[9*i+1]
        sigma_xz=sigma_values[9*i+2]
        sigma_yz=sigma_values[9*i+5]
        theta_t = atan2(y,x)
        sigma_theta_z.vector()[i] = -sin(theta_t)*sigma_xz+cos(theta_t)*sigma_yz
        sigma_z_z.vector()[i] = sigma_zz
     normal = assemble(sigma_z_z*ds(2))
     torque = assemble(sigma_theta_z*r*ds(2))
     writer_normal.writerow([t, normal])
     writer_torque.writerow([t, torque])
     # time increment
     t += float(dt)
normal_file.close()
torque_file.close()
