Hello. I’ve built the dolfinx c++ core from source and I am trying to install the python interface with pip install .
haydel@Delta-XPS-15-9500:~/FEniCSx/dolfinx/cpp/build$ make install
[100%] Built target dolfinx
Install the project...
-- Install configuration: "RelWithDebInfo"
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/lib/libdolfinx.so.0.5.0
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/lib/cmake/dolfinx/DOLFINXTargets.cmake
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/lib/cmake/dolfinx/DOLFINXTargets-relwithdebinfo.cmake
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/common/defines.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/common/dolfin_common.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/common/dolfin_doc.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/common/IndexMap.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/common/log.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/common/loguru.hpp
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/common/sort.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/common/math.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/common/MPI.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/common/Scatterer.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/common/Table.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/common/Timer.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/common/TimeLogger.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/common/TimeLogManager.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/common/timing.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/common/utils.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/fem/Constant.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/fem/CoordinateElement.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/fem/DirichletBC.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/fem/DofMap.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/fem/ElementDofLayout.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/fem/Expression.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/fem/FiniteElement.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/fem/Form.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/fem/Function.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/fem/FunctionSpace.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/fem/assembler.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/fem/assemble_matrix_impl.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/fem/assemble_scalar_impl.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/fem/assemble_vector_impl.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/fem/discreteoperators.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/fem/dofmapbuilder.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/fem/dolfin_fem.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/fem/interpolate.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/fem/petsc.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/fem/sparsitybuild.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/fem/utils.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/geometry/BoundingBoxTree.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/geometry/gjk.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/geometry/dolfin_geometry.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/geometry/utils.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/graph/AdjacencyList.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/graph/dolfin_graph.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/graph/ordering.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/graph/partitioners.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/graph/partition.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/io/dolfin_io.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/io/ADIOS2Writers.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/io/cells.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/io/HDF5Interface.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/io/vtk_utils.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/io/VTKFile.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/io/XDMFFile.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/io/xdmf_function.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/io/xdmf_mesh.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/io/xdmf_meshtags.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/io/xdmf_read.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/io/xdmf_utils.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/la/dolfin_la.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/la/MatrixCSR.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/la/SparsityPattern.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/la/Vector.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/la/petsc.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/la/utils.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/la/slepc.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/mesh/dolfin_mesh.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/mesh/Mesh.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/mesh/Geometry.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/mesh/Topology.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/mesh/MeshTags.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/mesh/cell_types.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/mesh/generation.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/mesh/graphbuild.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/mesh/permutationcomputation.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/mesh/topologycomputation.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/mesh/utils.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/nls/dolfin_nls.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/nls/NewtonSolver.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/refinement/dolfin_refinement.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/refinement/plaza.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/refinement/refine.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/refinement/utils.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/include/dolfinx/common/version.h
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/lib/cmake/dolfinx/DOLFINXConfig.cmake
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/lib/cmake/dolfinx/DOLFINXConfigVersion.cmake
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/lib/pkgconfig/dolfinx.pc
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/lib/dolfinx/dolfinx.conf
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/share/dolfinx/demo
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/share/dolfinx/demo/hyperelasticity
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/share/dolfinx/demo/hyperelasticity/main.cpp
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/share/dolfinx/demo/hyperelasticity/CMakeLists.txt
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/share/dolfinx/demo/hyperelasticity/hyperelasticity.py
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/share/dolfinx/demo/interpolation-io
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/share/dolfinx/demo/interpolation-io/main.cpp
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/share/dolfinx/demo/interpolation-io/CMakeLists.txt
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/share/dolfinx/demo/poisson_matrix_free
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/share/dolfinx/demo/poisson_matrix_free/poisson.py
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/share/dolfinx/demo/poisson_matrix_free/main.cpp
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/share/dolfinx/demo/poisson_matrix_free/CMakeLists.txt
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/share/dolfinx/demo/poisson/poisson.py
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/share/dolfinx/demo/poisson/main.cpp
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/share/dolfinx/demo/poisson/CMakeLists.txt
-- Up-to-date: /home/haydel/FEniCSx/dolfinx/cpp/build/share/dolfinx/demo/CMakeLists.txt
DOLFINx has now been installed in
and demo programs have been installed in
Don't forget to update your environment variables. This can be done
easily using the helper file 'dolfinx.conf' which sets the appropriate
variables (for users of the Bash shell).
To update your environment variables, run the following command:
source /home/haydel/FEniCSx/dolfinx/cpp/build/lib/dolfinx/dolfinx.conf
with the error message here:
haydel@Delta-XPS-15-9500:~/FEniCSx/dolfinx/python$ pip install .
Processing /home/haydel/FEniCSx/dolfinx/python
Preparing metadata (setup.py) ... done
Requirement already satisfied: cffi in /home/haydel/FEniCSx/python/lib/python3.10/site-packages (from fenics-dolfinx==0.5.0) (1.15.1)
Requirement already satisfied: numpy>=1.21 in /home/haydel/FEniCSx/python/lib/python3.10/site-packages (from fenics-dolfinx==0.5.0) (1.23.2)
Requirement already satisfied: mpi4py in /home/haydel/FEniCSx/python/lib/python3.10/site-packages (from fenics-dolfinx==0.5.0) (3.1.3)
Requirement already satisfied: petsc4py in /home/haydel/FEniCSx/python/lib/python3.10/site-packages (from fenics-dolfinx==0.5.0) (3.17.4)
Requirement already satisfied: fenics-ffcx<0.6.0,>=0.5.0 in /home/haydel/FEniCSx/python/lib/python3.10/site-packages (from fenics-dolfinx==0.5.0) (0.5.0.post0)
Requirement already satisfied: fenics-ufl<2022.3.0,>=2022.2.0 in /home/haydel/FEniCSx/python/lib/python3.10/site-packages (from fenics-dolfinx==0.5.0) (2022.2.0)
Requirement already satisfied: setuptools in /home/haydel/FEniCSx/python/lib/python3.10/site-packages (from fenics-ffcx<0.6.0,>=0.5.0->fenics-dolfinx==0.5.0) (63.2.0)
Requirement already satisfied: fenics-basix<0.6.0,>=0.5.0 in /home/haydel/FEniCSx/python/lib/python3.10/site-packages (from fenics-ffcx<0.6.0,>=0.5.0->fenics-dolfinx==0.5.0) (0.5.0)
Requirement already satisfied: pycparser in /home/haydel/FEniCSx/python/lib/python3.10/site-packages (from cffi->fenics-dolfinx==0.5.0) (2.21)
Using legacy 'setup.py install' for fenics-dolfinx, since package 'wheel' is not installed.
Installing collected packages: fenics-dolfinx
Running setup.py install for fenics-dolfinx ... error
error: subprocess-exited-with-error
× Running setup.py install for fenics-dolfinx did not run successfully.
│ exit code: 1
╰─> [102 lines of output]
/home/haydel/FEniCSx/python/lib/python3.10/site-packages/setuptools/installer.py:27: SetuptoolsDeprecationWarning: setuptools.installer is deprecated. Requirements should be satisfied by a PEP 517 installer.
warnings.warn(
WARNING: The wheel package is not available.
running install
/home/haydel/FEniCSx/python/lib/python3.10/site-packages/setuptools/command/install.py:34: SetuptoolsDeprecationWarning: setup.py install is deprecated. Use build and pip and other standards-based tools.
warnings.warn(
running build
running build_py
running build_ext
-- Found Python3: /home/haydel/FEniCSx/python/bin/python3.10 (found version "3.10.6") found components: Interpreter Development
-- Found pybind11: /home/haydel/FEniCSx/dolfinx/python/.eggs/pybind11-2.10.0-py3.10.egg/pybind11/include (found version "2.10.0")
-- Adding /home/haydel/FEniCSx/python/lib/python3.10/site-packages/basix to Basix search hints
-- Found Boost 1.71.0 at /usr/lib/x86_64-linux-gnu/cmake/Boost-1.71.0
-- Requested configuration: QUIET REQUIRED COMPONENTS timer;filesystem
-- Found boost_headers 1.71.0 at /usr/lib/x86_64-linux-gnu/cmake/boost_headers-1.71.0
-- Found boost_timer 1.71.0 at /usr/lib/x86_64-linux-gnu/cmake/boost_timer-1.71.0
-- [x] libboost_timer.so.1.71.0
-- [ ] libboost_timer.a
-- Adding boost_timer dependencies: chrono;headers
-- Found boost_chrono 1.71.0 at /usr/lib/x86_64-linux-gnu/cmake/boost_chrono-1.71.0
-- [x] libboost_chrono.so.1.71.0
-- [ ] libboost_chrono.a
-- Adding boost_chrono dependencies: headers
-- Found boost_filesystem 1.71.0 at /usr/lib/x86_64-linux-gnu/cmake/boost_filesystem-1.71.0
-- [x] libboost_filesystem.so.1.71.0
-- [ ] libboost_filesystem.a
-- Adding boost_filesystem dependencies: headers
-- HDF5: Using hdf5 compiler wrapper to determine C configuration
-- HDF5_DIR: HDF5_DIR-NOTFOUND
-- HDF5_DEFINITIONS:
-- HDF5_INCLUDE_DIRS: /usr/include/hdf5/openmpi
-- HDF5_LIBRARIES: /usr/lib/x86_64-linux-gnu/hdf5/openmpi/libhdf5.so;/usr/lib/x86_64-linux-gnu/libsz.so;/usr/lib/x86_64-linux-gnu/libz.so;/usr/lib/x86_64-linux-gnu/libdl.so;/usr/lib/x86_64-linux-gnu/libm.so
-- HDF5_HL_LIBRARIES:
-- HDF5_C_DEFINITIONS:
-- HDF5_C_INCLUDE_DIR:
-- HDF5_C_INCLUDE_DIRS: /usr/include/hdf5/openmpi
-- HDF5_C_LIBRARY:
-- HDF5_C_LIBRARIES: /usr/lib/x86_64-linux-gnu/hdf5/openmpi/libhdf5.so;/usr/lib/x86_64-linux-gnu/libsz.so;/usr/lib/x86_64-linux-gnu/libz.so;/usr/lib/x86_64-linux-gnu/libdl.so;/usr/lib/x86_64-linux-gnu/libm.so
-- HDF5_C_HL_LIBRARY:
-- HDF5_C_HL_LIBRARIES:
CMake Error at /home/haydel/FEniCSx/dolfinx/cpp/build/dolfinx/DOLFINXConfig.cmake:101 (include):
include could not find load file:
/home/haydel/FEniCSx/dolfinx/cpp/build/dolfinx/DOLFINXTargets.cmake
Call Stack (most recent call first):
CMakeLists.txt:35 (find_package)
CMake Error at CMakeLists.txt:39 (get_target_property):
get_target_property() called with non-existent target "dolfinx".
The cmake target file is built but not where the findpackage is looking:
Is there an easy fix for this? seems like I just need to point the setup.py to the correct directory, but I am not quite sure the best way to go about this without editing the file.
my environment vars are :
haydel@Delta-XPS-15-9500:~/FEniCSx/dolfinx/cpp/build$ echo $LD_LIBRARY_PATH
/home/haydel/FEniCSx/dolfinx/cpp/build/lib:/home/haydel/FEniCSx/dolfinx/cpp/build/lib:/home/haydel/FEniCSx/dolfinx/cpp/build/lib:/home/haydel/FEniCSx/dolfinx/cpp/build/lib:
haydel@Delta-XPS-15-9500:~/FEniCSx/dolfinx/cpp/build$ echo $PATH
/home/haydel/FEniCSx/dolfinx/cpp/build/bin:/home/haydel/FEniCSx/dolfinx/cpp/build/bin:/home/haydel/FEniCSx/dolfinx/cpp/build/bin:/home/haydel/FEniCSx/dolfinx/cpp/build/bin:/home/haydel/FEniCSx/python/bin:{/home/haydel/glvis-4.2:/usr/local/krb5/bin:/usr/local/ossh/bin:/home/haydel/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin}
haydel@Delta-XPS-15-9500:~/FEniCSx/dolfinx/cpp/build$ echo $PKG_CONFIG_PATH
/home/haydel/FEniCSx/dolfinx/cpp/build/lib/pkgconfig:/home/haydel/FEniCSx/dolfinx/cpp/build/lib/pkgconfig:/home/haydel/FEniCSx/dolfinx/cpp/build/lib/pkgconfig:/home/haydel/FEniCSx/dolfinx/cpp/build/lib/pkgconfig:
I know that I can use the spack package manager or docker image, but I would like to get this working if possible.
