Hi everyone,
I’m a FEniCS beginner and I am really looking forward to using it for my research.
Since I’d like to use my own (hex and quad) meshes from abaqus later, I’d first like to generate example meshes using quadrilaterals to understand the xml syntax, that I’d have to use when converting my abaqus mesh to fenics/dolfin.
However, I am not able to export quadrilateral xml mesh files.
I have found a tutorial [1], where a simple quad mesh is created.
Since the tutorial is based on FEniCS version 2018.1.0, I had to adapt it for my installed version 2017.2.0
from
mesh = UnitSquareMesh.create(1, 1, CellType.Type.quadrilateral)
File(‘mesh.xml’) << mesh
to
mesh = UnitSquareMesh.create(1, 1, CellType.Type_quadrilateral)
Generation of the “mesh” object then works perfectly fine, but when trying to export, it prompts an error message like the following:
*** Error: Unable to write mesh to XML file.
*** Reason: Unknown cell type (3).
*** Where: This error was encountered inside XMLMesh.cpp.
*** Process: 0
*** DOLFIN version: 2017.2.0
*** Git changeset: unknown
Am I missing something?
Thanks for any help!
[1] https://fenicsproject.org/docs/dolfin/2018.1.0/python/demos/cahn-hilliard/demo_cahn-hilliard.py.html
