Im trying to reproduce an algorithm for shape optimization in stokes flow by phase-field approaches,and the details of this algorithm :
Where α(φ) = α_0(1 − φ)2 and f (φ) = φ(1 − φ)(1/2 − φ).
Some definitions on the finite-dimensional spaces:
To reproduce the algorithm,I wrote the codes below:
code 1:update the velociaty field
import adios4dolfinx as adx
import pathlib
from dolfinx import fem, la, default_scalar_type
from dolfinx.fem import (Constant, Function, dirichletbc,
extract_function_spaces, form, functionspace,
locate_dofs_topological)
from dolfinx.fem.petsc import assemble_matrix_block, assemble_vector_block
from dolfinx.io import XDMFFile,VTXWriter
from dolfinx.mesh import CellType, create_rectangle, locate_entities_boundary, locate_entities
from ufl import div, dx, grad, inner, ds
# We create a {py:class}`Mesh <dolfinx.mesh.Mesh>`, define functions for
# locating geometrically subsets of the boundary, and define a function
# for the velocity on the lid:
# Create mesh
msh = create_rectangle(MPI.COMM_WORLD, [np.array([0, 0]), np.array([1, 1])],
[32, 32], CellType.triangle)
# Function to mark y = 0, y = 1
def noslip_boundary(x):
return np.logical_or(np.isclose(x[1], 0.0), np.isclose(x[1], 1.0))
# Function to mark the lid (x = 0)
def lid(x):
return np.isclose(x[0], 0.0)
# Lid velocity (y(1 - y)/0.25, 0)
def lid_velocity_expression(x):
y = x[1]
velocity_x = y * (1 - y) / 0.25
velocity_y = np.zeros_like(y)
return np.stack((velocity_x, velocity_y))
P2 = element("Lagrange", msh.basix_cell(), 2, shape=(msh.geometry.dim,))
P1 = element("Lagrange", msh.basix_cell(), 1)
V, Q = functionspace(msh, P2), functionspace(msh, P1)
# No-slip condition on boundaries where y = 0, and y = 1
noslip = np.zeros(msh.geometry.dim, dtype=PETSc.ScalarType) # type: ignore
facets = locate_entities_boundary(msh, 1, noslip_boundary)
bc0 = dirichletbc(noslip, locate_dofs_topological(V, 1, facets), V)
# Driving (lid) velocity condition on left boundary (x = 0)
lid_velocity = Function(V)
lid_velocity.interpolate(lid_velocity_expression)
facets = locate_entities_boundary(msh, 1, lid)
bc1 = dirichletbc(lid_velocity, locate_dofs_topological(V, 1, facets))
bcs = [bc0, bc1]
#alpha_0
alpha_0=Constant(msh, PETSc.ScalarType(0.2))
#define phi_0
W = functionspace(msh, ("DG", 0))
def condition_0(x):
return np.logical_or(x[0] <= 0.25, np.logical_and(x[1] >= 1/3, x[1] <= 2/3))
def condition_1(x):
return np.logical_or(np.logical_and(x[0] > 0.25,x[1] < 1/3),np.logical_and(x[0] > 0.25,x[1] > 2/3))
phi_0 = Function(W)
cells_0 = locate_entities(msh, msh.topology.dim, condition_0)
cells_1 = locate_entities(msh, msh.topology.dim, condition_1)
phi_0.x.array[cells_0] = np.full_like(cells_0, 1, dtype=default_scalar_type)
phi_0.x.array[cells_1] = np.full_like(cells_1, 0, dtype=default_scalar_type)
# The bilinear and linear forms for the Stokes equations are defined
# using a a blocked structure:
(u, p) = ufl.TrialFunction(V), ufl.TrialFunction(Q)
(v, q) = ufl.TestFunction(V), ufl.TestFunction(Q)
f = Constant(msh, (PETSc.ScalarType(0), PETSc.ScalarType(0)))
a = form([[inner(grad(u), grad(v)) * dx + inner(alpha_0*(Constant(msh, PETSc.ScalarType(1.0))-phi_0)*(Constant(msh, PETSc.ScalarType(1.0))-phi_0)*u, v)*dx, inner(p, div(v)) * dx],
[inner(div(u), q) * dx, None]])
L = form([inner(f, v) * dx, inner(Constant(msh, PETSc.ScalarType(0)), q) * dx])
# A block-diagonal preconditioner will be used with the iterative
# solvers for this problem:
a_p11 = form(inner(p, q) * dx)
a_p = [[a[0][0], None],
[None, a_p11]]
# ### Nested matrix solver
# We assemble the bilinear form into a nested matrix `A`, and call the
# `assemble()` method to communicate shared entries in parallel. Rows
# and columns in `A` that correspond to degrees-of-freedom with
# Dirichlet boundary conditions wil be zeroed by the assembler, and a
# value of 1 will be set on the diagonal for these rows.
def nested_iterative_solver():
"""Solve the Stokes problem using nest matrices and an iterative solver."""
# Assemble nested matrix operators
A = fem.petsc.assemble_matrix_nest(a, bcs=bcs)
# Create a nested matrix P to use as the preconditioner. The
# top-left block of P is shared with the top-left block of A. The
# bottom-right diagonal entry is assembled from the form a_p11:
P11 = fem.petsc.assemble_matrix(a_p11, [])
P = PETSc.Mat().createNest([[A.getNestSubMatrix(0, 0), None], [None, P11]])
P.assemble()
A00 = A.getNestSubMatrix(0, 0)
A00.setOption(PETSc.Mat.Option.SPD, True)
P00, P11 = P.getNestSubMatrix(0, 0), P.getNestSubMatrix(1, 1)
P00.setOption(PETSc.Mat.Option.SPD, True)
P11.setOption(PETSc.Mat.Option.SPD, True)
# Assemble right-hand side vector
b = fem.petsc.assemble_vector_nest(L)
# Modify ('lift') the RHS for Dirichlet boundary conditions
fem.petsc.apply_lifting_nest(b, a, bcs=bcs)
# Sum contributions for vector entries that are share across
# parallel processes
for b_sub in b.getNestSubVecs():
b_sub.ghostUpdate(addv=PETSc.InsertMode.ADD, mode=PETSc.ScatterMode.REVERSE)
# Set Dirichlet boundary condition values in the RHS vector
bcs0 = fem.bcs_by_block(extract_function_spaces(L), bcs)
fem.petsc.set_bc_nest(b, bcs0)
# The pressure field is determined only up to a constant. We supply
# a vector that spans the nullspace to the solver, and any component
# of the solution in this direction will be eliminated during the
# solution process.
null_vec = fem.petsc.create_vector_nest(L)
# Set velocity part to zero and the pressure part to a non-zero
# constant
null_vecs = null_vec.getNestSubVecs()
null_vecs[0].set(0.0), null_vecs[1].set(1.0)
# Normalize the vector that spans the nullspace, create a nullspace
# object, and attach it to the matrix
null_vec.normalize()
# Create a MINRES Krylov solver and a block-diagonal preconditioner
# using PETSc's additive fieldsplit preconditioner
ksp.setOperators(A, P)
ksp.setType("minres")
ksp.setTolerances(rtol=1e-9)
ksp.getPC().setType("fieldsplit")
ksp.getPC().setFieldSplitType(PETSc.PC.CompositeType.ADDITIVE)
# Define the matrix blocks in the preconditioner with the velocity
# and pressure matrix index sets
nested_IS = P.getNestISs()
ksp.getPC().setFieldSplitIS(("u", nested_IS[0][0]), ("p", nested_IS[0][1]))
# Set the preconditioners for each block. For the top-left
# Laplace-type operator we use algebraic multigrid. For the
# lower-right block we use a Jacobi preconditioner. By default, GAMG
# will infer the correct near-nullspace from the matrix block size.
ksp_u, ksp_p = ksp.getPC().getFieldSplitSubKSP()
ksp_u.setType("preonly")
ksp_u.getPC().setType("gamg")
ksp_p.setType("preonly")
ksp_p.getPC().setType("jacobi")
# Create finite element {py:class}`Function <dolfinx.fem.Function>`s
# for the velocity (on the space `V`) and for the pressure (on the
# space `Q`). The vectors for `u` and `p` are combined to form a
# nested vector and the system is solved.
u, p = Function(V), Function(Q)
x = PETSc.Vec().createNest([la.create_petsc_vector_wrap(u.x),
la.create_petsc_vector_wrap(p.x)])
ksp.solve(b, x)
#save mesh and u with adio4dolfinx
checkpoint_file = pathlib.Path("function_checkpoint.bp")
adx.write_mesh(msh, checkpoint_file, engine="BP4")
adx.write_function(u, checkpoint_file, engine="BP4")
# Save solution to file in XDMF format for visualization, e.g. with
# ParaView. Before writing to file, ghost values are updated using
# `scatter_forward`.
with XDMFFile(MPI.COMM_WORLD, "out_stokes/velocity.xdmf", "w") as ufile_xdmf:
u.x.scatter_forward()
P1 = element("Lagrange", msh.basix_cell(), 1, shape=(msh.geometry.dim,))
u1 = Function(functionspace(msh, P1))
u1.interpolate(u)
ufile_xdmf.write_mesh(msh)
ufile_xdmf.write_function(u1)
with XDMFFile(MPI.COMM_WORLD, "out_stokes/pressure.xdmf", "w") as pfile_xdmf:
p.x.scatter_forward()
pfile_xdmf.write_mesh(msh)
pfile_xdmf.write_function(p)
# Compute norms of the solution vectors
norm_u = u.x.norm()
norm_p = p.x.norm()
if MPI.COMM_WORLD.rank == 0:
print(f"(A) Norm of velocity coefficient vector (nested, iterative): {norm_u}")
print(f"(A) Norm of pressure coefficient vector (nested, iterative): {norm_p}")
return norm_u, norm_p
# Solve using PETSc MatNest
norm_u_0, norm_p_0 = nested_iterative_solver()
code 2:update the phase-field functions and variables:
import pathlib
from pathlib import Path
from dolfinx import fem, io, default_scalar_type
from dolfinx.fem.petsc import assemble_matrix, assemble_vector, LinearProblem
from dolfinx.fem import functionspace, Function ,Constant, assemble_scalar, form
from ufl import dot, div, dx, grad, inner, ds
# Read msh
checkpoint_file = Path("function_checkpoint.bp")
msh = adios4dolfinx.read_mesh(MPI.COMM_WORLD, checkpoint_file, engine='BP4', ghost_mode=dolfinx.mesh.GhostMode.shared_facet)
# Read u
U = functionspace(msh, P2)
u = Function(U)
adios4dolfinx.read_function(u, checkpoint_file, engine="BP4")
V = functionspace(msh, P1)
#define phi_0
def condition_0(x):
def condition_1(x):
phi_0 = Function(W)
with io.XDMFFile(MPI.COMM_WORLD, "output.xdmf", "w") as file:
file.write_mesh(msh)
file.write_function(phi_0)
# Assign to the parameter
alpha_0= 0.2
epsilon = 0.01
eta = 0.01
t = 1.0
beta_0 = 1.0
S = 0.5
beta = 0.5
V_0 = 1.0
#Start the inner iteration
k = 0
while k <= 10:
# Assign to λ
lamda = 0
if k == 0:
lamda_next = lamda
lamda_next = lamda_next
phi = ufl.TrialFunction(V)
phi_test = ufl.TestFunction(V)
if k == 0:
velocity_effect_1 = 0.5 * alpha_0 * dot(u, u) + S
velocity_effect_2 = - eta / epsilon * phi_0 * (1.0-phi_0) * (0.5-phi_0) + alpha_0 * dot(u, u) - lamda
velocity_effect_3 = S - 0.5 * alpha_0 * dot(u, u)
a = 1.0 / t * (inner(phi, phi_test) * dx)+ epsilon * eta * (inner(grad(phi), grad(phi_test)) * dx) + inner(velocity_effect_1 * phi, phi_test) * dx
L = 1.0 / t * (inner(phi_0, phi_test) * dx) + inner(velocity_effect_2, phi_test) * dx + inner(velocity_effect_3 * phi_0, phi_test) * dx
velocity_effect_1 = alpha_0 * 0.5 * dot(u, u)+ S
velocity_effect_2 = - eta / epsilon * phi_next * (1.0-phi_next) * (0.5-phi_next) + alpha_0 * dot(u, u) - lamda
L = 1.0 / t * (inner(phi_next, phi_test) * dx) + inner(velocity_effect_2, phi_test) * dx + inner(velocity_effect_3 * phi_next, phi_test) * dx
#Solve out the problem
problem = LinearProblem(a, L, petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
phi_next = problem.solve()
#Cauculate ∫_D φ_{h} ^{n + 1, k + 1, *} dx
if k == 0:
integral_form_1 = form(phi_0 * dx)
integral_value_1 = assemble_scalar(integral_form_1)
integral_form_1 = form(phi_next * dx)
#Restrict the phase-field function in [0, 1] by using a cut-off postprocessing strategy
phi_array = phi_next.x.array
phi_array[phi_array < 0] = 0
phi_array[phi_array > 1] = 1
phi_next.x.array[:] = phi_array
#visualize phi_next
filename = f"out_phase/phase_{k:03d}.xdmf"
with io.XDMFFile(MPI.COMM_WORLD, filename, "w") as phifile_xdmf:
phi_next.x.scatter_forward()
phifile_xdmf.write_mesh(msh)
phifile_xdmf.write_function(phi_next)
#update the parameter λ
def update_lamda():
#Cauculate ∫_D φ_{h} ^{n + 1, k + 1} dx
integral_form_2 = form(phi_next * dx)
integral_value_2 = assemble_scalar(integral_form_2)
#Cauculate Jv(φ_{h} ^{n + 1, k + 1,*}) and Jv(φ_{h} ^{n + 1, k + 1})
Jv_1 = integral_value_1 - beta * V_0
Jv_2 = integral_value_2 - beta * V_0
delta_Jv = Jv_1 - Jv_2
#Cauculate β_0^*
beta_0_star = lamda_next * (Jv_2 - Jv_1) / (Jv_2 * Jv_2)
#update λ
if delta_Jv >= 0:
lamda_new = lamda_next - beta_0 * Jv_2
lamda_new = lamda_next - beta_0_star * Jv_2
print(lamda_new)
return lamda_new
lamda_next = update_lamda()
k = k + 1
The output is supposed to be:
But the output of my code is:
visuallized phase-field function phi:
You can see difference between my output and the expected output. One of the differences is that the value of the expected phase-field function φ at the boundary y = 0 and y = 1 is zero, but the φ I solve out didnt appear that.
I had checked my code many times but coudnt figure out The error part in the my code.
