Question about saving the output in a more compact manner in parallel
I was wondering if there is a way besides using .pvd to save the outputs. When I run a time dependent code on 40 processors and save the output in .pvd it saves 40 chunks of the domain for each processor in .vtu. Then a .pvtu that gathers them for each time and then a .pvd that collects everything. I was wondering if there was a more compact and parallel compatible way to do this. Thank you so much for your help.
Best,
Look into using the scalable XDMFFile with h5 binary data. E.g. XDMFFile("something.xdmf").write(mesh)
Thank you Nate. I tried it and it works fine with functions changing in time. However, I have issues with meshfunctions. Suppose I have a mesh function that changes in time and I want to save it at each time step using the code below:
    mesh = UnitSquareMesh(10, 10)
    Inside = MeshFunction("size_t",mesh,2)
    V= VectorFunctionSpace(mesh,'P',1)
    u = Expression(('1','1'),degree=0)
    U = project(u,V)
    t = 0.0
    n=0
    file1 = XDMFFile(MPI.comm_world, "Inside.xdmf")
    file1.parameters["flush_output"] = True
    for n in range(100):
        ALE.move(mesh,U)
        file1.write(Inside)
        t+=1.0
This will give me an error on Paraview saying “unable to read data”. And when I replace
file1.write(Inside)
with
file1.write(Inside,t)
I get the following AttributeError from my code:
‘dolfin.cpp.mesh.MeshFunctionSizet’ object has no attribute ‘_cpp_object’
Do you know what’s happening here?
